POV-Ray : Newsgroups : povray.binaries.images : it's HDRI-tiiimee :) Server Time
21 Oct 2026 18:32:38 EDT (-0400)
  it's HDRI-tiiimee :) (Message 1 to 14 of 14)
Subject: it's HDRI-tiiimee :)
Date: 27 Dec 2002 22:43:26
Message: <3e0d1dde@news.povray.org>
Just a slightly adjusted version of the demo-scene included with MLPov.
First image is the POV-Ray-version, second image is a post-processed
version.
Here are some more tests: http://sad.studentenweb.org/hdri/
cu!
ZK AKA SaD
http://www.povplace.be.tf
"Wake up! Time to die."
Download 'HDRI2.jpg' (16 KB) Download 'HDRI2pp.jpg' (26 KB)
Preview of image 'HDRI2.jpg'
Preview of image 'HDRI2pp.jpg'
Subject: Re: it's HDRI-tiiimee :)
Date: 27 Dec 2002 22:57:55
Message: <3e0d2143@news.povray.org>
This sure looks promissing :)
Pretty cool stuff.
Can you tell something about render times?
Best regards.
Date: 27 Dec 2002 23:03:50
Message: <3e0d22a6@news.povray.org>
"JPGargoyle" <jot### [at] netcabopt> schreef in bericht
news:3e0d2143@news.povray.org...
> Pretty cool stuff.
tnx :)
It was rendered in 2 passes.  First pass with high radiosity settings
(error_bound .01 and 600 samples) at a very low resolution (160*120) (I
don't remember the rendertime for the first pass), second pass with lower
radiosity settings (error_bound 1.01, still 600 samples) at the full
resolution.  The second pass took 11 minutes 39 seconds, on an AMD
Thunderbird 1.1GHz, 352MB RAM, running Windows Me (too lazy to install a
decent OS :)
cu!
ZK AKA SaD
"Trust is only dangerous when you have to rely on it."
Date: 27 Dec 2002 23:53:34
Message: <1734054.elrD77ACJf@3-e.net>
Can you do this one again but add photons?
http://sad.studentenweb.org/hdri/globalilluminationtest7.jpg
Date: 28 Dec 2002 00:35:02
Message: <web.3e0d37d0f814632c5798b2cc0@news.povray.org>
I love it when a plan comes together....
*** http://www.highpoly3d.com ***
*** Tutorials/Textures/Forums ***
Date: 28 Dec 2002 08:44:23
Message: <3e0daab7@news.povray.org>
"Daniel Matthews" <dan#@3-e.net> schreef in bericht
news:173### [at] 3-enet...
there are no light_source's, so how can I add photons?
cu!
ZK AKA SaD
"Why make trillions when we could make... billions?"
Date: 28 Dec 2002 16:10:52
Message: <1236264.W7W56anrVo@3-e.net>
Ah well there's a nasty problem, if the HDRI environment can't act as a
light source for the purpose of generating caustics etc. then it is useless
for creating photo-realistic images.
<sigh>
Your connection failed because: Zombie processes haunting the computer
Date: 28 Dec 2002 16:31:35
Message: <3e0e1837$1@news.povray.org>
useless
> <sigh>
but if the radiosity-algorithm takes ior's into account, high enough
radiosity-settings should produce accurate caustics, no?
cu!
ZK AKA SaD
"Don't torture yourself Gomez, that's my job."
Date: 28 Dec 2002 21:43:37
Message: <3e0e6159$1@news.povray.org>
Correct.
 - Slime
[ http://www.slimeland.com/ ]
Date: 28 Dec 2002 22:01:13
Message: <3e0e6579$1@news.povray.org>
"Slime" <slm### [at] slimelandcom> schreef in bericht
news:3e0e6159$1@news.povray.org...
> Correct.
but does it take IOR's and reflections into account?
cu!
ZK AKA SaD
"We're not getting out of here in one piece, or if we do, it'll be one big
flat piece."
Date: 29 Dec 2002 05:06:27
Message: <Xns92F370B614C60raf256com@204.213.191.226>
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in
news:3e0e6579$1@news.povray.org
>> > enough radiosity-settings should produce accurate caustics, no?
>> Correct.
AFAIR no, same as it ignores specular/phong :( maybe it will could be done
in Pov 4.0 ?
Date: 23 Jun 2003 09:56:41
Message: <3ef70719@news.povray.org>
can you tell me the material of middle ball ?
KareoÝlker Yiðit Kareo Takým Lideri Vektor Ofis A.Þ. 0 216 411 1530
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in message
news:3e0d1dde@news.povray.org...
> version.
> cu!
> ZK AKA SaD
Date: 23 Jun 2003 12:02:06
Message: <3ef7247e@news.povray.org>
"ilker yigit" <ilk### [at] 2noktacom> schreef in bericht
news:3ef70719@news.povray.org...
I dont believe I changed any materials, but I'll check.
This is the material I used:
  pigment { color rgb 1 }
  finish { ambient 0 diffuse .8 reflection {0,.1 fresnel on}
   irid {.1 thickness .5 turbulence .5}
  interior {ior 28}
cu!
ZK AKA SaD
"Begin the unnecessarily slow-moving dipping mechanism!"
Date: 23 Jun 2003 13:32:04
Message: <3ef73994@news.povray.org>
Thanx for your reply. But i try this code but result is not some your
material.
What is wrong ?
#include "rad_def.inc"
global_settings{  max_trace_level 30
radiosity{ Rad_Settings(Radiosity_IndoorHQ, on, on)   }}
  location  <0.0, 2.0, -5.0>
  look_at   <0.0, 0.0,  0.0>
light_source {
  0*x                  // light's position (translated below)
  color rgb <1,1,1>    // light's color
  translate <-20, 40, -20>
sphere {
  <0, 1, 0> // center of sphere <X Y Z>
  0.5       // radius of sphere
  // scale <1,2,1> // <= Note: Spheres can become ellipses by uneven scaling
  interior {ior 28}
news:3ef7247e@news.povray.org...
>   interior {ior 28}
> cu!
> ZK AKA SaD
