I really had to study today, but I was way too tired for such a boring sh*t so
decided I better work on this boring shot, and I tried and textured my yet-to-be
textured watch model.
It's too late for a deeper description. Rendered with Mlpov 0.81. Render time: about
3 hours.
C&C is welcome.
Cheers,
Jonathan.
Download 'orologio_hdr.jpg' (128 KB)
Preview of image 'orologio_hdr.jpg'
It's ammazing work, like all the stuff you do :P
Keep them coming.
*** www.highpoly3d.com ***
*** Tutorials/Textures/Forums ***
Program ended abnormally on 12/26/02 8:18 PM, Due to a catastrophic JRG
error:
> 3 hours.
> C&C is welcome.
AWSUM ROLLEX!!!1!
This being said, I don't know if it's the focal blur or the jpeg but
there's something funky about the pixelisation in the image.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* videotron.ca */}camera{orthographic location<6,1.25,-6>look_at a }
Not zazzle worthy.....what's the use of a PHOTOGRAPH of a watch on a poster?
"JRG" <jrg### [at] hotmail com> wrote in news:3e0babc3@news.povray.org
Very nice image :) I would realy like to see a bigger version, with better
focalbulr.
Is it some path of Pov ?
How did you do the scratches on the surface of the
table/floor/somethingelse? Is it an image map?
> boring sh*t so decided I better work on this boring shot, and I tried
> and textured my yet-to-be textured watch model.
> Render time: about 3 hours.
> C&C is welcome.
Needs the focal blur sorting out, asdide from that AWSOME
PGP Public Key
Version: 6.0.434 / Virus Database: 243 - Release Date: 25/12/2002
The scratches on the face look a little weird, and it seems a little like
it's hovering in the air. Otherwise, it's really good. The focal blur could
easily be fixed up with a little Photoshop work. (I find that taking
POV-Ray's grainy blurring and then using a little gaussian blur over it
gives a smooth blur that's still quite close to realistic.)
How *did* you do the scratches anyway?
- Slime
[ http://www.slimeland.com/ ]
On Fri, 27 Dec 2002 02:18:04 +0100
> sh*t so decided I better work on this boring shot [...]
Strange concept of "boring"... I don't expect something "boring" to
keep me looking at it during hours, or comming back endless times to
look at it again.
Jaime Vives Piqueres
http://www.ignorancia.org
> look at it again.
Exactly - this has got to be one of the least boring images posting in a
while!
PGP Public Key
Thank you all for your comments.
About the focal blur... I did not use very low settings (blur_samples 70 variance 0),
and the grainess came quite a bit unexpected. I'm rendering a 1024x768 version atm
with better settings (blur_samples 200 variance 0)... if it does not look that good
I'll post the source so that everyone can raise it up to 1000 samples and start his
own 3 months worth render.
Welcome to the real world... ;-)
Yes it's a patch, here on earth we talked about it recently. Have a look at
povray.unofficial.patches and povray.general for more information.
Oh I just rendered a simple scene like this:
/* scratches */
//+w600 +h600
orthographic
location -5*z
look_at 0
right 40*x
up 40*y
#default {
pigment {rgb 1}
finish {ambient 1}
#include "transforms.inc"
#declare I = seed (0);
#declare ang = 0;
#while (ang < 360)
#declare num = 20 + 20*rand(I);
#declare i = 0;
#while (i<num)
#declare px = no;
#declare nx = no;
#declare r = 0.01+0.035*rand(I);
#declare s = 2+10*rand(I);
#declare _x = -20+40*rand(I);
#declare _y = -20+40*rand(I);
cylinder {
-0.5*y,0.5*y,r
scale <1,s,1>
rotate ang*z
translate <_x,_y,0>
#if (vtransform (0.5*y, transform {scale <1,s,1> rotate ang*z translate _x*x}).x>40
|vtransform (-0.5*y, transform {scale <1,s,1> rotate ang*z translate _x*x}).x>40)
#declare px = yes;
cylinder {
-0.5*y,0.5*y,r
scale <1,s,1>
rotate ang*z
translate <_x-40,_y,0>
#else
#if (vtransform (0.5*y, transform {scale <1,s,1> rotate ang*z translate _x*x}).x<40
|vtransform (-0.5*y, transform {scale <1,s,1> rotate ang*z translate _x*x}).x<40)
#declare nx = yes;
cylinder {
-0.5*y,0.5*y,r
scale <1,s,1>
rotate ang*z
translate <_x+40,_y,0>
#if (vtransform (0.5*y, transform {scale <1,s,1> rotate ang*z translate _y*y}).y>40
|vtransform (-0.5*y, transform {scale <1,s,1> rotate ang*z translate _y*y}).y>40)
cylinder {
-0.5*y,0.5*y,r
scale <1,s,1>
rotate ang*z
translate <_x,_y-40,0>
#if (px)
cylinder {
-0.5*y,0.5*y,r
scale <1,s,1>
rotate ang*z
translate <_x-40,_y-40,0>
#else
#if (nx)
cylinder {
-0.5*y,0.5*y,r
scale <1,s,1>
rotate ang*z
translate <_x+40,_y-40,0>
#else
#if (vtransform (0.5*y, transform {scale <1,s,1> rotate ang*z translate _y*y}).y<40
|vtransform (-0.5*y, transform {scale <1,s,1> rotate ang*z translate _y*y}).y<40)
cylinder {
-0.5*y,0.5*y,r
scale <1,s,1>
rotate ang*z
translate <_x,_y+40,0>
#if (px)
cylinder {
-0.5*y,0.5*y,r
scale <1,s,1>
rotate ang*z
translate <_x-40,_y+40,0>
#else
#if (nx)
cylinder {
-0.5*y,0.5*y,r
scale <1,s,1>
rotate ang*z
translate <_x+40,_y+40,0>
#declare i = i+1;
#declare ang = ang +20;
...and used it as a bump_map. The map, with different scale and bump_size, was
applied to every object in the scene.
That's maybe due to the fact that it's extremely scratchy. I just tried to reproduce
my mom's old watch, which is that scratchy.
As far as I am concerned, concerning this point, I know that it's not hovering so why
should I be concerned? Oh my.... English is hard. I mean, the watch isn't floating in
the air, fact, if it looks so how could I possibly fix it? :-)
Finally a strange thing which I couldn't fix yet: I get different results depending
on what I rotate: the hdr sphere or the whole scene. Specifically I get bad results
when rotating the sphere (the image gets extremely bright), while everything looks
fine when I rotate the scene as a whole (except the sphere that is)... weird isn't
it. The weirder (sp?) the bug, the higher the probability that it's not a bug but
some coding issue... well I couldn't find anything wrong with my code so far...
Cheers!
Jonathan.
> variance 0), and the grainess came quite a bit unexpected. I'm rendering a
> 1024x768 version atm with better settings (blur_samples 200 variance 0)...
> if it does not look that good I'll post the source so that everyone can
> raise it up to 1000 samples and start his own 3 months worth render.
LoL - three months, but not on my 1.8 THz machine ;)
Yes, the focal blur is too grainy in my opinion, but except that your image
is perfect. I really thought this is a photo.
Andreas
http://www.render-zone.com
"JRG" <jrg### [at] hotmail com> a écrit dans le message de news:
3e0c3c47@news.povray.org...
Same problem here, I couldn't get rid of the graininess in my glasses scenes
even with 200-300 samples.
> /* scratches */
Thanks ! This is going to be *** useful *** indeed.
> depending on what I rotate: the hdr sphere or the whole scene.
Hmm that could explain some of the things I've noticed too. I often have to
change the ambient value of the HDR map depending on the angle (which
doesn't make sense) but I didn't think of rotating the whole map.
Oh, and congrats for the watch pic, this is truly impressive.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
hmm keep in mind that mlpov is absolutely not deeply tested so maybe the bokeh
patch broke something in focal blur
> > /* scratches */
Yes very interesting
It would be nice to have a .inc package to create dirt, dust, scratch etc..
here again it's possible that there is some bug in the new hdr mapping
M
Very impressive - can't stop staring at it!
Mick
"JRG" <jrg### [at] hotmail com> wrote in message
news:3e0babc3@news.povray.org...
sh*t so
yet-to-be
time: about
> 3 hours.
> C&C is welcome.
> Cheers,
> Jonathan.
JRG escribió en el mensaje de noticias 3e0babc3@news.povray.org...
sh*t so
yet-to-be
time: about
> 3 hours.
> C&C is welcome.
Hi Jonathan.
My wife and daughters have had to disconnect the PC
to bring me back to this world.
Simply amazing, you get better and better with each
image you send, where will be your limit?.
I love the scratches, they give a great sense of realism to
your image.
Waiting to see the next image with the new focal blur settings
(I will ask my family for their support before I'll see it ;-).
Merry Xmas and a Happy New Year.
And keep up that fabulous work.
Bye
Txemi Jendrix
http://www.txemijendrix.com
Txemi Jendrix wrote:
>Hi Jonathan.
>your image.
>Bye
Merry Xmas and a Happy New Year to you too, Txemi, and thank you!!
Jonathan.
