Last ones before it gets boring... In fact I guess that similar results
could be obtained with regular maps, lol.
Xfrog rose, Rhino glasses. I had to touch up some residual focal blur
graininess.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Download 'hdr_glass.jpg' (137 KB)
Preview of image 'hdr_glass.jpg'
What exactly is HDRI? It looks to me like some sort of special "radiosity"
that only takes the sky_sphere into account and treats it as light sources.
But I can't figure out exactly what is happening.
It's certainly not getting boring, though... these images are extremely
impressive. Photorealistic. I love the red one. Hmm... where'd you get the
rose model?
- Slime
[ http://www.slimeland.com/ ]
"Slime" <slm### [at] slimeland com> a écrit dans le message de news:
3e0a5255@news.povray.org...
sources.
I guess it's explained here.
http://athens.ict.usc.edu/Research/HDR/
I tend to think of HDR maps as photographs with the ability to blind those
who see them...
Thanks. These are merely tests though, they just turned out better than they
were meant to. If I get the time, I'll develop them later (better textures
etc.).
> Hmm... where'd you get the rose model?
It's an Xfrog model from their "Flowers 1" collection.
G.
- Posters
> graininess.
Beautiful images, Gilles. I looked at some of the HDRI links you
provided for Slime, and I understood the explanation for a while,
but then it got sorta fuzzy. The HDR shop is a post-processor that's
applied after rendering, isn't it? Is that what you used?
Thanks, miker
"ZSpider" <zsp### [at] gte net> a écrit dans le message de news:
3e0b1239$1@news.povray.org...
Thanks !
I'd rather let the experts explain what this is all about because it's quite
fuzzy for me too !
Basically the trick is to get a HDR file and use it on a big sphere in a
radiosity scene. This I figured out.
What HDR shop does is 1) let you view and edit HDR files and 2) create HDR
files out of sequences of normal images (particularly ones from digital
cameras).
Actually this part is *** very *** confusing to me right now. Anyone knows
if it possible to take a single regular image and turn it into a HDR version
? I've tried it and get a HDR file but I'm not sure it really works (or make
sense at all ?)...
G.
- Posters
If you no see on p.g or p.u.p
There are a litle bug with material_map
The files corrected (source and exe) :
(same name of version mlpov081 122302)
http://martial.rameaux.free.fr/mael/mlpov81eng.html
Thanks Mael !
Martial
> fuzzy for me too !
> cameras).
> sense at all ?)...
First HDR has nothing to do with the kind of mapping you use. If you look at
Paul Debevec' page you'll find also box-mapped HDR images or simple planar
ones. High Dynamic Range Images means that the full color indensity (or better
the lumens) is also stored into the image file. This is a much better representation
of "reality" as Low Dynamic Range as represented by using the (poor) RGB
color space (used within jpg or png files). POV does internal work with high
dynamic range and I guess most of you have already used a light source that is
"brighter" than rgb <1,1,1>. I usually do so and this is the way Jaime's lighting
system does work. This is also "HDR".
Imaging a white sheet of paper, white clauds on a sunny day, the sun itself or
a exploding super nova. In rgb color space, all of them are represented as
simple rgb <1,1,1>. And as POV does already calculate with HDR values
it seems really logic and useful to me not to be restricted when it comes to
input AND output if image formats. This would give you simply the similar
possibilities that are normal to any photographer.
Oh, and one more thing: HDR means simply that the full range of gamut and
lumens is coverd by the image format. The files from Paul Debevec' page are
in the Radiance-format as developed by Greg Ward, who did also design the
LogLUV format (also HDR). There are others around as e.g. TIFF-Pixar-Log
as used by (you guessed it) Pixar.
-Ive
P.S. sorry Gilles it did happen again, wrong button in Outlook.
version
make
> sense at all ?)...
From what I read in the links you gave me, it seems that HDR is an image
format that lets you store non-clipped color values. (normal images cover
RGB values 0-255 (really 0.0 - 1.0), whereas HDR lets you cover 0.0 to
infinity... or maybe even negative infinity to infinity, I'm not sure.)
So you couldn't get an HDR image from a single photograph, since all that
photograph contains is values from 0 to 1, and you need more photographs
with different exposure times to get more information.
That's about all I can figure out.
- Slime
Thats correct Slime :) I've made a few square ones myself using just my
webcam and adjusting the exposure settings.. and using HDRShop.. its really
cool
George Pantzopoulos
> - Slime
Well.... why don't you render us some nice pics then?
Apache
"Ive" <ive### [at] lilysoft com> a écrit dans le message de news:
3e0b58b7$1@news.povray.org...
that is
lighting
In fact my question was more, given a normal LDR image with variation of
intensity clipped between 0 and 1, is it possible to create directly a HDR
image by calculating the intensity value from the clipped one, by using a
function I=f(r,g,b) with I being maximum (and much higher than 1 of course)
for White? As I said, HDR shop accepts to do this but I'm not sure that the
final image really has hot spots (but then I have not tested this
extensively).
In any case, creating HDR maps within POV-Ray would be sweet.
G.
- Posters
> for White?
No. If the data is clipped (like POV output) how should it be recovered. If
the data is compressed (like done with Kari's patch) there is no need to use
HDR shop, simply usse a higher ambient value, but the quality will not be the
same as with "real" hdr data. .
> extensively).
To recreate HDR data you'll need a couple of images (lets say 5 to 10
more are better) with different exposer, this works fine.
-Ive
course)
> for White?
From a single image, you could only approximate it. All of the clipped areas
(large areas of pure white or pure black) would have to be guessed about.
- Slime
