POV-Ray : Newsgroups : povray.binaries.images : bonsai scene ~96k Server Time
21 Oct 2026 21:46:13 EDT (-0400)
  bonsai scene ~96k (Message 1 to 15 of 15)
Subject: bonsai scene ~96k
Date: 7 Nov 2002 20:26:27
Message: <3dcb12c3@news.povray.org>
This is a bonsai scene I have been playing with on and off for a while.  I'd
like to add some media to create a slightly dusty/hazy look that would
highlight the light beams a little and maybe give the image a little extra
something.  Any advice on how to create a media that would do that would be
appreciated.
Patrick Dugan
Download 'Bonsai.jpg' (96 KB)
Preview of image 'Bonsai.jpg'
Subject: Re: bonsai scene ~96k
Date: 7 Nov 2002 21:21:58
Message: <3dcb1fc6$1@news.povray.org>
I'd
be
> appreciated.
Since you're using an area light, and area lights + media are a bad idea
when avoidable, I'd suggest this approach:
1. Put the entire scene you have right now (excluding the camera) into a
light_group.
2. Inside a separate light_group, create a plane whose surface coincides
with the backside of the bamboo wall. Make sure the tree and camera are
*inside* this plane. Make the plane hollow and transparent and give it an
interior something like
interior {
media {
scattering {2, .01}
// experiment with different scattering types (like type 1, or type 5 with
different eccentricity values)
// if the media is too heavy, lower the .01; if its too invisible, bring the
.01 up higher.
// if there's simply too much darkness for the lighting effects that are
created, then add "extinction .5" and fiddle with the .5 until it looks
good.
3. Put a light source identical to your area light inside this light_group,
but *don't make it an area light*. That way, the solid objects in the scene
will be lit with an area light, but the media will be lit with a point
light. This will speed up the render a *lot* and the difference probably
won't be noticeable.
 - Slime
[ http://www.slimeland.com/ ]
Date: 7 Nov 2002 21:25:50
Message: <chrishuff-87EAB0.21255107112002@netplex.aussie.org>
In article <3dcb12c3@news.povray.org>,
> appreciated.
Nice...the bark and leaves look too brightly lit though, do they have a
high ambient?
Anyway, what you want is scattering media, without a density pattern,
and with a very dim scattering color. Type 4 (Rayleigh) scattering is
probably the best for this. If it is invisible, boost the scattering
amount, if everything is black or white, lower it.
http://tag.povray.org/
Subject: RE: bonsai scene ~96k
Date: 7 Nov 2002 21:49:34
Message: <3dcb263e@news.povray.org>
Patrick Dugan escribió en el mensaje de noticias 3dcb12c3@news.povray.org...
I'd
be
> appreciated.
I have no advice to give (haven't played with scattering media)
but I wanted to say I like your bonsai a lot.
How it was made?.
Txemi Jendrix
http://www.txemijendrix.com
Date: 7 Nov 2002 22:05:59
Message: <3dcb2a17@news.povray.org>
Thank you!  The tree was created using Gilles Tran wonderful tree macro.
The rest was modeled within Povray by hand.  The bamboo was made using SOR
objects.
"Txemi Jendrix" <tji### [at] euskalnetnet> wrote in message
news:3dcb263e@news.povray.org...
> I'd
extra
> be
> > appreciated.
> How it was made?.
> Txemi Jendrix
Date: 7 Nov 2002 22:18:27
Message: <3dcb2d03@news.povray.org>
Okay, I'll show my stupidity here.  If I use a plane that is parallel to the
back wall won't it be flat?  How can the
tree and camera be inside it?  I could see a box since it would "fill" the
scene but I don't understand using a plane.
"Slime" <slm### [at] slimelandcom> wrote in message
news:3dcb1fc6$1@news.povray.org...
> I'd
extra
> be
> > appreciated.
> light_group.
> interior {
> media {
> scattering {2, .01}
the
> .01 up higher.
> good.
light_group,
scene
>  - Slime
Date: 7 Nov 2002 22:26:53
Message: <3dcb2efd@news.povray.org>
Patrick Dugan escribió en el mensaje de noticias 3dcb2a17@news.povray.org...
> objects.
I wanted to update an image I made back in 1999, and I
think your bonsai has given me the final push.
Again, great image. Waiting to see the media version.
Bye
PS: Just if you are curious, this is the old image:
http://www.txemijendrix.com/imagpov/povpage/1.html
Txemi Jendrix
Date: 7 Nov 2002 22:32:52
Message: <3dcb3064@news.povray.org>
Patrick Dugan escribió en el mensaje de noticias 3dcb2d03@news.povray.org...
the
I think he means you'll have to create a plane and rotate it
so the +y axis of the plane points to the tree and camera.
Bye
Txemi Jendrix
Date: 7 Nov 2002 22:53:31
Message: <3dcb353b@news.povray.org>
the
Planes have insides and outsides just like boxes or spheres. The
"underneath" part of a plane is considered to be "inside" it. So just make
sure the normal of the plane points *away* from the camera, so that the
camera is "underneath" it.
 - Slime
Date: 8 Nov 2002 05:34:27
Message: <nm4nsuk6i4ut4bfl0e9kqi2dpvqt4c3e8a@4ax.com>
On Thu, 7 Nov 2002 19:25:26 -0600, "Patrick Dugan"
>appreciated.
Impressive! I can't wait to see it with media.
My only nit to pick is that the whole bonsai - even the leaves - seems
luxophobic. Shouldn't at least the leaves make some effort to point to
the light, instead of away from it?
Peter Popov ICQ : 15002700
Date: 8 Nov 2002 10:09:51
Message: <3dcbd3bf@news.povray.org>
Well the entire scene has all ambient turned off.  It might be caused by my
radiosity setting being too bright.
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
I'd
extra
be
> > appreciated.
> high ambient?
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 8 Nov 2002 14:35:12
Message: <3dcc11f0$1@news.povray.org>
Txemi Jendrix escribió en el mensaje de noticias 3dcb3064@news.povray.org...
 It was exactly the contary (it was 4:30 a.m.)
Sorry for the inconvenience
Txemi Jendrix
Date: 9 Nov 2002 03:01:22
Message: <3dccc0d2@news.povray.org>
What a stunning little image... The colours, the sense of sunshine... The
tree looks cool... That moss is brilliant too... I _like_ this!
Andrew.
Date: 9 Nov 2002 09:14:29
Message: <3dcd1845$1@news.povray.org>
"Patrick Dugan" <pat### [at] netinsnet> wrote in message
news:3dcb12c3@news.povray.org...
I'd
be
> appreciated.
Not sure if that's a good idea, myself. Hazy air can be overused sometimes.
I think this looks nice and clean as is, like it's sitting out on a patio
outside instead of a closed space.
While looking at it here I couldn't help thinking that if I could see just a
little bit of a background landscape showing between the bamboo screen that
I'd feel more in the picture than out looking in. Just a thought. Not
anything but a little sky, vegetation, and building colors; with only very
slight hint of there being something back there. In fact, it almost starts
to look that way when I scrutinize it more. It's a fairly small image as
seen here.
Date: 9 Nov 2002 12:46:29
Message: <3dcd49f5@news.povray.org>
There is a little background behind the bamboo.  It is more noticeable in
the larger version.  I didn't want anything obviously behind it only the
hint to avoid detracting from the main focus.
"hughes, b." <omn### [at] charternet> wrote in message
news:3dcd1845$1@news.povray.org...
> I'd
extra
> be
> > appreciated.
sometimes.
a
that
> seen here.
