POV-Ray : Newsgroups : povray.binaries.images : Forewarning Server Time
4 Jun 2026 16:07:00 EDT (-0400)
  Forewarning (Message 11 to 12 of 12)
Subject: L-Space
Date: 26 Oct 2002 15:26:05
Message: <3dbaec4c@news.povray.org>
"In large libraries and other places where large numbers of books are
stored together the sheer weight of gathered knowledge bends time
and space around itself in complex and eye watering patterns.
This warping can in extreme cases result in wormholes leading
to other libraries or even the same library in a different
time or dimension.
"This is why most second hand book shops are bigger inside
than on the outside. Take the Barbican Bookshop in York,
for instance. Small shop on the outside, vast labrynth
of bookshelves on the inside."
For an in-depth discussion of this phenomenon (circa 1996), visit the
following link:
http://groups.google.com/groups?th=c8b2ebb6e773a096
Ken
Timothy R. Cook wrote:
> Daniel Matthews wrote:
>> That is assuming you're not sucked through to the other side as soon as
>> it is complete.
> Suck this. ;)
> Ray->Shape Intersection          Tests       Succeeded  Percentage
> Box                          502432001       357334763     71.12
> Cone/Cylinder                140178035        78139521     55.74
> CSG Intersection             152777125       122643021     80.28
> CSG Merge                     15264724         1740201     11.40
> CSG Union                       239055           15991      6.69
> Lathe                         61720447        36387822     58.96
> Lathe Bound                   61720447        51104445     82.80
> Plane                           239055           61826     25.86
> Prism                            39621            7379     18.62
> Prism Bound                     144525           90377     62.53
> Sphere                       106709368        87824381     82.30
> Torus                         19392109         1567811      8.08
> Torus Bound                   19392109         2245184     11.58
> True Type Font                    6527             298      4.57
> Bounding Box                6905669204      2457807325     35.59
> Vista Buffer                  16077378        10449927     65.00
> Roots tested:             81278451   eliminated:               81314
> Calls to Noise:         6779041568   Calls to DNoise:    13460988918
> Media Intervals:          90800514   Media Samples:       1130749414
> (12.45)
> Shadow Ray Tests:        158719338   Succeeded:             89317373
> Reflected Rays:              92835   Total Internal:           85049
> Refracted Rays:            2802968
> Transmitted Rays:           110137
> Number of photons shot:          30626
> Surface photons stored:        2736564
> Media photons stored:          3436608
> Priority queue insert:      4378500727
> Priority queue remove:      2731579279
> Gather function called:         585007
> Gather radius expanded:           2780
> Radiosity samples calculated:       3413 (0.87 percent)
> Radiosity samples reused:         388420
> Smallest Alloc:                 25 bytes   Largest:           327704
> Peak memory used:        161596764 bytes
> Time For Parse:    0 hours  0 minutes   6.0 seconds (6 seconds)
> Time For Photon:   0 hours  4 minutes  44.0 seconds (284 seconds)
> Time For Trace:    8 hours  9 minutes  39.0 seconds (29362 seconds)
>      Total Time:    8 hours 14 minutes  12.0 seconds (29652 seconds)
> CPU time used: kernel 15.56 seconds, user 27842.52 seconds, total
> 27858.08 seconds
> Render averaged 11.03 PPS over 307200 pixels
Subject: Re: Forewarning
Date: 26 Oct 2002 18:00:24
Message: <3DBB1077.7030305@faricy.net>
Very cool.  Where're all the ravers?  ;)
___     ______________________________________________
  | \     |_         website: http://davidf.faricy.net/
  |_/avid |ontaine           email: <dav### [at] faricynet>
