POV-Ray : Newsgroups : povray.binaries.images : Pretty photons Server Time
4 Jun 2026 17:43:49 EDT (-0400)
  Pretty photons (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Pretty photons
Date: 20 Oct 2002 13:08:17
Message: <3db2e300@news.povray.org>
Timothy R. Cook wrote:
> settings...default everything except for count which was 50000
> the glas has an IOR of 1.00001, caustics 1, dispersion 1.04, samples 50
> probably should turn off the caustics and tone down the dispersion
You should probably increase the count by a couple of magnitudes ;)
Date: 20 Oct 2002 13:29:07
Message: <3db2e7e3@news.povray.org>
Only problem is 50000 is the limit Moray has for photon count
Tim Cook
Version: 3.12
Date: 20 Oct 2002 13:43:16
Message: <3db2eb33@news.povray.org>
Really? That sounds strange, having tens of millions of photons in a scene
is not at all unusual. Perhaps someone should notify the author. If Moray
supports it, you could use spacing instead. Just remember that halving the
spacing value increases the surface photon count four-fold, and media
photon count eight-fold.
Date: 20 Oct 2002 13:47:25
Message: <3db2ec2d@news.povray.org>
Moray does support spacing, but it has both photon count AND photon
spacing, not either/or, and once you set photon count youc can't set
it back to 0.
Tim Cook
Version: 3.12
Date: 20 Oct 2002 14:10:16
Message: <Xns92ADCC4674DA7raf256com@204.213.191.226>
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in
news:3db2e7e3@news.povray.org
and what is the problem to hand-edit .pov code ?
Date: 20 Oct 2002 14:17:28
Message: <3db2f338$1@news.povray.org>
I hand-edit .pov code and later change something with Moray,
I have to re-hand-edit the code again.  My scene is not yet
finished, I consider lighting a finishing touch kinda thing.
Tim Cook
Version: 3.12
Date: 20 Oct 2002 15:07:35
Message: <3db2fef7@news.povray.org>
sing it with me:
D-I-S-C-O !   ;)
is this the library scene you wree working on a while back? cos it gets
better with every post.
jim
Date: 20 Oct 2002 16:15:20
Message: <3db30ed8@news.povray.org>
> remodelled the chandellier based on one that I have...it's not
> finished
Wow - thats cool :)
PGP Public Key
Version: 6.0.404 / Virus Database: 228 - Release Date: 15/10/2002
Date: 20 Oct 2002 17:07:29
Message: <3db31b11$1@news.povray.org>
The same.
 > cos it gets better with every post.
One would hope. ;)
Tim Cook
Version: 3.12
Date: 20 Oct 2002 17:45:29
Message: <3db323f9@news.povray.org>
news: 3db2f338$1@news.povray.org...
Hello,
I'm used to compose my scenes in Moray and hand edit code a lot as well.
I usually save the parts I edited -and want to keep so that- in separate
files.
Marc
