POV-Ray : Newsgroups : povray.binaries.images : old dog, new tricks.... Server Time
5 Jun 2026 00:40:25 EDT (-0400)
  old dog, new tricks.... (Message 31 to 40 of 40)
Subject: A true THOMAS-Network cards !
Date: 8 Sep 2002 03:17:09
Message: <3d7af975$1@news.povray.org>
A true THOMAS -Network - Card !
Maybe it will not often make connections to other network-cards cause it
can't believe their data :-).
However, this is the most realistic looking POV-Rendering (together with
Jaimes Apples)
I've ever seen.
Maybe there is something artificial even missing .... to contrast a normal
photography.
--Theo
Distributed Network-Rendering or Local SMP-Rendering on all CPU's you have.
With SMPOV und POV-Ray 3.5. Download free at:
http://www.it-berater.org/smpov.htm
Subject: Re: old dog, new tricks....
Date: 8 Sep 2002 04:31:15
Message: <3d7b0ad3$1@news.povray.org>
Jaime Vives Piqueres wrote:
>   Yes, Christoph pointed it out in other reply. Now I understand why
> the loading rad data works so fast: because I use "always_sample
> off". Well, actually it also helps using a very small image for the
> saving-rad scene (about 30% of the final render).
Will have to try that next time round
PGP Public Key
Version: 6.0.385 / Virus Database: 217 - Release Date: 04/09/2002
Subject: Re: A true THOMAS-Network cards !
Date: 8 Sep 2002 05:16:55
Message: <3d7b1587$1@news.povray.org>
> it can't believe their data :-).
> with Jaimes Apples)
> I've ever seen.
> normal photography.
I think the reason it looks so real is the simple subject matter (as you see
from the model, there isnt really much to it) and the texture, lighting &
focal blur which in this instance make the scene work.
After doing this the first time round I pretty much decided that where ever
possable (for 'real world' objects) I would use 'real world' texture maps
and a flat bed scanner seems the best tool for getting them where ever
possable.
Oh, and focal blur hides a multitude of sins, really brings new meaning to
the term 'if you wont see it, dont model it!' well worth the increased
render time.
On a final note, I wouldn't have fancied doing this without Moray, without
which positioning all those little blocks for the mounted components would
have taken significantly longer.
PGP Public Key
Version: 6.0.385 / Virus Database: 217 - Release Date: 05/09/2002
Date: 8 Sep 2002 08:35:17
Message: <3d7b4405@news.povray.org>
news:3d7b1587$1@news.povray.org...
    Odd... I wouldn't have fancied doing it _with_ Moray, with which
positioning all those little block for the mounted components would have
taken _me_ significantly longer.
Pandora/Scott Hill/[::O:M:C::]Scorpion
Software Engineer.
http://www.pandora-software.com
Date: 8 Sep 2002 11:58:35
Message: <3d7b73ab@news.povray.org>
> have taken _me_ significantly longer.
Place the texture as a viewpoint bg image, and copy paste little blocks into
place, it took 2 mins to position all the surface mounted components
perfectly.
PGP Public Key
Date: 8 Sep 2002 13:09:21
Message: <3d7b8441@news.povray.org>
news:3d7b73ab@news.povray.org...
into
> perfectly.
    AH! Well, I don't use Moray, so wouldn't have thought have doing that
and would've spent days trying to get everything into the right place...
    Though I'd have done something similar if I'd have done it by hand -
load the image into an image editor and jot down the position and size, in
pixels, of each component and then would probably have created the card
object in POV so that one pov-unit was equal to on pixel on the image...
Software Engineer.
Date: 8 Sep 2002 23:43:44
Message: <3d7c18f0$1@news.povray.org>
. . . and a very nice old dog it is too. Well done.
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Date: 9 Sep 2002 09:44:38
Message: <Xns928495EF6E9Eveentukibmcom@204.213.191.226>
"Rick [Kitty5]" <ric### [at] kitty5com> wrote in
news:3d793b99@news.povray.org:
> Needed another render of the 3com network card I did ages ago, this
> time with focal blur, 2 area lights and a touch of rad. tweaked the
> scene slightly and altered a lot of the settings for 3.5 (old was done
> with MP)
> end
Very nice indeed, I remember when I saw you first image months ago a I
wanted to do one similar of the card I have been developing at work, but I
never came round doing it. Good stuff!
Date: 9 Sep 2002 09:45:53
Message: <3d7ca611@news.povray.org>
> that and would've spent days trying to get everything into the right
>     place... Though I'd have done something similar if I'd have done
> it by hand - load the image into an image editor and jot down the
> position and size, in pixels, of each component and then would
> probably have created the card object in POV so that one pov-unit was
that sounds like to much hard work!
PGP Public Key
Date: 9 Sep 2002 13:40:39
Message: <3d7cdd17@news.povray.org>
Excellent work, Rick. Inspiring...
    ~Steve~
