POV-Ray : Newsgroups : povray.binaries.images : Odd blur effect: squared spheres Server Time
17 Oct 2026 06:04:26 EDT (-0400)
  Odd blur effect: squared spheres (Message 1 to 25 of 25)
Subject: Odd blur effect: squared spheres
Date: 27 Aug 2002 05:57:31
Message: <3d6b4d0b@news.povray.org>
Currently I am rendering a large version of a dice image. The dice points
really get angularly. Does anyone know why?
Thanx,
Rene
Rene Schwietzke
r.schwietzke<at>reneschwietzke.de
Download 'blur.jpg' (24 KB)
Preview of image 'blur.jpg'
Subject: Re: Odd blur effect: squared spheres
Date: 27 Aug 2002 06:50:40
Message: <3D6B59A8.3070709@free.fr>
Rene Schwietzke wrote:
> Hi,
Dive in the source code (unless it is documented ?),
the blur code as some magic values on blur_sample IIRC which
use an hexagonal grid instead of square grid. At least, it was
in 3.1 ...
Other solution might be to increase the blur_sample,
or reduce the variance or increase the confidence.
 Go read section 6.4.3 of the help (pov 3.5)
Date: 27 Aug 2002 08:29:14
Message: <3d6b709a@news.povray.org>
I found three constants in the help about Hex_Blur, might be related but the
camera SDL does not allow any additional settings.
Hex_Blur1 = 7
Hex_Blur2 = 19
Hex_Blur3 = 37
My settings are:
blur_samples 150
variance 0
confidence 0.9999999
Any ideas? Your assumption seems to be right...
Rene
"Le Forgeron" <jgr### [at] freefr> wrote in message
news:3D6### [at] freefr...
> in 3.1 ...
Date: 27 Aug 2002 12:37:32
Message: <3d6baacc@news.povray.org>
AFAIK the focal blur is achieved by scattering the camera location
point in a rectangular area, while maintaining the focal point the
same. The size of this area is determined by the aperature keyword.
Date: 27 Aug 2002 13:30:22
Message: <3d6bb72e@news.povray.org>
Shouldn't it be a circular area for realism?
 - Slime
[ http://www.slimeland.com/ ]
Date: 27 Aug 2002 14:05:30
Message: <3d6bbf6a$1@news.povray.org>
"Slime" <slm### [at] slimelandcom>
correct ...
either that or you can start modelling complex shapes for a
probability model. Meaning, you support a greyscale bitmap
where black says "no here won't get a ray shooten from" and
white means that from here will get a ray shooten with the
highest probability.
This would allow you to form flare shapes as they sometimes
appear in photography; think of hexagonal or triangular ones.
The problem would be, that it will even slower to determine
the point.
Date: 27 Aug 2002 15:10:37
Message: <3d6bcead@news.povray.org>
"Rene Schwietzke" <ren### [at] reneschwietzkede> a écrit dans le message de
news: 3d6b4d0b@news.povray.org...
See this page
http://www.kenrockwell.com/tech/bokeh.htm
There's a patch that implements this in POV-Ray that is currently being
ported to 3.5 (it's under testing and not available yet). From what I heard
it's faster that the regular focal_blur but I have not verified this myself.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 27 Aug 2002 15:24:54
Message: <3d6bd206$1@news.povray.org>
> correct ...
I don't think that's correct actually...
> the point.
True, but I would be happy with the possibility to choose between a circular
area and an area in the shape of a regular polygon.
I was trying to do focalblur by averaging different renders earlier this day.  I
came up with the following formula to scatter points inside a regular polygon:
  #declare Seed=seed(whatever);
  #declare angles=<insert number of angles here>;
  #declare Rot=360*rand(Seed);
  #declare X=pow(rand(Seed),.5);
  #declare Rot2=Rot/(360/angles);
  #declare fraqrot=Rot2-int(Rot2);
  #declare fraqrot2=abs(fraqrot-.5);
  #declare fraqrot3=pow(fraqrot2*2,.5);
  #declare Location=vrotate(x*X*(.8+.2*fraqrot3),Rot*z);
This produces a random point within a regular polygon inside a circle with
radius 1 (I think, could be that it's a bit outside that circle...) (more or
less, it's not a perfect polygon, and it needs more than 3 angles to look like a
polygon)
cu!
Date: 27 Aug 2002 16:06:48
Message: <3d6bdbd8@news.povray.org>
probably right....
but please compare these lines to the simple way of determing a single point
in an rectangle concerning the time it takes to compute it ...
... and then take into account, that this has to been done multiple times
per pixel ... Maybe its ok to precompute ~2^10 such values and store them
in a table, so you can reuse them later ... but I'm not sure this will help
Date: 27 Aug 2002 16:17:34
Message: <3d6bde5e@news.povray.org>
day.  I
polygon:
> probably right....
Yes, a rectangle, or a circle, will be faster, that's why you should have the
option to use a circle (or a rectangle, but I don't think that would give
realistic results actually).
cu!
Date: 27 Aug 2002 16:25:22
Message: <3d6be032$1@news.povray.org>
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> schrieb im Newsbeitrag
news:3d6bde5e@news.povray.org...
> day.  I
> polygon:
> > probably right....
point
help
the
why not just make a circular pattern by generating the Points like before
in a rectangular area and then testing  [x^2+y^2 > Radius] for the Point
to find out if it lies in the Circle. If the Condition is True, just generate
another Point until it's inside the Circle. This is a common and fast way to
get circular Points.
Greetings,
Thies
Date: 27 Aug 2002 16:28:14
Message: <3d6be0de$1@news.povray.org>
> Hi,
Because in real life, it aren't perfect circles, but regular polygons.  So it
would be better if POV-Ray had an option to use regular polygons instead of
perfect circles.  That in combination with non-clipped focal blur, would allow
us to create realistic focal-blurred images.
cu!
Date: 28 Aug 2002 01:54:14
Message: <j8pomug7b9itfc8scj99fka5vko9gdfnf3@4ax.com>
On Tue, 27 Aug 2002 21:10:30 +0200, "Gilles Tran" <git### [at] wanadoofr> wrote:
Who does it ? French community again ?
ABX
Date: 28 Aug 2002 02:15:19
Message: <3d6c6a77$1@news.povray.org>
Interesting. Please keep us updated.
Rene
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3d6bcead@news.povray.org...
heard
myself.
Date: 28 Aug 2002 05:09:51
Message: <3d6c935f@news.povray.org>
"ABX" <abx### [at] abxartpl> a écrit dans le message de news:
j8pomug7b9itfc8scj99fka5vko9gdfnf3@4ax.com...
Yes, it's the patch by Mael (it also contains finish maps, HDRI support and
a whole lot of goodies). Unfortunately he has removed it from its location
but when he has something clean to show he'll tell us.
G.
- Posters
Date: 28 Aug 2002 05:20:25
Message: <3D6C95D9.F79F18BF@gmx.de>
I really wonder why, most of the patches were already in a previous
version so i suppose they are quite well tested.  The projection pattern
looked really interesting.
Date: 28 Aug 2002 08:27:24
Message: <3d6cc1ac$1@news.povray.org>
they were in a previous version but not really tested (and they still are not
for those who want to try my current patched pov3.5 you can download this file
http://195.221.122.126/tmp/mlpov08.zip (1.7 Mo, windows exe only, compiled
with vc6 so probably slower than official version)
extract in your pov3.5 directory and run the mlpov.exe
for documentation (in french) click the mlpov button next to 'irtc site'
button
this version includes :
-aoi : new pattern , angle between incident ray and normal
-projection : new pattern, projection of an object
-shadow_pigment : to colorize shadows
-bokeh_pigment : for a customizable focal blur
-synthese : to create a new image_map from a sample image
-finish maps : to specify a function for finish parameters
don't forget to add
#version unofficial mlpov 0.8;
in your scene to test the patches.
M
Date: 28 Aug 2002 08:52:00
Message: <3D6CC770.BD2FAEC6@gmx.de>
> button
I have already downloaded this, but it would be much better if i was able
to use it on my linux box.  Also if you supply the source code it would be
likely that possible problems with the implementation are discovered in
case you don't have the time to test it in detail.
Date: 28 Aug 2002 09:07:39
Message: <3d6ccb1b$1@news.povray.org>
i'm still doing some experimentations with the code, but may be later i will
try to compile a version for linux
you can download the modified sources here
http://195.221.122.126/tmp/sources08.zip
(if you're not too afraid to look at my ugly code :)
M
Date: 28 Aug 2002 09:23:58
Message: <Xns92789D5C9E218seed7@povray.org>
Mael,
Thanks for the patch, I'm especialy facinated with the sythese and
ofcourse I want always more. Would it be possible to use that kind of
algorithem in 3D-space? Randomly picking small cubes from a unit cube
and build a new pattern from there, in SDL something like:
    	bozo
    	warp {synthese, BlockSizeVector, RandomStream}
Ingo
p.s. Good documentation!
Would have been even nicer if it was in dutch ;)
Date: 28 Aug 2002 09:44:18
Message: <3d6cd3b2$1@news.povray.org>
the current synthese algorithm needs to build the entire new image_map before
using it, You have to tell you want a 500x500 new image, it computes it, and
then uses it. This algorithm can't find a value at a random (x,y) point
directly. (And the construction is quite slow so if you want to use it it's
better to create the image, save it, and use it as a normal image_map)
so in 3D it would be possible but the result would be pre-computed values on a
3D grid (voxels) of a given size
thanks, i writed it in docbook xml format and used some modified .xsl to try
to match the povray documentation :)
M
Date: 28 Aug 2002 10:05:37
Message: <3D6CD8B1.BA46A08B@gmx.de>
Thanks, that should be perfectly sufficient, no need for a compiled
version, like most linux users i prefer doing my own compile anyway.
BTW, what's 'BRDF_PATCH', is it not in the compiled windows version or is
it just not documented yet?
Date: 28 Aug 2002 10:06:48
Message: <3D6CD8F0.DFADBAA@gmx.de>
Sounds interesting and might be suited for a general patch documentation
system (i suppose it does not require tools that are not freely
available).
If you could write some short tutorial about the steps used to generate it
that would be great.
Date: 28 Aug 2002 10:07:17
Message: <Xns9278A4B4C2EFBseed7@povray.org>
> values on a 3D grid (voxels) of a given size
Was afraid that that would be the awnser,
Thanks,
Ingo
Date: 28 Aug 2002 10:11:21
Message: <3d6cda09$1@news.povray.org>
it's not in the compiled windows version because it's a work in progress, i'm
doing some tests writing BRDF stuff (for anisotropic highlights for example,
or to give a local micro-geometry and computes the resulting BRDF) (it really
needs lot of work...)
M
