I've been trying to use cylinder lights to create a search-light effect,
using atmospheric media. I have noticed that the end of the cylinder light
shows as a black disk, rather than just 'running out'.
Is this normal? Can I stop this?
thanks
Mark
Download 'sample.jpg.dat' (39 KB)
Your image isn't showing Mark. At least for me that is...
~Steve~
Subject: Re: Cylinder lights have a black end-cap?
Date: 18 Aug 2002 16:03:58
Message: <3d5ffdae@news.povray.org>
I had this problem too but I vaguely remembered this cropping up before and used a
tight cone instead.
Mick
Ingo
In article <3d5ff521@news.povray.org>,
This probably has something to do with how intervals are split up to
optimize rendering for spotlights and cylinder lights and the fact that
your media is infinite. Simple answer: don't use atmospheric media, use
some kind of comtainer.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
oops. Sorry...
"ingo" <ing### [at] home nl> wrote in message
news:Xns### [at] povray org...
> Ingo
But wouldn't this start as a point? I need a visible diameter at the lamp
end of the beam.
Ideally I wanted a spotlight, but couldn't see how to make the start of it
wide enough.
Mark
"Mick Hazelgrove" <mic### [at] mhazelgrove fsnet co uk> wrote in message
news:3d5ffdae@news.povray.org...
and used a tight cone instead.
> Mick
Hmmm,
I just tried a sphere{0,15 interior{media{...}}} instead of atmospheric
media, with the same problem
Mark
PS
here is the media
sphere{
0, 20
interior{
media {
intervals 10
samples 1,1
confidence 0.9
variance 1.0/128
ratio 0.9
scattering {
1,
rgb<0.05,0.05,0.05>
method 3
hollow
"Christopher James Huff" <chr### [at] mac com> wrote in message
news:chr### [at] netplex aussie org...
light
> http://home.earthlink.net/~cjameshuff/
in news:3d600212$1@news.povray.org Mark Hanford wrote:
> sphere{
> 0, 20
put a transparent pigment here
> interior{
or else you'll se the container object with the default (black) texture.
Ingo
Thanks Ingo, got it now.
~Steve~
> Ingo
It's outside an opaque sphere{0,15 texture{...}}, but I'll put it in anyway
to stop the warning
> > sphere{
> > 0, 20
> > interior{
> Ingo
"Mark Hanford" <mar### [at] the internet com> wrote in message
news:3d6000c7$1@news.povray.org...
> end of the beam.
> wide enough.
I may be wrong here, but couldn't you just move the cone back until the
desired diameter is met with the inner rim of your lamp? Would this work?
~Steve~
> Mark
> > Mick
On Sun, 18 Aug 2002 20:27:38 +0100, "Mark Hanford"
A similar problem has been reported in early July by Rohan Bernett.
Maybe it's worth investigating deeper.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
Date: 18 Aug 2002 17:37:55
Message: <3d6013b3@news.povray.org>
Okay, thanks for the input, here's another sample that shows what I think is
odd behaviour:
Am I right in assuming that my light beam will be no bigger than Beam_Width?
If that is the case (and even if not, I think) then the bottom of the beam
is enclosed entirely by the shade, and so the black shadow should be
covered, no?
This was supposed to be a simple scene to fill in the beginning of a movie
we made :( This light stuff is really stumping me.
The actual lamp part of the image is:
#declare Beam_Width=0.06;
#macro FloodLight(Direction, Position)
union{
cylinder{0, Beam_Width*1.1*y, Beam_Width*1.1}
sphere{0, Beam_Width*1.1}
rotate Direction
translate Position
texture{Tex_Base}
no_shadow
light_source{
0 color rgb <0.7, 0.7, 1>*15
cylinder
point_at 10*y
radius Beam_Width*0.9
falloff Beam_Width
tightness 0
rotate Direction
translate Position}
Download 'sample.jpg' (3 KB)
Preview of image 'sample.jpg'
If it helps, I can post the scene in the relevent (p.t.s-f or p.b?) group...
"Peter Popov" <pet### [at] vip bg> wrote in message
news:7n40mucvb653or3ljh0lr7u953qu6rs34b@4ax.com...
light
Date: 18 Aug 2002 17:48:57
Message: <3d601649@news.povray.org>
Oh, and I've just noticed that even if the whole bunch of objects
(beam+shade) is well behind another object, the black disk still sometimes
shows infront, so it's not just objects which the beam terminus is "inside".
M
news:3d6014cb$1@news.povray.org...
group...
effect,
> light
In article <3d600212$1@news.povray.org>,
Looking at some of the other messages, it looks like this isn't the
problem, though it could be something else related to media handling of
cylinder lights. I'm not sure what is wrong...
