POV-Ray : Newsgroups : povray.binaries.images : Photons and media Server Time
15 Aug 2024 04:19:35 EDT (-0400)
  Photons and media (Message 1 to 5 of 5)
Subject: Photons and media
Date: 9 Aug 2002 20:04:28
Message: <3d54588c@news.povray.org>
Content-Transfer-Encoding: 8Bit
I played around a bit with photons and I wonder why the following picture
does not contain any (colored) rays from the diamond into the media.
The color dispersion in this images seems to contain just a few colors and
no smooth color transitions.
Does someone know what causes these effects and how to make it look more
realistic?
Thank You,
Hans
P.S.:
Yes, I know, it looks terrible...
Download 'us-ascii' (100 KB) Download 'us-ascii' (2 KB)
Subject: Re: Photons and media
Date: 10 Aug 2002 03:37:28
Message: <Xns9266614C9D6DFraf256com@204.213.191.226>
Johann Uhrmann <juh### [at] fh-landshutde> wrote in
news:3d54588c@news.povray.org
> --nextPart1312712.W6geO5KgaW
> Content-Transfer-Encoding: base64
> Content-Disposition: attachment; filename="photon.jpg"
> /9j/4AAQSkZJRgABAQEASABIAAD//gAXQ3JlYXRlZCB3aXRoIFRoZSBHSU1Q/9sAQwABAQE
> BAQEB
> AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQE
something is wrong with this attachment
Date: 10 Aug 2002 17:20:29
Message: <3d55839d@news.povray.org>
"Johann Uhrmann" <juh### [at] fh-landshutde> wrote in message
news:3d54588c@news.povray.org...
Hi there Johann,
Same as 'Raf256', I couldn't see your attached image (maybe that "8-bit"
encoding?). Might have been better to post each part at their respective
places here at the newsgroups, namely image file here, pov file to
povray.text.scene-files (the text in message). Regardless....
....I rendered your script and puzzled over it a while. Found that I could
not get photons in the media other than from the spotlight. When I made a
box to act as media container and room the reflecting photons showed up in
the media, not when only open air media was used.
The photon mapping was working okay showing on the ground, just not in
media, before making that change. I did need to increase the light source
color above one to see it good enough. If the transmit 0.95 is changed to
1.2 that also brightens it up but probably not always okay to do that.
I really wonder about that problem of the missing photons in media if it
isn't enclosed, something either not right or I missed a reason for it. I
won't say it's a bug unless others find likewise.
Now, about that dispersion. Reason that looked sharp-edged for you I guess
is because the default of 7 colors was used, so adding a dispersion_samples
14 would double that.
About that media again. I was surprised to find how the box container
addition slowed it down terribly. I couldn't seem to speed it back up to
it's original render-time, maybe something to do with the previously missing
media photons and now it shows all bouncing around from reflection and
refraction. Still was much, much slower than I'd have expected. So slow in
fact I quit trying to check on it.
Only half helpful perhaps.
Date: 10 Aug 2002 21:41:15
Message: <Xns926724E96FBC6raf256com@204.213.191.226>
"hughes b" <omn### [at] charternet> wrote in
news:3d55839d@news.povray.org
> Hi there Johann,
> Same as 'Raf256'
thanks ;)
> "8-bit" encoding?). Might have been better to post each part at their
> respective places here at the newsgroups, namely image file here, pov
> file to povray.text.scene-files (the text in message). Regardless....
try (in Xnews it works)
no content-transfer-encoding selected
no Conntent-type selected
Mime-Version 1.0
Attachments : Use MIME - ye
Date: 12 Aug 2002 16:56:17
Message: <3d5820f1@news.povray.org>
hughes b wrote:
> Hi there Johann,
> encoding?).
Well, sorry for that unreadable attachment. I switched 8-bit-encoding off -
hope this will fix it.
Maybe this problem is from the same type as those "no laser effect"-threads
I just discovered.
> dispersion_samples 14 would double that.
Thanks for that hint :)
> missing media photons and now it shows all bouncing around from reflection
> and refraction. Still was much, much slower than I'd have expected. So
> slow in fact I quit trying to check on it.
I guess, I will try it anyway. Using a linux-cluster should speed it up a
bit.
Speaking of clusters: Currently, I am using shell scripts to distribute the
load. Unfortunately, this does not speed up the photon map creation. Has
someone an idea how to parallelize photon maps?
It was all the help I hoped for ;)
Thank You,
Hans
