Someone was asking a while ago about creating repeatable patterns in POV. I
think I have come up with a manageable solution without resorting to
mirroring the pattern.
The attached images are of heightfields generated using the method tiled
together. HF1 is just the hf with the image_map, HF2 highlights the the
individual hfs. HF3 shows a closeup at the corner seam of 4 hfs.
Comments/questions/problems (before I post the source).
-tgq
Download 'HF1.JPG' (66 KB)
Download 'HF2.JPG' (65 KB)
Download 'HF3.JPG' (34 KB)
Preview of image 'HF1.JPG'
Preview of image 'HF2.JPG'
Preview of image 'HF3.JPG'
On Tue, 30 Jul 2002 13:08:28 -0400, "TinCanMan" <Tin### [at] hotmail com>
How much memory use this detailed hf ? Have you tried the same function as
isosurface ?
ABX
for the close-up (HF3) (P4, 1GHz, 256RAM, Win2000):
Statistics for C:\Raytracing\POVRay\scenes\ddd.pov, Resolution 512 x 384
Pixels: 196608 Samples: 277841 Smpls/Pxl: 1.41
Rays: 348820 Saved: 70979 Max Level: 1/250
Ray->Shape Intersection Tests Succeeded Percentage
Height Field 629008 277892 44.18
Height Field Box 629008 629008 100.00
Height Field Triangle 2276187 278167 12.22
Height Field Block 1486076 836575 56.29
Height Field Cell 13307907 1231203 9.25
Bounding Box 866794 725805 83.73
Light Buffer 2457879 1305287 53.11
Vista Buffer 1578723 1365287 86.48
Calls to Noise: 0 Calls to DNoise: 10
Shadow Ray Tests: 275194 Succeeded: 0
Reflected Rays: 70979
Smallest Alloc: 25 bytes Largest: 98352
Peak memory used: 6013674 bytes
Time For Parse: 0 hours 0 minutes 1.0 seconds (1 seconds)
Time For Trace: 0 hours 0 minutes 9.0 seconds (9 seconds)
Total Time: 0 hours 0 minutes 10.0 seconds (10 seconds)
CPU time used: kernel 0.16 seconds, user 9.67 seconds, total 9.83 seconds
Render averaged 19992.39 PPS over 196608 pixels
POV-Ray finished
> isosurface ?
No, not yet.
-tgq
On Tue, 30 Jul 2002 13:22:54 -0400, "TinCanMan" <Tin### [at] hotmail com>
Hmm, where is hole in my knowledge? Why bounding box can be 83.7%. Is bounding
box for hf only considered or something else ?
> > isosurface ?
> No, not yet.
But You will ? :-)
Nice images, btw.
ABX
> > > isosurface ?
> > No, not yet.
> But You will ? :-)
It doesn't seem to be translating well to an isosurface, perhaps my brain
isn't functioning to well today.
> Nice images, btw.
Thanx
-tgq
I really like the first one and would like to try and animate it. Could you
let me/us know when you post the code?
thanks much,
D.
"TinCanMan" <Tin### [at] hotmail com> wrote in message
news:3d46c824@news.povray.org...
I
> -tgq
Scenes to be posted shortly in p.b.s-f
-tgq
BTW, if you didn't notice, the actual hf was only the size of 1 of the
checker squares and was tiled.
> isosurface ?
I think I may have figured it out, but render times are horrendous compared
to HF.
-tgq
It seems greatly improved if I use the funtion image pattern (6.7.11.16
Function Image) for the hf (internal) rather than a separately processed hf
image.
With external hf image, 512x384:
Peak memory used: 2297685 bytes
With internal hf image, 512x384:
Peak memory used: 902579 bytes
For some reason, the pattern comes out different for each of the two methods
(though they appear equal in their scales, randomness). Perhaps something
different in the way the noise used to calculate the pattern is perceived?
-tgq
I've found that the "pattern image function" will
switch up and down of an image. It uses the
section from <0,0,0> to <1,1,0>, and <1,1,0>
will be, on a heightfield, the foremost right
corner, when looking from -z towards z.
(Hope that explains something... Think about it)
So, in effect, you might be using different
parts of your pattern (not the y-planar
<0,0,0> to <1,0,1>, but the z-planar), or
its used upside down. Don't know for sure though.
Tim Nikias
Email: Tim### [at] gmx de
"Tim Nikias" <tim### [at] gmx de> wrote in message
news:3d480dce@news.povray.org...
Yes, that was it. I found another little phenomenon. The attached images
(sorry for the terrible jpg artifacts) show hfs of the same function.
TPGenTestE.JPG uses an external hf image whereas TPGenTestI.JPG uses the
internal type, both at the same res (512x384). As can be seen, the lumps in
the internal one have a much sharper, less rounded shape. Do they interpret
the input image differently or perhaps the "pattern image function" uses a
different waveform.
-tgq
Download 'TPGenTestI.JPG' (57 KB)
Download 'TPGenTestE.JPG' (59 KB)
Preview of image 'TPGenTestI.JPG'
Preview of image 'TPGenTestE.JPG'
Another little phenomenon that I found out:
When creating a hf from an image with res m*n, the hf has a res of
(m-1)*(n-1), ie. each pixel represents a vertex on the hf (this is mentioned
in "6.5.1.5 Height Field"), this requires the input image I use to need an
"extra" row and column of pixels to join seamlessly. However, with the
"function image pattern", this is not necessary.
-tgq
In article <3d481ce5@news.povray.org>,
> different waveform.
Gamma correction of the external image? Maybe something with the
color_map or waveform you used to generate the external image?
Christopher James Huff <chr### [at] mac com>
POV-Ray TAG e-mail: chr### [at] tag povray org
There it is, it was because my display_gamma was set to 1.8 in my .ini
-tgq
