POV-Ray : Newsgroups : povray.binaries.images : ACE (179 KB) Server Time
17 Oct 2026 10:54:21 EDT (-0400)
  ACE (179 KB) (Message 1 to 18 of 18)
Subject: ACE (179 KB)
Date: 24 Jul 2002 16:04:00
Message: <3d3f0830@news.povray.org>
Just a quick test with my brand new copy of POV-Ray 3.5. The juice looks more like
tea, I know, I should have used scattering media, but I didn't have the time to play
with its settings, I had to turn back to my quantum physics...
It took me more or less 30 minutes to code and 2 hours and 25 minutes to render on an
Athlon 1 Ghz 384 MB.
Cheers,
Jonathan.
Download 'ace.jpg' (180 KB)
Preview of image 'ace.jpg'
Subject: Re: ACE (179 KB)
Date: 24 Jul 2002 18:15:47
Message: <3d3f2713@news.povray.org>
How dare you make me feel so inept again! I hate you, Gilles Tr... oh,
wait... it's JRG... wow... Bellissimo! :)
PS: I don't hate you, Gilles, I just admire and envy you. ;)
Date: 24 Jul 2002 20:52:48
Message: <3D3F4B61.3000104@videotron.ca>
an
I think you deserve an "AWSOME ROLLEX!!!1!" for that.
Date: 24 Jul 2002 21:58:44
Message: <3d3f5b54$1@news.povray.org>
Jonathan,
Great image! Are you still working on your kitchen items? Your renders have
such reality--a call for a tutorial to help the rest of us!
Jack
Date: 24 Jul 2002 22:59:45
Message: <3d3f69a1$3@news.povray.org>
kitchens without roaches --> not real. I know many people with fake
kitchens.
never mind. This is absolutely ROLEX-worthy.
Date: 25 Jul 2002 06:19:41
Message: <3D407963.8000401@chesapeake.net>
JRG wrote:
> The juice looks more like tea
> Jonathan.
So just change the lable to one for tea. :)
Date: 25 Jul 2002 11:26:39
Message: <3d4018af@news.povray.org>
Are those very small white blotches at the bottoms of the two closest
bottles radiosity artifacts?
And them bottles are a little bit distorted by the perspective. I had the
same problem with http://24.132.254.155/experiments/redpieces.png, so I
changed the camera in such a way there is absolutely no perspective left.
With that problem the pyramids at the left and the right were extremely
distorted and almost pointing to the sides.
Date: 25 Jul 2002 12:39:24
Message: <3d4029bc$1@news.povray.org>
Jack wrote:
> Your renders have such reality
I agree that Jonathan uses a great setup of light and reflections! The
textures impress me, and the window reflecting on the yellow plastic is much
more interesting than the usual round highlights. I never got that to work.
The render time is very low considering what is going on. I'd like an
explanation too.
Hugo
Date: 25 Jul 2002 17:04:44
Message: <3d4067ec@news.povray.org>
wow this is much of a compliment. :o)
Jonathan.
Date: 25 Jul 2002 17:07:12
Message: <3d406880$1@news.povray.org>
Whoa, compliments like this make your day happier...
Jonathan.
Date: 25 Jul 2002 17:22:20
Message: <3d406c0c@news.povray.org>
"Hugo" <hua### [at] post3teledk> ha scritto nel messaggio
news:3d4029bc$1@news.povray.org...
Oh that's easy: just add an ambient 20 sky inside the one used for the global
illumination and put the no_image flag into it (otherwise the pic will look, hum,
*burnt*).
> explanation too.
I didn't use very high radiosity settings.
But the trick is another one: you all know indoor pure radiosity scenes are awfully
hard to get good, usually because the skylight has very little room to pass through
(a window or a door for instance), and you need very high settings but things don't
look good either...
What I do here (and what I did elsewhere) is to add the no_image flag to the wall
where the window is... it looks right, it doesn't need damn high settings hence the
low render time. :-)
Hopefully I was clear enough, otherwise I can post the source if asked so.
Jonathan.
Date: 25 Jul 2002 17:29:01
Message: <3d406d9d@news.povray.org>
> kitchens.
Roaches?! Poor little kid, what do my ears have to hear? Do bad men make you work
there?
<j/k> :-)
Thanks!
Jonathan.
Date: 25 Jul 2002 17:49:51
Message: <3d40727f$1@news.povray.org>
> no_image flag to the wall where the window is... it looks
Thanks! I just read in the POV docs about the no_image keyword, because it
seems strange to me that this should work any different than having a real
wall to block the light.
From what I understand, the faked wall will actually emit a strong light
(because of ambient 20) but it isn't visible to the camera, only radiosity
reacts to it.. And perhaps objects with reflection reacts to it also, in
which case these objects will need uncommon finish statements.
Sounds strange that this should allow for lower settings for radiosity.
I'll experiment when I get the time.
You are welcome to post an example.
Hugo
Date: 25 Jul 2002 18:09:47
Message: <3d40772b@news.povray.org>
Excuse my bad explanation.
Let's try again: :o)
first of all, keep in mind that no_image objects do not affect radiosity. This means
that I use the no_image flag because I don't want the object to affect radiosity yet
I want it to be visible through the reflections.
That said:
I don't use ambient 20 with the wall. I use it with a sphere, which I put inside the
*real* sky_sphere. Ambient 20 would mess up my radiosity setup, so I also use the
no_image flag in order to make this sky only visible through the reflections. It is
this very bright sky which causes those nice window highlights on the reflective
objects. Of course you also need another skysphere in order to light the scene.
As for the wall, I use the no_image flag so that the scene is lit just as if the wall
were not there. You see the wall in the reflections (actually the drawback is that it
is completely black) but it doesn't affect radiosity, and the skylight has so much
more room to pass through. This is the key: the no_image wall does _not_ block the
light.
Jonathan.
Date: 25 Jul 2002 19:10:01
Message: <3d408549@news.povray.org>
Done. Posted to p.b.s-f.
Jonathan.
Date: 25 Jul 2002 19:15:28
Message: <3d408690$1@news.povray.org>
Thanks!  I got it now!
I'm experimenting now.  :o)
Also thanks for posting an example!
Hugo
Date: 26 Jul 2002 01:11:02
Message: <3d40d9e6$1@news.povray.org>
I like this image, except for the perspective distortion.
I particularly like the highlights and the subtle wrinkling at the edges of the
labels. Nice touch!
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Date: 28 Jul 2002 06:12:33
Message: <Xns925920AEBDDA7hookflash7@204.213.191.226>
"JRG" <jrg### [at] hotmailcom> wrote in news:3d3f0830@news.povray.org:
> looks more like tea, I know, I should have used scattering media, but
> I didn't have the time to play with its settings, I had to turn back
> to my quantum physics... It took me more or less 30 minutes to code
> and 2 hours and 25 minutes to render on an Athlon 1 Ghz 384 MB.
> Cheers,
> Jonathan.
> Attachment decoded: ace.jpg
> end
Awesome!  I really think you guys ought to start posting these sorts of
images to some of the popular CG forums (cgtalk.com, cgchat.com, etc.).  It
would help to promote PovRay, and maybe even humble some of the
finalRender/Brazil/etc. fanatics.
