POV-Ray : Newsgroups : povray.binaries.images : My dorm room... Server Time
17 Oct 2026 14:31:23 EDT (-0400)
  My dorm room... (Message 1 to 18 of 18)
Subject: My dorm room...
Date: 2 Jun 2002 19:59:20
Message: <3cfab158@news.povray.org>
...but it's never this clean.  I just made a quick model for the purposes of
planning out some decorations for next year and did some radiosity
experiments with it.  If it looks a bit distorted it's because of the camera
angle (120 degrees) wanted to get the bunk, desk, and window in the same
shot.
Skip
Download 'room1.jpg' (63 KB)
Preview of image 'room1.jpg'
Subject: Re: My dorm room...
Date: 2 Jun 2002 20:50:58
Message: <3cfabd72$1@news.povray.org>
How's the real room? Is this POV version like the real one?
Apache
POV-Ray Cloth experiments: http://geitenkaas.dns2go.com/experiments/
Email: apa### [at] yahoocom
ICQ: 146690431
Date: 2 Jun 2002 21:18:47
Message: <3CFAC3F2.3030504@bellsouth.net>
Looks familiar.  Almost exactly the same as a dorm room I've been in...
Tim Cook
Version: 3.12
Date: 2 Jun 2002 21:43:26
Message: <3cfac9be@news.povray.org>
Well, I took a tape measure to every major detail around the room so the
actual model is very precise.  The wood textures are straight out of
woods.inc but they are fairly close.
POV's radiosity lighting is fantastic BTW.  My roommate used to stay up
doing homework and I let him keep the overhead light on.  I was able to
sleep in the bottom bunk because the overhead's only illuminated half of the
bottom bunk... just like in the rendering.  The shadows produced by the
window light are very close to real life as well.  There are no conventional
light sources in this scene.
Skip
Date: 2 Jun 2002 22:07:46
Message: <3cfacf72$1@news.povray.org>
Cool! And the window 'light-source' is that just a white ambient area or did
you do some extra things outside the dorm? Maybe recreating some major parts
of the outside area and ambient them you'll be able to get even more
realistic results?
Apache
ICQ: 146690431
Date: 2 Jun 2002 22:12:22
Message: <3cfad086@news.povray.org>
Sky sphere.  On the eleventh floor the incoming light is pretty simple: blue
sky.  Or the sun if it is setting.
Skip
Date: 2 Jun 2002 23:08:01
Message: <3CFAE219.8020206@caltel.com>
Hey Skip, nice scene! What rad. settings did you use?
> shot.
> Skip
Samuel Benge
sbe### [at] caltelcom
Date: 2 Jun 2002 23:25:48
Message: <3cfae1bc$1@news.povray.org>
global_settings {
  assumed_gamma 2
  radiosity {
    pretrace_start 0.08
    pretrace_end   0.0025
    count 1600
    nearest_count 15
    error_bound .2
    recursion_limit 3
    //low_error_factor 0.5
0
    gray_threshold 0.0
    minimum_reuse 0.015
    brightness 1.
    //adc_bailout 0.01/10
    always_sample on
// Grin!
Date: 3 Jun 2002 00:20:31
Message: <3cfaee8f$1@news.povray.org>
>     count 1600
Don't you just hate that upper limit? =)
 - Slime
[ http://www.slimeland.com/ ]
Date: 3 Jun 2002 00:30:49
Message: <3cfaf0f9$1@news.povray.org>
How hard would it be change it?  As easy as changing "1600" to "1000000" in
the source and then recompiling?
Date: 3 Jun 2002 03:00:24
Message: <3cfb1408@news.povray.org>
in
Perhaps, but I bet the limit is there because that's the size of an internal
array, and if you just blindly changed it, it'd eat up a ton of memory.
That's my guess at least.
 - Slime
Date: 3 Jun 2002 04:23:00
Message: <3cfb2764@news.povray.org>
> purposes of planning out some decorations for next year and did some
> radiosity experiments with it.  If it looks a bit distorted it's
> because of the camera angle (120 degrees) wanted to get the bunk,
> desk, and window in the same shot.
remove the back walls and put the camera far away :)
PGP Public Key
Date: 3 Jun 2002 05:36:22
Message: <3cfb3896@news.povray.org>
"Skip Talbot" <sta### [at] uiucedu> wrote in message
news:3cfac9be@news.povray.org...
the
conventional
Are the wooden parts of the bed really like that? I'd expect the "lines"
ending up being parallel with the long side, at least that's the usual way
they cut the trees.
Otherwise nice image, but there's always something that says it's not real.
Don't know what though.
Date: 3 Jun 2002 14:33:00
Message: <3cfbb65c@news.povray.org>
> Won't work well with radiosity.  But maybe no_image will do the trick.
Don't remove the back walls; instead, set the texture of the walls (which i
assume are nothing more than a hollow box) to be transparent, and then set
the *inner* texture of them to be solid, and you can see right through them
from the outside. Theoretically, at least.
 - Slime
Date: 3 Jun 2002 16:16:54
Message: <3cfbceb6$1@news.povray.org>
No, the wood grain on the bed is not really like that.  I just slapped a
woods.inc texture on it without scaling or rotating it.  In real life the
grain is much more subtle, it just has the same basic color.  Many smaller
details are left out too, which probably explains the lack of realism you
sense.
Skip
Date: 4 Jun 2002 14:17:23
Message: <3cfd0433@news.povray.org>
Doesn't seem to work that way...
At least, not when I tried:
difference {
    box { <-5,-5,-5>,<5,5,5> pigment { Clear } }
    box { <-2,-2,-2>,<2,2,2> pigment { Orange transmit .5 } }
sphere { <0,0,0>,.5 pigment { Red } }
Of course, I may have no clue what I'm doing...
"Slime" <slm### [at] slimelandcom> wrote in message
news:3cfbb65c@news.povray.org...
i
them
>  - Slime
Date: 4 Jun 2002 14:48:32
Message: <nSDiJdA1sQ$8Ew1f@econym.demon.co.uk>
>difference {
The syntax is
   texture {pigment {Clear}}
   interior_texture {pigment {Orange}}
Interior_texture is not supported in POV 3.1. You need POV 3.5 or
MegaPOV.
Mike Williams
Gentleman of Leisure
Date: 5 Jun 2002 00:10:06
Message: <3cfd8f1e@news.povray.org>
> >difference {
Mike's way illustrates what I meant. However, you'll probably want to make
the box "hollow" to keep from getting a "camera is inside a non-hollow
object" warning.
 - Slime
