POV-Ray : Newsgroups : povray.binaries.images : A quick img Server Time
23 Nov 2026 22:26:13 EST (-0500)
  A quick img (Message 1 to 13 of 13)
Subject: A quick img
Date: 18 Apr 2002 15:06:01
Message: <3cbf1919@news.povray.org>
Here's a quick spaceship image: ship is differenced objects from moray,
flares by the colefax flares pluign and galaxy from the other moray plugin.
What do you think? I may post a version with reduced flares.
Download 'spaceshp.jpg' (56 KB)
Preview of image 'spaceshp.jpg'
Subject: Re: A quick img
Date: 18 Apr 2002 17:56:36
Message: <3cbf4114$1@news.povray.org>
Needs Detail^197342 and Gaudiness^1/197342
 -Shay
Sam Van Oort <sam### [at] yahoocom> wrote in message
news:3cbf1919@news.povray.org...
Date: 18 Apr 2002 18:11:36
Message: <3cbf4498$1@news.povray.org>
You've got.. let me count.. 5 flares too many. The *small* flares on the wingtips lok
good, but particularly with the searchlights
(whatever they are) you get the feeling the flares are just there to show off. This
may not have been your intention- the Flare
include _is_ pretty neat, I agree- but the extra bits aren't necessary.
Date: 19 Apr 2002 14:31:44
Message: <3cc06290$1@news.povray.org>
Yeah, the flares are a BIT overkill. (understatement)  This was mostly a
test scene for some of the Moray plugins I downloaded.  I'll post a better
version sooner or later.  The "searchlight" is actually supposed to be a
laser, but I'm too lazy to tinker with media.  If anyone has a shortcut, be
my guest.
Sam
"Sam Van Oort" <sam### [at] yahoocom> wrote in message
plugin.
Date: 19 Apr 2002 16:05:52
Message: <Xns91F5A3C11C029csbhccse@204.213.191.226>
news:3cc06290$1@news.povray.org:
> The "searchlight" is actually supposed to be a laser, but I'm too lazy to
> tinker with media.  If anyone has a shortcut, be my guest.
Generic glowing sci-fi 'laser':
#macro BeamWeapon (Source, Bearing, Range, Radius, CenterColor, SideColor)
#local SourceRadius = Radius * 2;
sphere
    0,1
    pigment {rgbt 1}
    hollow
    interior
        media
            intervals 1
            method 3
            emission 1.75/Radius
            density
                spherical
                color_map
                    [0 color rgb <0,0,0>]
                    [.125 color SideColor]
                    [1 color CenterColor]
        media
            intervals 1
            method 3
            absorption .25/Radius
            density
                cylindrical
                color_map
                    [.125 color NegateVector (SideColor)]
                    [1 color NegateVector (CenterColor)]
    scale SourceRadius
    translate Source
cylinder
    <0,0,0> <0,1,0>, 1
    pigment {rgbt 1}
    hollow
    interior
        media
            intervals 1
            method 3
            density
                cylindrical
                color_map
        media
            intervals 1
            method 3
            absorption .275/Radius
            density
                cylindrical
                color_map
                    [1 color NegateVector (CenterColor*2)]
    rotate x*90
    scale <Radius, Radius, Range>
    rotate Bearing
    translate Source
Date: 19 Apr 2002 16:07:44
Message: <Xns91F5A412DD7AAcsbhccse@204.213.191.226>
che### [at] sympaticoca (Coridon Henshaw) wrote in
news:Xns### [at] 204213191226:
And you'll also need this:
#macro NegateVector (V)
<abs(1-V.x), abs(1-V.y), abs(1-V.z)>
Date: 20 Apr 2002 00:51:10
Message: <3cc0f3be@news.povray.org>
Thanks for code --  I'll use it soon. A new version of this img with focal
blur and less flare is rendering as I type. It is at the 4 hr mark now.  I
guess I've been rendering too long when I stay up past midnight to finish a
render. ;-).
Sam
Coridon Henshaw wrote in message ...
>#end
Date: 20 Apr 2002 01:29:48
Message: <3cc0fccc@news.povray.org>
Here's the new one.   The beam still needs stronger flares and some
tweaks... but that'll be version 3.0 (besides, I don't have the patience for
another render only to get weird effects from focal blur).
I know I should have set variance = 0...
Oh well, hindsight is 20/20 and
  aperture 2.0
  variance 0.01
  blur_samples = infinity
  confidence = ~1
Download 'nu_spaceshp3.jpg' (36 KB)
Preview of image 'nu_spaceshp3.jpg'
Date: 20 Apr 2002 11:42:35
Message: <3cc18c6b$1@news.povray.org>
I wasn't too impressed with this scene the first time, but you have
completely turned it around. The scene has a great look to it now.
The ship just needs a little work. The texture looks too large for the scale
of the ship and the lines look a little too "CSG-ish"
 -Shay
news:3cc0fccc@news.povray.org...
Date: 20 Apr 2002 19:28:09
Message: <3cc1f989$1@news.povray.org>
I think the focal blur is a bit too strong.
Date: 21 Apr 2002 15:10:55
Message: <3cc30ebf$1@news.povray.org>
Glad you like it.  I wanted the ship to appear as somewhat small, which is
why I have the oversized texture.  The lines are pretty much beyond my
control (an odd side effect of a checker texture w/out anything TO checker.
All I can do is add a little noise.   I'll do version 3.0 soon
As to the focal blur: maybe I should have put on my glasses when modelling.
Date: 22 Apr 2002 08:48:52
Message: <3CC4068D.7090908@yahoo.com>
I could be wrong about what those are, but I think the lasers or
whatever they are should extend past the camera.
The ending flares (the big white ones) are pointing away from the
camera, which means that you would not see whats in the image (you'd see
a glow around the engine tips and/or flame/glow extending away)
Think of it as a light behind an object, you may see the glow around the
object, but you'd not likely see the star-point streak effect unless the
light is bigger than the object. In this case the light isn't really
visible since it's right on or even in the engine and the angle means
the light is out of direct sight. All you'd see is the indirect
reflections of the light.
Date: 23 Apr 2002 03:08:51
Message: <3cc50883@news.povray.org>
Hi I agree for focal blur, it is usually found in photographs including a
foreground because when lense is focused to infinite, blur occurate only for
1st meters ( for usual focal lengths <300mm)
I am not a maths freak but depth of field may be a tangent function of focal
distance.
Am I wrong?
Marc
"Corey Woodworth" <cdw### [at] mpinetnet> a écrit dans le message de news:
3cc1f989$1@news.povray.org...
