Here is the (maybe) finished sword stand picture. I'm not sure if it's done
or I need to do something else in the image. The idea was to highlight the
sword and dagger (in a black leather sheath) on a wrought-iron sword stand.
The entire mess sitting on a fireplace mantel. I thought about adding
something cloth-like to offset the hardness of the image but I'm not sure.
Any ideas?
Patrick Dugan
Download 'SwordStand.jpg' (108 KB)
Preview of image 'SwordStand.jpg'
I would not have known that the dagger was in a leather sheath had you not
posted a description. The blade just looks like it hasn't had a texture
applied. The sword is nice, but the blue reflecting in the blade makes it
appear that the sky is reflecting. A photograph of the inside of your house
or just a plane with an image map of your bricks would probably make a more
convincing reflection.
-Shay
Patrick Dugan <pat### [at] netins net> wrote in message
news:3ca91752@news.povray.org...
That's true. I wanted to make the blade stand out but I think "viewing the
outside on the blade" does look too odd.
I'll have to come up with a better interior.
Thanks!
"Shay" <sah### [at] simcoparts com> wrote in message
news:3ca9c413$1@news.povray.org...
house
more
> -Shay
The coloring on the blade looks very artistic, I like the colors. I believe
that it adds to the scene instead of taking away from it because of realism.
The stone bricks are isosurfaces, no? What if you added a pigment function
on top of them giving them a small grain?
Skip
Yes they are isosurfaces. My math skills are poor at best. I felt luckly
to get them to look like that! :)
Here is some of the code I used:
isosurface {
function { f_rounded_box(x,y,z,0,0.70,0.85,0.70) - f_noise3d(x*5.2,
y*4.9, z*4.7)* 0.05 }
contained_by { box { -1 , 1} }
max_gradient 25
pigment {RockColor3 translate <0,-1.8,0>}
scale RockScale
If you could explain how that could be added here I will certainly try that.
Thanks!
Patrick Dugan
"Skip Talbot" <sta### [at] uiuc edu> wrote in message
news:3ca9f3cd$1@news.povray.org...
believe
realism.
function
> Skip
Sorry I left out the scale I used for the rocks.
#declare RockScale = <0.360,0.1,0.360>;
believe
realism.
function
> Skip
"Patrick Dugan" <pat### [at] netins net> wrote in message
> Any ideas?
Excellent! I've been following this. I think you could be right. A 'drape' hanging
behind the sword would look good IMHO. Either
red and yellow or red and black with some kind of FE.Asian text? I have to say that
your sword looks a beast in lambs clothing.
Those two straight bits with the curve on the ends, (near the hilt), are quite
in-humane are they not? Cruelly interesting. Are they
for real? I haven't seen that before myself...
Back to the image... A bevel line would look good also.... straight down the
middle of the blade...
Very nice image.
~Steve~
> Patrick Dugan
Perhaps add some focal blur?
Looks very good so far!
Marc-Hendrik
Thank you! Once I figure out a cloth method (or someone else posts a clith
include for Povray 3.5) I'll add something in there.
Well I actually own the sword and dagger. I haev tried to model them as
close as I can to the real thing. The "horns" on the hilt
could be a bit dangerous. The sword is very heavy. I didn't add a "blood
channel" down the blade since the real one doesn't have it.
Patrick Dugan
"25ct" <25c### [at] lineone net> wrote in message news:3ca9ff59@news.povray.org...
done
the
stand.
sure.
> > Any ideas?
'drape' hanging behind the sword would look good IMHO. Either
say that your sword looks a beast in lambs clothing.
quite in-humane are they not? Cruelly interesting. Are they
straight down the middle of the blade...
> Very nice image.
> ~Steve~
> > Patrick Dugan
Thank you!
I'm not sure where I would blur the image though. Maybe near the bottom of
the wall?
Patrick Dugan
"Marc-Hendrik Bremer" <Mar### [at] t-online de> wrote in message
news:3caa020c@news.povray.org...
> Marc-Hendrik
"Patrick Dugan" <pat### [at] usnetcomcorp com> wrote in message
news:3caa043d@news.povray.org...
> Thank you! Once I figure out a cloth method (or someone else posts a cloth
> Well I actually own the sword and dagger. I have tried to model them as
Ah! That's what it's called! A ' Blood Channel' ? Ie, a groove for the blood to
run down?? - Obviously.
Eek!! ;)
Heheh.. I was thinking more along the lines of the actual manufacture of the
sword. Don't they usually have 'bevelled' angles to
the blade? (Possibly with a groove too?)
The whole cross section being a thin/narrow diamond shape? I'm very possibly
wrong, so forgive me for *digging* too deep with
this... <..sheesh....> ;)
~Steve~
>blood to run down?? - Obviously.
Actually, the main purpose was to release suction on the blade and make
it easier to remove from your opponents body IIRC...
Jamie.
"Jamie Davison" <jam### [at] ntlworld com> wrote in message
news:MPG.17142409dbf1d231989b14@news.povray.org...
as
"blood
the
oops...common misconception...
True purpose of the fullered groove in a blade is to reduce weight and add
strength. (If you don't have the strength to give the blade a bit of a
twist when pulling it out, you didn't have the strength to put it in there
either.)
Scott
I would suggest the focal point on the name-plaque (or what ever it is
called), perhaps a little bit up and to the left. Start with some arbitrary
aperture. I don't know what will look better: some strong blurring, or just
a tiny bit.
Marc-Hendrik
