In which of these two images does the grass look more real?
1: http://rsj.mobilixnet.dk/3d/include/fgrass.jpg
2: http://rsj.mobilixnet.dk/3d/include/fgrass2.jpg
...and why? ...and what can be improved?
Thanks in advance,
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Feb 16)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring: http://webring.povray.co.uk
The first one- there are more lights and darks (different colors of grass, shadows),
the flowers are better defined, and the grass
bits look more wavy, like real grass.
"Rune" <run### [at] mobilixnet dk> wrote in message news:3ca509a8@news.povray.org...
> Thanks in advance,
> Rune
> 3D images and anims, include files, tutorials and more:
I disagree: I prefer the 2nd before in the 1st, the blades bend creates a
kind of repeated pattern and the 2nd is mor subtily random
Marc
"Mahalis" <don### [at] fakey com> a écrit dans le message de news:
3ca510cc@news.povray.org...
shadows), the flowers are better defined, and the grass
Subject: Re: Please help me compare some grass
Date: 29 Mar 2002 21:25:04
Message: <3ca52200$1@news.povray.org>
The second image looks much better. At first glance, it is hard to say just
why, but I think it is because the blades show the right amount of curvature
versus width. If you had longer grass, the curvature in the first picture would
look more realistic. An individual blade of grass is fairly stiff, and does not
usually exhibit a great deal of bending unless exposed to high winds.
Cheers!
Chip Shults
I agree, it is the wave that puts me off the first one, I think.
> say just
> curvature
> would
> does not usually exhibit a great deal of bending unless exposed to high
> winds.
> Cheers!
> Chip Shults
> My robotics, space and CGI web page - http://home.cfl.rr.com/aichip
I think the curved one is less realistic. It seems forced. The straight
one is too straight, but within the realm of possible. The curvy one would
be right for 2 ft high grass.
I made a modified version of the second image, where the grass is a bit more
turbulated, and a bit lighter in color. How is the third image compared to
the others?
3: http://rsj.mobilixnet.dk/3d/include/fgrass3.jpg
Rune
/me still likes the 2nd image most ...
I'm not sure, if you see so much "pattern" in a closeup of the grass ...
Nr 2 is best.. Less waves and more stiff.. Both textures are best at a
distance - not surprising - but really good, at a distance! The straight
ones are *not* too straight IMO.. Besides I wonder if not most blades should
wave almost in the same direction - either due to wind or the sun, that
attracts them.
Hugo
Too much bending, and should be in the same direction.
Hugo
I prefer the second image. It appears the blades have a more random length, and the
third appears to have forced curvature and seems
unnatural.
Grim
I would agree with Hugo.
Of the three, I liked #2 best.
I don't have a problem with the curvature of the grass in #'s 1 and 3, but I would
expect that larger regions of the field would have a more similar direction of the
curvature.
I'm not sure I'm being clear. Maybe this is better:
A large region (like a few square meters) should have most of the grass bending the
same general direction. A neighboring region could have most of the grass bending a
different direction, with a gradual shift in direction between the different regions.
Keep some randomness, of course, but less (or maybe a wider) turbulence.
The grass could even be laying down flat (from wind or rain) but it would mostly be
lying in the same general direction.
On a completely different note:
I thought that your technique was basically just "coloring" the ground to make it
look like grass. But then I saw on the horizon of the nearby knoll (on the left)
that the grass appears to rise above the surface. I'm just itching to have a look at
your technique.
Thomas Bates
"Hugo" <hua### [at] post3 tele dk> wrote in message news:3ca5cdd0$1@news.povray.org...
> attracts them.
> Regards,
> Hugo
> ...and why?
I prefer the second one.. not so wavy, and it seems to blend better in
the distance.
-Xplo
1. Looking strictly at the grass, it's hard to say, but the flowers in
2 look like they're just floating, and I think 1 has a much nicer blend
into the path.
David Fontaine <dav### [at] faricy net> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
Don't like 1, blades are too bent or seem to have too many curves.
No opinion about 3 but can't explain why :-/
Like 2 best, I've seen better, but I would be happy with that.
Alf
I like grass2 best too. Some reference images from corbis.com:
http://www.luxlab.com/ref/grass/
Maybe you could add fake shading.
_____________
Kari Kivisalo
Very good reference images. Thanks!
Looks like grass has a much more crisp green color than I remembered. Unless
the photos have been saturated artificially that is, but I don't think so...
I don't think that works with the method I use...
Rune
An excellent job. I'm voting for Number 2 so far. It looks the way a
recently-seeded lawn looks as it starts to sprout in the spring.
A quick look at the Corbis reference images reminded me of just how
surprisingly green grass actually is, especially early in the year. It
doesn't seem to bend in any single direction unless the wind is very
strong. In scale it can be rather more thin than memory would have it,
and there's usually a great variation in blade height in any unmown
grass. Long grass can be branchier and more tuft-like than one would
think. In the Midwest US where I live, I've noticed that wild fields of
grass (up close) have much variety of texture and species, lots of
little sticks and brush and weeds sticking up, etc-- clutter, in other
words. All on top of mats of dried matter from previous seasons: the
dirt almost never shows through in a wild field.
I'm sure you've run up against the biggest issue in creating CG grass:
creating
enough bejillions of blades to approximate nature. Limitations of memory
and processing time tend to see to it that the blades must be much
sparser than in a real field, which is so jammed with life that even
from a short distance the grass looks like fuzz. I've often thought that
individual blades may be best for the parts of the scene that are in the
foreground and middle-near, while some other method (one or more layers
of variagated procedural texture?) be used for the background. Sometimes
height-dependent background textures seem tempting, as color and
lushness often vary with moisture levels.
All in all: nice stuff.
DZ
> Thanks in advance,
> Rune
"DZ" wrote:
> An excellent job.
Thanks!
> me of just how surprisingly green grass actually is
Same here. In my newer message "Some grass" which you'll find below, I've
tried making the grass a bit more saturated. Still not quite as green as in
the photos though, because that just didn't look right in this image.
> creating CG grass: creating enough bejillions of
Nope.
> Limitations of memory and processing time tend to
> see to it that the blades must be much sparser than
> in a real field
But the whole concept of my grass is that it's a texture, not individual
blades of grass. So I have only two objects in the scene: two copies of the
same height_field, one translated sligtly above the other.
With my method memory and processing time is absolutely no problem, no
matter how big the field of grass is. :)
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Mar 19)
Wow, that's cool! But how can suprimposed heightfields create the blade-like
shapes?
DZ
> Nope. [...] the whole concept of my grass is that it's a texture, not
> individual
> heightfields create the blade-like shapes?
It's actually not the superimposed heightfields that does it. One
heightfield would be enough, but then the horizon would not be fuzzy, and
that would reveal the illusion.
The trick lies in the special function used for the pigment. It, well, sort
of simulates 3d blades of grass being projected onto a 2d plane using
perspective projection. How to do that is something you know if you have the
ability to twist the concept of 3d around your little finger. Ok, just
kidding, but it's a bit difficult to explain... ;)
Rune
I downloaded the source from your website. 3dnoise and sin/cosine-- that's
brilliant! Acres and acres of cheap, verdant POV real estate.
Nice job.
DZ
> and sin/cosine-- that's brilliant! Acres and acres
Thanks. :)
Though, the file on my website is my old Fast Grass Include File.
What I'm working on now is a better-looking technique which makes more
realistic grass which also work in animations. It's a bit slower though...
Rune
