POV-Ray : Newsgroups : povray.binaries.images : Dry stone wall - help! [12.4KB] Server Time
23 Nov 2026 23:16:32 EST (-0500)
  Dry stone wall - help! [12.4KB] (Message 1 to 23 of 23)
Subject: Dry stone wall - help! [12.4KB]
Date: 22 Mar 2002 08:23:27
Message: <3c9b304f@news.povray.org>
I'm working on a macro that will hopefully eventually generate a dry-stone wall,
but I'm running into problems. In the image below, the wall should approx. fill
the area marked out by the yellow cylinders, but it ain't.
If anyone can be bothered to:
a) work out what I'm trying to do
b) work out how I'm trying to do it
and
c) what's going wrong
then here is the code:
//start code
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 1.5, -100.0>
  look_at   <0.0, 1.5,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
#macro BuildWall()
  #declare Rand1 = seed(142);
  #declare Brick = sphere{0,1 pigment{Red}}
  #declare Ground = plane{y,0 pigment{Green}}
  #declare WallLen = 50;
  #declare WallHi = 15;
  #declare ThisLen = 0;
  #declare ThisHi = 0;
  #declare Wall = object{Ground}
  #while(ThisLen <= WallLen & ThisHi <= WallHi)
    #declare XScale = rand(Rand1)*2 + 0.5;
    #declare YScale = rand(Rand1)*2 + 0.5;
    #declare ZScale = rand(Rand1)*2 + 0.5;
    #declare ThisBrick = object{Brick scale<XScale, YScale, ZScale>}
    #if(ThisLen = 0)
      #declare Norm = <0, 0, 0>;
      #declare Start = <0,WallHi*2,0>;
      #declare InterA = trace ( Wall, Start, <0, -1, 0>, Norm );
      #declare Wall = union{
        object{Wall}
        object{ThisBrick translate y*(InterA.y + YScale)}
      #declare ThisLen = XScale;
      #declare ThisHi = InterA.y + YScale;
    #else
      #declare Start = <ThisLen+XScale,WallHi*2,0>;
      #if(InterA.y < ThisHi)
        #declare Start = <WallLen*2,InterA.y + YScale,0>;
        #declare InterB = trace ( Wall, Start, <-1, 0, 0>, Norm );
          object{Wall}
          object{ThisBrick translate<InterB.x + XScale, InterA.y + YScale, 0>}
      #declare ThisLen = InterB.x + (XScale*2);
      #if(ThisLen > WallLen & ThisHi <= WallHi)
BuildWall()
object{Wall}
cylinder{0,y*25, 0.2 pigment{Yellow}}
cylinder{0,y*25, 0.2 pigment{Yellow} translate x*50}
cylinder{x*-10,x*60, 0.2 pigment{Yellow} translate y*15}
//end code
... and here is the image
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Download 'dw1.jpg' (13 KB)
Preview of image 'dw1.jpg'
Subject: Re: Dry stone wall - help! [12.4KB]
Date: 22 Mar 2002 08:35:11
Message: <fhcm9u828ait8dv6qdnl804gj40jcrnj6a@4ax.com>
On Fri, 22 Mar 2002 13:23:26 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
Sorry, i'm tired of functions currently and I want to not think for a moment
(only sigs can give me some enterainment) but take a look in Ken's macro
http://home.pacbell.net/tylereng/arbre.jpg. Perhaps something could be
borrowed. Personally I would use turbulenced isosurface of spheres (as
pattern) for such stones probably.
ABX
Date: 22 Mar 2002 09:08:30
Message: <3c9b3ade$1@news.povray.org>
"W³odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:fhcm9u828ait8dv6qdnl804gj40jcrnj6a@4ax.com...
I know the feeling...
I fully intend to use iso-surfaces when I get the basic code sorted - the
sphere's are just a quick and dirty temporary thing...
I'll take a look at Ken's macro (arbre.jpg?) - many thanks.
Date: 22 Mar 2002 09:09:54
Message: <3c9b3b32$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3c9b3ade$1@news.povray.org...
Ah! - I suspect that this won't help me as his bricks are too regular for a
dry-stone wall (or at least of the type I'm trying to create).
Date: 22 Mar 2002 09:22:58
Message: <9efm9u4qstnder7tssujbna65u56gr6ohc@4ax.com>
On Fri, 22 Mar 2002 14:09:54 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
I didn't looked at his macro (perhaps it is pigment) but You can use centers
of cells and dimensions as radius, then create isosurface and adjust
turbulencing.
ABX
Date: 22 Mar 2002 09:53:22
Message: <3c9b4562@news.povray.org>
news:3c9b304f@news.povray.org...
wall,
fill
> and
    Well, skipping a) and b) and looking only at the image, it looks like
you have a mismatched loop somewhere. It goes across but not up. I will take
a few more minutes to look it over but so far your method befuddles* me.
    *Remembering that I am easily befuddled by math-like thingies.
Date: 22 Mar 2002 09:55:58
Message: <3c9b45fe$1@news.povray.org>
    Doesn't the above fail as soon as one of the conditions are met?
Shouldn't they be in two statements, one repeating until the other fails?
Subject: Re: Dry stone wall - I see the problem
Date: 22 Mar 2002 10:02:18
Message: <3c9b477a$1@news.povray.org>
Trace hits all of the stones in the first row, because they are all stacked
in a straight line. On subsequent rows, the trace is only hitting
occasionally. One miss starts you back on the ground.
 -Shay
Tom Melly <tom### [at] tomandlucouk> wrote in message
Date: 22 Mar 2002 10:09:51
Message: <3c9b493f$1@news.povray.org>
"Bill DeWitt" <bde### [at] cflrrcom> wrote in message
news:3c9b45fe$1@news.povray.org...
Ah! I think that's it - it should be an "or" rather than an "and". Ta.
Date: 22 Mar 2002 10:10:30
Message: <3c9b4966$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3c9b477a$1@news.povray.org...
Hmm, no I think that's alright. At any rate, it's intended.... I think Bill has
spotted it.
Date: 22 Mar 2002 10:16:41
Message: <3c9b4ad9@news.povray.org>
news:3c9b493f$1@news.povray.org...
Your stones will go on for a very long distance this way.
 -Shay
Date: 22 Mar 2002 10:33:46
Message: <3c9b4eda$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3c9b4ad9@news.povray.org...
Yes - Bill's pointed out the problem, but I'm still working on the solution. I
don't think there's a perfect solution using this method, except to try
different random seeds. However, it's starting to look like it might produce
some nice results.... Hopefully I'll have a second image post RSN.
Date: 22 Mar 2002 10:40:23
Message: <3c9b5067$1@news.povray.org>
news:3c9b4eda$1@news.povray.org...
I'm still confident that it is the trace problem. Leave your code exactly as
it is in your post except for the following lines, and you will see what I
mean.
#declare XScale = 1;//rand(Rand1)*2 + 0.5;
#declare YScale = 1;//rand(Rand1)*2 + 0.5;
#declare ZScale = 1;//rand(Rand1)*2 + 0.5;
 -Shay
Date: 22 Mar 2002 10:47:03
Message: <3c9b51f7$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3c9b5067$1@news.povray.org...
> mean.
Hmm, okay - I'll have to think about this some more (probably when my brain
stops bleeding).
Date: 22 Mar 2002 10:57:55
Message: <3c9b5483$1@news.povray.org>
I have the solution if you want it. I won't post without asking, because you
may want to think about it more yourself.
 -Shay
news:3c9b51f7$1@news.povray.org...
Date: 22 Mar 2002 11:04:58
Message: <3c9b562a$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3c9b5483$1@news.povray.org...
Nghhh - okay, post. No, no, I didn't mean that. Ah, hell.
Date: 22 Mar 2002 11:23:41
Message: <3c9b5a8d$1@news.povray.org>
news:3c9b562a$1@news.povray.org...
I guess that's a "no." I see another possible bug when you switch over to
side trace.
 -Shay
Date: 22 Mar 2002 11:40:13
Message: <3c9b5e6d$1@news.povray.org>
I've been playing with your code a little bit, and I'm afraid that the
algorithm may be doomed. The only ways that I can think of for keeping the
bricks from overlapping are *very* complex. Hopefully someone can find a
simpler solution to the problems with the algorithm than I.
You might want to create another algorithm that places the stones
mathematically rather than with trace, but I don't think that any algorithm
will beat a random guess and check algorithm.
 -Shay
Shay <sah### [at] simcopartscom> wrote in message
news:3c9b5a8d$1@news.povray.org...
Date: 22 Mar 2002 11:49:07
Message: <3c9b6083@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3c9b5e6d$1@news.povray.org...
Yes, some overlapping seems inevitable. My hope is that with the right random
seed the problem will not be visable. Partial results look ok.
Besides..... a lot of the wall will be hidden by snow ;)
Date: 2 Apr 2002 20:23:30
Message: <3caa5992@news.povray.org>
a)  Drive people absolutely nuts and job security...
b)  TOO complex
c)  TOO Much CODE.
Here's my solution...
#declare RS=seed(9938);
//------------------------------------------------Wall
#declare R1=1;
#while(R1<3000)
  #declare RX=rand(RS)*50;
  #declare RY=rand(RS)*10;
  #declare ROD=rand(RS)*1+.5;
  #declare RSY=rand(RS)*.5+.5;
  #declare RSX=rand(RS)*.5+.5;
  sphere{<0,0,0>,ROD scale<RSX,RSY,1> translate<RX,RY,0>
texture{pigment{color Red}}}
  #declare R1=R1+1;
I made it only 10 units tall instead of your 25.  Looks better.
Robert J Becraft
aka cas### [at] aolcom
wall,
fill
> and
> //start code
> #version 3.5;
> global_settings {
>   assumed_gamma 1.0
> camera {
> light_source {
> #macro BuildWall()
>     #if(ThisLen = 0)
>         object{Wall}
>     #else
>           object{Wall}
0>}
>       #end
>       #end
>     #end
>   #end
> #end
> BuildWall()
> object{Wall}
> //end code
Download 'TESTwall.jpg' (10 KB)
Preview of image 'TESTwall.jpg'
Date: 2 Apr 2002 20:32:48
Message: <3caa5bc0@news.povray.org>
Version 2 w/ a color randomizer for the components...
#declare RS=seed(938);
#declare R1=1;
#while(R1<3000)
  #declare RC=int(rand(RS)*5+1);
       #switch(RC)
       #case(1) Gray10 #break
       #case(2) Gray40 #break
       #case(3) Gray50 #break
       #case(4) Gray80 #break
       #case(5) Gray90 #break
  #declare R1=R1+1;
"Robert J Becraft" <cas### [at] aolcom> wrote in message
news:3caa5992@news.povray.org...
> b)  TOO complex
> c)  TOO Much CODE.
> #declare R1=1;
> #while(R1<3000)
>   #declare R1=R1+1;
> #end
> Regards,
> Robert J Becraft
dry-stone
> wall,
approx.
> fill
> > and
> > //start code
> > #version 3.5;
> > global_settings {
> >   assumed_gamma 1.0
> > camera {
> > light_source {
> > #macro BuildWall()
> >     #if(ThisLen = 0)
> >         object{Wall}
> >     #else
> >           object{Wall}
YScale,
> 0>}
> >       #end
> >       #end
> >     #end
> >   #end
> > #end
> > BuildWall()
> > object{Wall}
> > //end code
Download 'TESTwall.jpg' (11 KB)
Date: 2 Apr 2002 23:34:57
Message: <3caa8671@news.povray.org>
The problem with this solution is that the "stones" blend into each other.
IIRC... the original problem was to build a realistic stone wall.
Scott
news:3caa5bc0@news.povray.org...
> #declare R1=1;
> #while(R1<3000)
>        #switch(RC)
>        #end
>   #declare R1=R1+1;
> #end
> > b)  TOO complex
> > c)  TOO Much CODE.
> > #declare R1=1;
> > #while(R1<3000)
> >   #declare R1=R1+1;
> > #end
> > Regards,
> > Robert J Becraft
> dry-stone
> > wall,
> approx.
> > fill
> > > and
> > > //start code
> > > #version 3.5;
> > > global_settings {
> > >   assumed_gamma 1.0
> > > camera {
> > > light_source {
> > > #macro BuildWall()
> > >     #if(ThisLen = 0)
> > >         object{Wall}
> > >     #else
> > >           object{Wall}
> YScale,
> > 0>}
> > >       #end
> > >       #end
> > >     #end
> > >   #end
> > > #end
> > > BuildWall()
> > > object{Wall}
> > > //end code
Date: 3 Apr 2002 07:18:40
Message: <3caaf320@news.povray.org>
Ooo - not bad. I'm still working on my version (now much more simplified). RL
has got in the way, but hopefully something to post soon. Currently running into
a problem where, under certain conditions, the macro finds the same hole that
needs filling, fails to fill it, then finds the hole again - aka infinite loop.
