POV-Ray : Newsgroups : povray.binaries.images : Dry stone wall - help! [12.4KB] Server Time
16 Aug 2024 06:18:05 EDT (-0400)
  Dry stone wall - help! [12.4KB] (Message 1 to 10 of 23)
Subject: Dry stone wall - help! [12.4KB]
Date: 22 Mar 2002 08:23:27
Message: <3c9b304f@news.povray.org>
I'm working on a macro that will hopefully eventually generate a dry-stone wall,
but I'm running into problems. In the image below, the wall should approx. fill
the area marked out by the yellow cylinders, but it ain't.
If anyone can be bothered to:
a) work out what I'm trying to do
b) work out how I'm trying to do it
and
c) what's going wrong
then here is the code:
//start code
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 1.5, -100.0>
  look_at   <0.0, 1.5,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
#macro BuildWall()
  #declare Rand1 = seed(142);
  #declare Brick = sphere{0,1 pigment{Red}}
  #declare Ground = plane{y,0 pigment{Green}}
  #declare WallLen = 50;
  #declare WallHi = 15;
  #declare ThisLen = 0;
  #declare ThisHi = 0;
  #declare Wall = object{Ground}
  #while(ThisLen <= WallLen & ThisHi <= WallHi)
    #declare XScale = rand(Rand1)*2 + 0.5;
    #declare YScale = rand(Rand1)*2 + 0.5;
    #declare ZScale = rand(Rand1)*2 + 0.5;
    #declare ThisBrick = object{Brick scale<XScale, YScale, ZScale>}
    #if(ThisLen = 0)
      #declare Norm = <0, 0, 0>;
      #declare Start = <0,WallHi*2,0>;
      #declare InterA = trace ( Wall, Start, <0, -1, 0>, Norm );
      #declare Wall = union{
        object{Wall}
        object{ThisBrick translate y*(InterA.y + YScale)}
      #declare ThisLen = XScale;
      #declare ThisHi = InterA.y + YScale;
    #else
      #declare Start = <ThisLen+XScale,WallHi*2,0>;
      #if(InterA.y < ThisHi)
        #declare Start = <WallLen*2,InterA.y + YScale,0>;
        #declare InterB = trace ( Wall, Start, <-1, 0, 0>, Norm );
          object{Wall}
          object{ThisBrick translate<InterB.x + XScale, InterA.y + YScale, 0>}
      #declare ThisLen = InterB.x + (XScale*2);
      #if(ThisLen > WallLen & ThisHi <= WallHi)
BuildWall()
object{Wall}
cylinder{0,y*25, 0.2 pigment{Yellow}}
cylinder{0,y*25, 0.2 pigment{Yellow} translate x*50}
cylinder{x*-10,x*60, 0.2 pigment{Yellow} translate y*15}
//end code
... and here is the image
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Download 'dw1.jpg' (13 KB)
Preview of image 'dw1.jpg'
Subject: Re: Dry stone wall - help! [12.4KB]
Date: 22 Mar 2002 08:35:11
Message: <fhcm9u828ait8dv6qdnl804gj40jcrnj6a@4ax.com>
On Fri, 22 Mar 2002 13:23:26 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
Sorry, i'm tired of functions currently and I want to not think for a moment
(only sigs can give me some enterainment) but take a look in Ken's macro
http://home.pacbell.net/tylereng/arbre.jpg. Perhaps something could be
borrowed. Personally I would use turbulenced isosurface of spheres (as
pattern) for such stones probably.
ABX
Date: 22 Mar 2002 09:08:30
Message: <3c9b3ade$1@news.povray.org>
news:fhcm9u828ait8dv6qdnl804gj40jcrnj6a@4ax.com...
I know the feeling...
I fully intend to use iso-surfaces when I get the basic code sorted - the
sphere's are just a quick and dirty temporary thing...
I'll take a look at Ken's macro (arbre.jpg?) - many thanks.
Date: 22 Mar 2002 09:09:54
Message: <3c9b3b32$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3c9b3ade$1@news.povray.org...
Ah! - I suspect that this won't help me as his bricks are too regular for a
dry-stone wall (or at least of the type I'm trying to create).
Date: 22 Mar 2002 09:22:58
Message: <9efm9u4qstnder7tssujbna65u56gr6ohc@4ax.com>
On Fri, 22 Mar 2002 14:09:54 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
I didn't looked at his macro (perhaps it is pigment) but You can use centers
of cells and dimensions as radius, then create isosurface and adjust
turbulencing.
ABX
Date: 22 Mar 2002 09:53:22
Message: <3c9b4562@news.povray.org>
news:3c9b304f@news.povray.org...
wall,
fill
> and
    Well, skipping a) and b) and looking only at the image, it looks like
you have a mismatched loop somewhere. It goes across but not up. I will take
a few more minutes to look it over but so far your method befuddles* me.
    *Remembering that I am easily befuddled by math-like thingies.
Date: 22 Mar 2002 09:55:58
Message: <3c9b45fe$1@news.povray.org>
    Doesn't the above fail as soon as one of the conditions are met?
Shouldn't they be in two statements, one repeating until the other fails?
Subject: Re: Dry stone wall - I see the problem
Date: 22 Mar 2002 10:02:18
Message: <3c9b477a$1@news.povray.org>
Trace hits all of the stones in the first row, because they are all stacked
in a straight line. On subsequent rows, the trace is only hitting
occasionally. One miss starts you back on the ground.
 -Shay
Tom Melly <tom### [at] tomandlucouk> wrote in message
Date: 22 Mar 2002 10:09:51
Message: <3c9b493f$1@news.povray.org>
"Bill DeWitt" <bde### [at] cflrrcom> wrote in message
news:3c9b45fe$1@news.povray.org...
Ah! I think that's it - it should be an "or" rather than an "and". Ta.
Date: 22 Mar 2002 10:10:30
Message: <3c9b4966$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3c9b477a$1@news.povray.org...
Hmm, no I think that's alright. At any rate, it's intended.... I think Bill has
spotted it.
