POV-Ray : Newsgroups : povray.binaries.images : Dart Server Time
23 Nov 2026 23:34:07 EST (-0500)
  Dart (Message 1 to 19 of 19)
Subject: Dart
Date: 11 Mar 2002 17:24:21
Message: <3c8d2e95@news.povray.org>
I'm a newbie to pov-ray, but am very excited at the possibilities pov-ray
offers!!!
A friend named Flaming Monarch (already posted in group) and I are working
through pov-ray, learning as much as we can.
This was an image I created in about 6 hours (most of the time spent on
getting image_map to work the way I wanted it), and I am pleased with the
result!
Any criticism, whether positive or negative would be accepted!
Download 'darts.png' (27 KB)
Preview of image 'darts.png'
Subject: Re: Dart
Date: 11 Mar 2002 17:28:58
Message: <3c8d2faa@news.povray.org>
it seams darts are also quite common objects to stat with POV ...
I did one, when I started, but I can't find it anymore ..
maybe make the metal reflective, and give it some environment to reflect ?
I'm sure, about the tail .. are the flaps supposed, not to be perpendicular
otherwise: fine modeling and nice perspective ...
Add some focal blur now ...
Subject: Re: Dart
Date: 11 Mar 2002 17:33:57
Message: <3c8d30d5@news.povray.org>
"Jan Walzer" <jan### [at] lzernet> wrote in message
news:3c8d2faa@news.povray.org...
Makes me feel better :-)
Interesting idea! I plan on eventually including this object in my office
scene (WIP), which would provide the needed environment.
perpendicular
On these darts, yes the flaps are supposed to be slightly off perpendicular.
Again, an interesting idea... ill try it soon
Thanx!!!
Subject: Re: Dart
Date: 11 Mar 2002 17:37:23
Message: <3c8d31a3$1@news.povray.org>
Another thing, maybe worth a try, is to use extrem FB and set the focal
point
in such a manner, that the reflected objects are sharp ... you know what I
mean ?
Subject: Re: Dart
Date: 11 Mar 2002 17:42:26
Message: <3c8d32d2@news.povray.org>
> point
> mean ?
That would look amazing :-)
Thanx for the tips!
Subject: Re: Dart
Date: 11 Mar 2002 17:48:55
Message: <3c8d3457@news.povray.org>
no probs, but:
I'm not sure 'bout "amazing" ...
especially in the current perspective, you would blur the dart itself a
lot, so you could merely see it any longer ... but as I said, worth a try
Subject: Re: Dart
Date: 11 Mar 2002 18:06:34
Message: <3c8d387a$1@news.povray.org>
Cool Dart!
Subject: Re: Dart
Date: 12 Mar 2002 13:06:22
Message: <slrna8s5j2.7r6.steve@zero-pps.localdomain>
Nice image, but the metal textures need some work, and the flighte should
be semi-transparent.
I can just imagine the Canadian camera man standing infront of the dart
board saying, "throw it now, I'll try to take a snap and move out of the
way in the split second that it takes to travel from your hand to the
dart board":-))
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Subject: Re: Dart
Date: 12 Mar 2002 15:03:38
Message: <3c8e5f1a$1@news.povray.org>
Needs slight softening of the edges on the "grip."
 -Shay
Lieut_Data <lIe### [at] yahOOcom> wrote in message
news:3c8d2e95@news.povray.org...
Subject: Re: Dart
Date: 12 Mar 2002 18:28:05
Message: <3c8e8f05$1@news.povray.org>
"Steve" <ste### [at] zeroppsuklinuxnet> wrote in message
news:slr### [at] zero-ppslocaldomain...
How would you recommend I go about working on the metal texture?
> , and the flighte should be semi-transparent.
Hmm... the dart I modeled dosen't seem to be partially transparent... are
most darts that way?
Thanks for the input!
Subject: Re: Dart
Date: 12 Mar 2002 18:30:13
Message: <3c8e8f85$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message
news:3c8e5f1a$1@news.povray.org...
To which part are you referring, the angular cut on the grip (points on
lathe)?
Or to the differenced cylinders in the grip itself?
Thanks!
Subject: Re: Dart
Date: 12 Mar 2002 20:39:54
Message: <3c8eadea$1@news.povray.org>
Cool! How about adding a regular but bumpy normal to the copper part to make
it look like it has some grip.
Corey
Subject: Re: Dart
Date: 13 Mar 2002 08:33:30
Message: <3c8f552a@news.povray.org>
"Corey Woodworth" <cdw### [at] mpinetnet> wrote in message
news:3c8eadea$1@news.povray.org...
make
Interesting addition. Although it adds to the picture, the real dart I
modeled had no such "grip".... maybe I have cheap darts :-)
Thanx!!!
Download 'darts.png' (33 KB)
Subject: Re: Dart
Date: 13 Mar 2002 09:27:04
Message: <3c8f61b8$1@news.povray.org>
news:3c8e8f85$1@news.povray.org...
> lathe)?
The cylinders on the grip itself.
 -Shay
Subject: Re: Dart
Date: 13 Mar 2002 13:08:24
Message: <slrna8um87.d25.steve@zero-pps.localdomain>
I think it's down to the finish statement, maybe add some thong size
and roughness to it, like thong_size 40, roughness 0.0001 or soemthing
like that, and maybe a touch of specular.
I'm sure that even the ones that aren't particularly transparent do allow
light to pass through, so you get a double illuminated effect.  You see
something simil with individual sheets of paper in a room that has only
one light source, you can't see through the paper but you can see the
light coming through it no matter what direction you're facing.  This is
considered to be an advanced effect so if you can pull it off you will
be doing very well.
Subject: Re: Dart
Date: 13 Mar 2002 16:52:44
Message: <3c8fca2c$1@news.povray.org>
thong?      :-)
Subject: Re: Dart
Date: 14 Mar 2002 19:29:55
Message: <slrna92g3o.i78.steve@zero-pps.localdomain>
> thong?      :-)
Oops, just spelling as I'd say it :-)
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Subject: Re: Dart
Date: 15 Mar 2002 09:00:11
Message: <3c91fe6b@news.povray.org>
"Lieut_Data" <lIe### [at] yahOOcom> wrote in message
> offers!!!
> result!
Very cool ideas:
    -As others have suggested focal blur (on the dart)
    -Try Megapov's motion blur...
    -Less specular on the grip (it better not be smooth)
Subject: Re: Dart
Date: 15 Mar 2002 12:18:46
Message: <3c922cf6$1@news.povray.org>
> Very cool ideas:
Thanks for so much input. I have been working on a new version, adding
several of the suggested items.
