I've been messing around with the crackle pigment, and got a couple of good
effects :)
The first one's an iso surface that looks a bit like a city. It looks more
city-like from a low camera angle, but I did this orthographic view to use a s a
desktop backdrop :) BTW, this one took nearly 24 hours to render!! I'm gonna
have to find a way to speed it up.
The other picture's a circuit board pigment effect I dreamt up a couple of hours
ago. Both use crackle with metric 1 to get that nice angular effect.
What do you think?
Tek
http://www.evilsuperbrain.com
Download 'crackscape.jpg' (173 KB)
Download 'crackcircuit.jpg' (54 KB)
Preview of image 'crackscape.jpg'
Preview of image 'crackcircuit.jpg'
Hi Tek, I especially like the circuit board and I have no idea how you made
it with crackle patterns! I would have needed a bitmap.. But you know, if
you send electricity through this, you'll get nothing but shortcuts.. Can
this be avoided / improved? Good work, anyway.
Hugo
I think you mean 'short circuits', not 'shortcuts'. Of course, from an
electron's point of view, it's the same thing.. but you weren't talking from
an electron's perspective.. *walks away muttering*
"Hugo" <hua### [at] post3 tele dk> wrote in message
news:3c8bc3a4$1@news.povray.org...
made
> Regards,
> Hugo
?? Sorry hmm.. I really thought this was the proper way to say it in
english. Then how to say "when something short circuits" ...you don't say
that, or?
I like the first one best, a desktop for one day. After more than a day, my
eyes will probably start to malfunction.
It makes me think of a kind of rock call basalt (at lease in Dutch, I am
not sure what it is in English).
> of good effects :)
Very nice, both of them. Any chance of getting the source?
/"\ | iki.
\ / ASCII Ribbon Campaign | fi/
X Against HTML Mail | zds
> am not sure what it is in English).
Same thing.
Gis poste, Arto.
> effects :)
You will always have serious problems with such infinite gradient
functions. There are no strongly visible artefacts at this scale, but in
a more detailed view you will surely see them.
Using conventional objects instead, preferably meshes, would be much more
efficient.
See for example:
http://www.interq.or.jp/blue/kawashu/include/i04.html
http://news.povray.org/povray.binaries.images/12339/
Last updated 21 Feb. 2002 _____./\/^>_*_<^\/\.______
In article <3c8bcda8@news.povray.org>,
It is called basalt in English as well. However, it usually takes the
form of hexagonal pillars, these are too irregular. This looks like more
of an organic phenomenon.
Christopher James Huff <chr### [at] mac com>
POV-Ray TAG e-mail: chr### [at] tag povray org
Christoph Hormann schrieb in Nachricht <3C8BD3C2.7F80B4CE@gmx.de>...
Hi Christoph,
Of course I have limited experience, but the problem seems not that big as
it first appears. There is that adaptive gradient method R. Suzuki mentioned
once (where? Don't know - had something to do with the old "eval" IIRC.) and
functions like min(min(abs(x),abs(y)),abs(z))) work quite well with there
infinite gradient and even with low max_gradient settings.
There are problems with the gradient of course and using pigments or
functions in isosurfaces will sometimes need some high max_gradient
settings. But I use them all the time and I had no problems, I could not
solve with some decent settings - even with the really 'evil' brick-pattern,
which is hard to use in isosurfaces.
Perhaps your experience is different, but IMHO pattern/pigment-functions are
very suitable esp. for isosurface beginners.
Greetings,
Marc-Hendrik
You could use a sample of a pattern and apply it to hexagon pillars...
that would give a height for each and they would be much more like actual
basalt, if that was what you were aiming for. For the centerpoint of each
column, grab a value from one of the patterns like bumps.
Hmm, gives me an idea.
Cheers!
Chip Shults
You might be able to speed things up by using a hightfield with a
pigment function. They render fairly fast.
Josh English
eng### [at] spiritone com
http://www.spiritone.com/~english
> effects :)
> What do you think?
> Tek
> [Image]
> [Image]
> with a pigment function. They render fairly fast.
That won't work well. Completely and almost completely vertical surfaces in
height fields look horrible. And no, it won't help much using a higher
resolution for the height field.
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Feb 16)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
On Sun, 10 Mar 2002 19:29:40 -0000, Tek wrote:
> What do you think?
Source me:-)
%HAV-A-NICEDAY email mailto:ste### [at] zeropps uklinux net
Steve web http://www.zeropps.uklinux.net/
or http://start.at/zero-pps
7:47pm up 4 days, 21:44, 1 user, load average: 1.19, 1.10, 1.03
You're right there. I started out rendering from gound level and had to play
with the max_gradient and accuracy settings to reduce the artefacts to an
acceptable level, though from those low angles things rendered a lot quicker so
I could afford some more accuracy.
> efficient.
> See for example:
Thanks! I'd had a go at doing something like that, but my results weren't any
quicker to draw than the isosurface! The only problem with this is trying to
imitate the shapes I get using a metric of 1.
Tek
Christoph Hormann <chr### [at] gmx de> wrote in message
news:3C8BD3C2.7F80B4CE@gmx.de...
> > effects :)
s a
> efficient.
> See for example:
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
Subject: Re: the power of crackle - BIG circuit picture (597k)
Date: 10 Mar 2002 19:03:33
Message: <3c8bf455@news.povray.org>
Here's a biiig backdrop render I've done. The colours are loosely based on
photos I saw once of a CPU... but who cares it looks cool :)
Tek
Tek <tek### [at] evilsuperbrain com> wrote in message news:3c8bb4ff@news.povray.org...
> effects :)
a
hours
> What do you think?
> Tek
Download 'crackcircuit2.jpg' (597 KB)
Preview of image 'crackcircuit2.jpg'
By popular demand, source is now in p.b.s-f :)
Tek
> effects :)
a
hours
> What do you think?
> Tek
This function does not have an infinite gradient, it should render
perfectly with max_gradient 2. However it does have non-continuous
derivatives, but this is no problem for isosurfaces.
Pigment and pattern functions are generally suited for isosurfaces as long
as they are continuous. brick, checker, cells, etc. are not. You may
have successfully used them, but every time you change the geometry or
the viewpoint there can be artefacts occuring and it will be unnecessarily
slow so i can only advise against it.
On Sun, 10 Mar 2002 19:29:40 -0000, "Tek" <tek### [at] evilsuperbrain com> wrote:
Oh, man! 24 hours ?! Speed it up ?!
My failed "shortest code contest" entry at this moment has status line:
"165:16:47 Rendering line 159 of 600 supersampled 467 times."
(and there are only 2 flat isosurfaces) so you should be happy.
ABX
Very cool for just a few lines of code. You really should find a way to make
this into a mesh.
-Shay
I took the perspective view of the cityscape, moved the camera upwards a
bit, increased the radiosity detail from Fast to Normal, and then rendered
in 1024x768 AA 0.3 +AM2 +R3. I'm now using this image as my desktop.
If you could figure out how to create a building texture and road texture,
it would just be killer. I'm not good enough with POV to figure out how to
do it.
-DJ
Download 'crackscape.png' (259 KB)
Preview of image 'crackscape.png'
Oh yeah. It took about 12 hours to render on my 1 Ghz Pentium III, in case
anyone was curious.
-DJ
Remove the TRIMBRAKES to reply.
"DJ Wiza" <Kil### [at] TRIMBRAKESyahoo com> wrote in message
news:3c8f0377@news.povray.org...
to
> do it.
> -DJ
That's interesting, i can hardly see any artefacts. What settings did you
use for max_gradient and accuracy?
max_gradient is 8 and accuracy is 0.0001.
-DJ
"Christoph Hormann" <chr### [at] gmx de> wrote in message
news:3C8F15C7.237C5951@gmx.de...
> Christoph
Cool pic! I just put the smaller one on my BG at work, but I'll replace it with
this render :)
BTW, I find it renders much quicker from the low camera angle, because it has
lots of sky and the anti-aliasing can do far fewer samples.
I really like the higher camera position, some of the distant buildings are
really nice. In fact, you've motivated me to try texturing it! I'll post the
results if I get anything good.
Tek
DJ Wiza <Kil### [at] TRIMBRAKESyahoo com> wrote in message
news:3c8f0658@news.povray.org...
> anyone was curious.
> -DJ
> to
> > do it.
> > -DJ
> takes the form of hexagonal pillars, these are too irregular.
crackle metric 2 (the default) would fit it better.
Anton Sherwood, http://www.ogre.nu/
Ah, so the bug in metric 1 has been corrected. (Which version of pov?)
Anton Sherwood <bro### [at] pobox com> wrote in message
news:3CB0A898.3311CB02@pobox.com...
It was rendered with 3.5 beta 13 I think.
Tek
