POV-Ray : Newsgroups : povray.binaries.images : SEM neuron Server Time
17 Oct 2026 23:26:09 EDT (-0400)
  SEM neuron (Message 1 to 20 of 20)
Subject: SEM neuron
Date: 19 Feb 2002 18:35:38
Message: <3c72e14a@news.povray.org>
My take on "worlds within worlds". Not very literal, but for a me (my real
job is in medicine), it makes sense. What do you think of the idea?
Also, would like comments on the scanning electron microscope effect. It's
not quite where I want it to be, but getting there. (see previous post SEM
texture)
John
Download 'neurons.jpg' (81 KB)
Preview of image 'neurons.jpg'
Subject: Re: SEM neuron
Date: 19 Feb 2002 21:47:39
Message: <3c730e4b@news.povray.org>
I like it very much! I agree that it does look like an electronic microscope
photograph. I think some minor tweaking will produce a better image, but
you're already on the way!
Congrats,
Fernando.
"John Bradshaw" <joh### [at] nospamhotmailcom> wrote in message
news:3c72e14a@news.povray.org...
> texture)
> John
Date: 19 Feb 2002 22:33:49
Message: <3c73191d$1@news.povray.org>
I was thinking about almost the same texture situation: the clothes of that
princess in 'Shrek', did you see that? (I forgot about the name of that
fabric.)
I like that texture.
And I absolutely like that picture! But isn't it a bit too 'clean' and sharp
for a scanning electron microscope?
Date: 20 Feb 2002 02:16:25
Message: <3c734d49$1@news.povray.org>
"Apache" <apa### [at] yahoocom> wrote in message
news:3c73191d$1@news.povray.org...
that
> fabric.)
Hi Apache,
I think that the texture you're talking about in Spanish is called
"terciopelo", and I think in English is "velvet". I hope someone can confirm
my dubious translation.
Fernando.
Date: 20 Feb 2002 03:53:19
Message: <3c7363ff$1@news.povray.org>
Cool pic!
I like it a lot.
IMHO there should be something in the background, since the SEM probes are
mounted on some surface before they get a gold coat, right?
Very nice, tough!
regards
SY
Date: 20 Feb 2002 10:28:39
Message: <3c73c0a7$1@news.povray.org>
Check out www.uq.edu.au/nanoworld they have a database of SEM and TEM
images.  The "Mystery Images" section seems pretty good.
I think people would murder to get real images as good as yours...
Mark Hanford
http://www.mrhanford.com/povray
> texture)
> John
Date: 20 Feb 2002 10:29:41
Message: <3c73c0e5@news.povray.org>
Looks good and I recognize the type of lighting! But I don't know WHY it
looks that way through an .... what did you call it?  Electron microscope..
What's the reason for such a light?
Hugo
Date: 20 Feb 2002 11:04:41
Message: <3c73c919$1@news.povray.org>
> texture)
I reviewed that teapot image with an SEM expert and these were our comments
there, many of which would apply to your image...
An SEM has a detector off to one side.  So in effect surfaces which face the
detector will be brighter (higher collection yield) than those which face
away. Your image gives the feeling that the detector is in the center of the
sample, if there's not multiple light sources.
The image rightly shows how surfaces which are normal to the "camera" ie.,
incident beam are brighter. Again, the secondary electron detection yield is
higher as well on these surfaces.   This is a good *pigment*, FWIW.
It looks, however, as if it were stainless steel, with very little beam
penetration into the sample.  Contrast this with "record 22 of 700; Title:
'Blood cell' " in the image gallery at.
http://www.uq.edu.au/nanoworld/images_1.html
For an organic, low-atomic-number sample, I'd expect there to be some
translucency, almost a 'media' effect, as in that blood cell image
The "etched steel" effect in your texture normal is a bit troublesome.  Here
the concern is not so much with SEM physics but with the intuitive feel of
cells: things should be more round, even like "Lung surface: image 39 of
700" at that gallery.
_________
Greg M. Johnson
10-yr SEM user
Date: 20 Feb 2002 12:07:08
Message: <3c73d7bc@news.povray.org>
> texture)
looks great close up - not so great further away.. hmmm
perhaps a little translucency
PGP Public Key
Date: 20 Feb 2002 12:24:31
Message: <3c73dbcf@news.povray.org>
Thanks for your comments and perspective of an actual SEM user.
the
the
I've added another light source about 80 degrees to the right, we'll see if
that helps.
Hmmm, perhaps a little scattering media. Hate to see those render times
though.
Here
Again, I think the biggest problem with the texture is that it is only a
bump map. If I knew of a way to introduce a little noise into my mesh....
Date: 20 Feb 2002 12:26:35
Message: <3c73dc4b$1@news.povray.org>
Cool! Great reference images. Thanks.
Again, I wish I could mess it up a little with some displacement in the
mesh.
Date: 20 Feb 2002 12:28:12
Message: <3c73dcac@news.povray.org>
> Cool pic!
> I like it a lot.
Thanks.
I think your right, but I didn't like how it looked on a plane, so enter
artistic license.
John
Date: 20 Feb 2002 13:34:59
Message: <3c73ec53$1@news.povray.org>
news:3c73dbcf@news.povray.org...
>> the sample, if there's not multiple light sources.
if
> that helps.
Ooops. I meant it should be more like a single light source, fwiw.
Date: 20 Feb 2002 14:50:43
Message: <MPG.16de1c84b9b053b89896c4@news.povray.org>
In article <3c73c919$1@news.povray.org>, "Greg M. Johnson" <gregj:-)
565### [at] aolcom> says...
> > texture)
> _________
> Greg M. Johnson
> 10-yr SEM user
It is true that a SEM has a detector somewhere to one side, but this
doesn't mean in any way that the resulting image can be compared to an
object illuminated by the detector as the light source!
The secondary electrons that make up the SEM image can very well
originate at the opposite side of the object. These electrons are low
energy particles and travel slowly, so their paths are easily bent.
And what i really miss in these images is the so-called "Kanten Effekt"
characteristic to SEM images. In short this means that thin and sharp
parts of the object show up much lighter than the more even and smooth
parts.
In general the image looks a bit like an SEM image...  :))
Sander (who spent half his working life behind an SEM!)
Date: 20 Feb 2002 16:55:20
Message: <3c741b48$1@news.povray.org>
"Sander" <san### [at] stolscom> wrote in message
news:MPG.16de1c84b9b053b89896c4@news.povray.org...
I just saw some SEM's where the "north-facing slope" of raised features is
darker than the "south slope".  The question is one of different detection
efficiency.  What do you think of the "double illumination" effect of the
teapot image??
My mentor has left for the day and all Yahoo! searches of this term end up
with German web sites........
Date: 20 Feb 2002 17:09:50
Message: <3c741eae$1@news.povray.org>
> parts.
Do you have an example of this effect? Could it be simulated with media?
Date: 20 Feb 2002 18:31:23
Message: <3c7431cb$1@news.povray.org>
John Bradshaw <joh### [at] nospamhotmailcom> schrieb in im Newsbeitrag:
3c741eae$1@news.povray.org...
> > parts.
I have. The sawtooth-like structures in the upper part of the picture get
thinner on the right side. So more secondary electrons emerge from the
sample which brighten up the image in that parts. ("Kante" means "edge", for
those who don't speak german.)
BTW, there _can_ be a "directional lighting" in SEM images. It just depends
on how much voltage you apply to the detector grid. If, for example, the
voltage is zero, you collect only those electrons flying directly into the
detector, leaving the surfaces facing away from it completely dark.
In POV you could perhaps simulate SEM images by radiosity. If you put a thin
horizontal ring around the scene, with ambient=1 all parts facing horizontal
would be the brightest, and all facing vertical would be the darkest,
assumed the camera is looking along -y.
Michael
Date: 20 Feb 2002 18:32:13
Message: <3c7431fd@news.povray.org>
D'oh!
Download '33412_1.JPG' (42 KB)
Preview of image '33412_1.JPG'
Date: 21 Feb 2002 06:18:41
Message: <3C74D785.6E3C8ACA@namtar.qub.ac.uk>
Yowch! This one's scary...
36/700  http://www.uq.edu.au/nanoworld/images_1.html
signature{
Date: 21 Feb 2002 07:01:57
Message: <MPG.16df002147b7105b9896c6@news.povray.org>
In article <3c7431cb$1@news.povray.org>, zie### [at] atlantiswh2tu-dresdende
says...
True: in that case you collect back-nscattered electrons only.
> Michael
Sander
