POV-Ray : Newsgroups : povray.binaries.images : Art gallery IRTC WIP (52kbu) Server Time
24 Nov 2026 00:18:31 EST (-0500)
  Art gallery IRTC WIP (52kbu) (Message 1 to 20 of 20)
Subject: Art gallery IRTC WIP (52kbu)
Date: 1 Feb 2002 09:25:15
Message: <3c5aa54b@news.povray.org>
Version 2
Still need to do the lights and add some water around the fish and
perhaps a subtle normal to the wall.
The fish is a poser model and the pictures in the frames were created
in vue d'espirit
Comments?
Gail
#macro G(H,S)disc{0z.4pigment{onion color_map{[0rgb<sin(H/pi)cos(S/pi)*(H<6)
cos(S/pi)*(H>6)>*18][.4rgb 0]}}translate<H-5S-3,9>}#end G(3,5)G(2,5.5)G(1,5)
G(.6,4)G(.5,3)G(.6,2)G(1,1)G(2,.5)G(3,.7)G(3.2,1.6)G(3.1,2.5)G(2.2,2.5)G(9,5
)G(8,5.5)G(7,5)G(7,4)G(7.7,3.3)G(8.3,2.7)G(9,2)G(9,1)G(8,.5)G(7,1)//GS
Download 'Painting.jpg' (52 KB)
Preview of image 'Painting.jpg'
Subject: Re: Art gallery IRTC WIP (52kbu)
Date: 1 Feb 2002 10:22:19
Message: <3c5ab2ab@news.povray.org>
<envy-suppressing mode>
Your concept keeps getting better and better.
That said, two comments: the surface of the water (ripples) seems too
regular, and could use some water drops emerging as the fish passes. Also,
did you try ro get parto of the fish tail to be inside the painting? I don't
even know if such is possible, but I believe that the emerging effect would
be improved if such was possible.
Keep up the good work.
Ruy
</envy-suppressing mode>
Date: 1 Feb 2002 11:39:23
Message: <3c5ac4bb$1@news.povray.org>
Ruy <ruy### [at] hipernetcombr> wrote in message news:3c5ab2ab@news.povray.org...
> Ruy
And a splash in the water from the fish breaking the surface.
That would add to the effect I think.
Tom Bates
#macro T(B)#local m=mod(B,8);#local B=floor(B/8);m#end#local C=126981491245202;#
local D=115694168992822;sphere_sweep{b_spline 16#local i=0;#while(i<16)<T(C)-4,T
(D)-4,10-i/10>.1#local i=i+1;#end pigment{rgb 1}}light_source{-10,1} //Tom Bates
Date: 1 Feb 2002 16:09:50
Message: <3C5B03C3.8040508@tiac.net>
Very nice. Definately needs water splashing and if
you can bend the fishes tail it might give it a little
more life.
Phil
Behold, for I am the keeper of the sacred coffee brewing method.
Date: 2 Feb 2002 00:35:39
Message: <slrna5mj3q.66o.steve@zero-pps.localdomain>
On Fri, 1 Feb 2002 16:24:51 +0200, Gail Shaw wrote:
> Version 2
How about some leaves of one of the trees sticking out too.
The fish jumping out is a great idea, how about a goldfish bowl on top
of that pedestal instead of the fractal, and a small goldfish inside it.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Date: 2 Feb 2002 02:02:19
Message: <3c5b8efb$1@news.povray.org>
Or a goldfish painting floating just under the surface in the bowl... kinda
like a reverse of roles.  yin yang
Date: 2 Feb 2002 05:33:54
Message: <3C5BC0F0.9030809@web.de>
Gail Shaw wrote:
> Version 2
> in vue d'espirit
> Comments?
> Gail
Shouldn't the fish be in the image on the wall? :-)
Subject: Re: Art gallery IRTC WIP (16kbu)
Date: 2 Feb 2002 05:34:15
Message: <3c5bc0a7@news.povray.org>
"Ruy" <ruy### [at] hipernetcombr> wrote in message
thank you
Painting still needs work.
> Also,
don't
would
The fish tail is part of the painting. the image that's used in the painting
is attached.
Anything is possible (within reason) it's just a case of how much time you
are
willing to spend. Aligning the fish model with the picture so that it looks
like one
fish took the better part of two days of tweak and render.
Gail
Download 'Pond.jpg' (17 KB)
Preview of image 'Pond.jpg'
Date: 2 Feb 2002 05:35:15
Message: <3c5bc0e3@news.povray.org>
"Phil Clute" <pcl### [at] tiacnet> wrote in message
news:3C5### [at] tiacnet...
> more life.
It's as bent as I can. The poser model's not very good and
angles larger than I have make it look broken :-<
Gail
Date: 2 Feb 2002 05:35:44
Message: <3c5bc100@news.povray.org>
"Steve" <ste### [at] zeroppsuklinuxnet> wrote in message
news:slr### [at] zero-ppslocaldomain...
Sounds good
Gail
Date: 2 Feb 2002 05:56:07
Message: <3c5bc5c7@news.povray.org>
Hi Gail
 This is getting really interesting as concept, and also artistically. My
only complains are more for the tech part. I see the shadow parts are too
dark. Can you put some light on "the other side" of the room to give some
light filling? It also seems to mee that the point of view is somewhat
"opressive", too close to the wall (I think someone already mentioned it).
  Good luck!
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 2 Feb 2002 08:25:45
Message: <3c5be8d9@news.povray.org>
"Gail Shaw" wrote:
> Aligning the fish model with the picture so that it looks like
> one fish took the better part of two days of tweak and render.
Sounds like you could maybe save some time by using my Illusion Include
File:
http://rsj.mobilixnet.dk/3d/include/include.html
Great image by the way! I'll follow its development. :)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
Date: 3 Feb 2002 18:01:11
Message: <3c5dc137@news.povray.org>
Hi Gail,
A nice image progressing well. I like the fish leaving the picture (it
emphasises the 'where the pictures are a little more real than is usual'
comment in your first post). When I read that comment I though you might
have had a figure reaching into one of the pictures, but your concept is
great.
I think that the camera position/angle could be tweaked a little. Moving it
back could give you the opportinity to add some more details to the wall,
such as skirting boards, and floor.
I look forward to seeing the final version.
Cheers,
Ian.
http://www.outerarm.demon.co.uk/graphics/graphics.html
Date: 3 Feb 2002 20:28:24
Message: <3C5DE3B8.90205@umich.edu>
> is attached.
> are
> like one
Maybe this would require unreasonable trouble, in light of how you made
the fish, but I think a different camera angle would help. That is, so
the camera is closer to the fish and the fish is jumping at it.
The image is kinda dark. You might try 1) brighter lighting, or
2) lighting that looks like nighttime security lighting as if this sort
of thing only happens after hours.
John Haiducek
Date: 3 Feb 2002 20:31:28
Message: <3c5de470$1@news.povray.org>
"John Haiducek" <jha### [at] umichedu> wrote in message
news:3C5### [at] umichedu...
> John Haiducek
Or, if you wanted to use a poser model, a security guard finding a fish on
the floor in front of the painting. Actually, you wouldn't even need the
security guard. Not sure if you want to be that subtle, however.
 -Shay
Date: 4 Feb 2002 01:16:07
Message: <3c5e2727@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3c5be8d9@news.povray.org...
> File:
Forgot about it <g>
Thanks
Gail
Date: 4 Feb 2002 07:05:20
Message: <3C5E78FA.9480463B@namtar.qub.ac.uk>
The julias look a bit unstable to me; perhaps make the pedestals a bit
bigger?
Gail Shaw wrote:
> Version 2
> in vue d'espirit
> Comments?
> Gail
signature{
Subject: Re: Art gallery IRTC WIP new camera angle (15kbu)
Date: 4 Feb 2002 09:24:14
Message: <3c5e998e@news.povray.org>
Version 2.5
Changed the camera angle and brightened up the fill lights.
better? worse?
Gail
Download 'Painting.jpg' (15 KB)
Date: 4 Feb 2002 09:27:42
Message: <3c5e9a5e$1@news.povray.org>
Worse. Looks better showing a view down the hall. IMO
Gail Shaw <gsh### [at] monotixcoza> wrote in message
news:3c5e998e@news.povray.org...
> Version 2.5
Date: 4 Feb 2002 11:16:50
Message: <3c5eb3f2$1@news.povray.org>
"Gail Shaw" <gsh### [at] monotixcoza> wrote in message
> Version 2.5
> better? worse?
    The fish now looks as if it could actually be part of the physical
painting. Like a sculpture attached to it. Before it was obviously separated
from the image.
