POV-Ray : Newsgroups : povray.binaries.images : camera lens - GI + blured reflec + problem :) (76kbbu) Server Time
24 Nov 2026 00:57:23 EST (-0500)
  camera lens - GI + blured reflec + problem :) (76kbbu) (Message 1 to 14 of 14)
Subject: camera lens - GI + blured reflec + problem :) (76kbbu)
Date: 28 Dec 2001 15:52:14
Message: <3c2cdb7e@news.povray.org>
3 day render, an old model of a standard 35mm camera lens, 99% rad lighting
(1 small very dim 3x3 area light)
blurred reflection created using a fine bump on ground plain (same settings
as image I posted a few days back)
spot the problem? I have no idea what caused that. nothing that an average
blur in psp wont fix mind
will post the post processed versions when I have it if any one is
interested
PGP Public Key
Download 'camera-blurreflec.jpg' (76 KB)
Preview of image 'camera-blurreflec.jpg'
Subject: Re: camera lens - GI + blured reflec + problem :) (76kbbu)
Date: 28 Dec 2001 19:42:35
Message: <574q2uc7ta5pbr2caft9o2g11g0229mcuf@4ax.com>
On Fri, 28 Dec 2001 20:53:17 -0000, "Rick [Kitty5]" <ric### [at] kitty5com>
Wow... thought for a moment that Mike was back. Really convincing!
Peter Popov ICQ : 15002700
Date: 28 Dec 2001 22:38:40
Message: <3c2d3ac0@news.povray.org>
news:3c2cdb7e@news.povray.org...
lighting
Awsome rolex? j/k :-)
Looks awesome!  I'm just curious, if you put the POV-camera by one of those
lenses, would it give a sort of "camera" effect (lens flares, etc)?
#macro S(M)cylinder{E(M)<A,C,5>,<B,D,5>,.1,15}#end#macro E(P)#if(div(P,16)
)#declare B=-1;#declare D=-2;#end#if(div(P,32))#declare A=1;#declare C=0;#
end#if(div(P,64))#declare B=-1;#declare D=0;#end#if(div(P,128))#declare A=
1;#declare C=2;#end#end blob{S(192)S(96)S(48)pigment{rgb 8*z}} /** Ian **/
Date: 28 Dec 2001 22:40:11
Message: <3c2d3b1b@news.povray.org>
"Ian Burgmyer" <the### [at] yahoocom> wrote in message
news:3c2d3ac0@news.povray.org...
> lighting
You know, now that I look at it, the glass plate on the right lens looks a
bit too opaque to me.  Is the scene lighting doing that?
Date: 29 Dec 2001 04:56:14
Message: <3c2d933e$1@news.povray.org>
The problem i see is in the darker parts of the reflection. It seems to be
"squared". After 3 days of render, this must be boring ... :)
Hartmut
"Rick [Kitty5]" <ric### [at] kitty5com> schrieb im Newsbeitrag
lighting
settings
> interested
> Rick
> Kitty5 WebDesign - http://Kitty5.com
> POV-Ray News & Resources - http://Povray.co.uk
> TEL : +44 (01270) 501101 - FAX : +44 (01270) 251105 - ICQ : 15776037
> PGP Public Key
Date: 29 Dec 2001 06:31:26
Message: <3c2da98e$1@news.povray.org>
yeah - that's the huge ambient 1 sphere I lit the scene with's reflection
PGP Public Key
Date: 29 Dec 2001 06:31:27
Message: <3c2da98f$1@news.povray.org>
yes - if you brighten you monitor up its really noticeable - and I have no
idea what caused it - as all my test renders didn't show anything like it
PGP Public Key
Date: 29 Dec 2001 06:31:28
Message: <3c2da990$1@news.povray.org>
those
yes and no
the elements I made are rough approximations of the real things, mainly so
they look correct from the front. if I had made them a little more precisely
you would be able to look through them and get a semi meaningful result.
'real' lens flares are quite easy to achieve
http://news.povray.org/povray.binaries.images/11313/
PGP Public Key
Date: 30 Dec 2001 23:19:50
Message: <3c2fe766$1@news.povray.org>
news:3c2da98e$1@news.povray.org...
a
Ohh, okay...figured.
Date: 30 Dec 2001 23:21:34
Message: <3c2fe7ce$1@news.povray.org>
news:3c2da98f$1@news.povray.org...
be
Try putting an additional light behind the camera to see if that clears it
up at all.  It seems like the shadows are getting "blocked up" by the "grip"
of the lens.
Date: 30 Dec 2001 23:24:59
Message: <3c2fe89b@news.povray.org>
news:3c2da990$1@news.povray.org...
precisely
Yeah, I remember that post (I replied to it a couple of times).  That's
exactly what I was thinking of when I posed the question, actually :-)
Would you be able to post the Moray source for the first lens image in
moray.binaries?  I'm interesting in seeing what kind of setup you have.
Date: 31 Dec 2001 08:44:51
Message: <3c306bd3$1@news.povray.org>
news:3c2fe89b@news.povray.org...
> "Rick [Kitty5]" <ric### [at] kitty5com> wrote in message
so
> precisely
which scene - the camera lens one, or the 'real lens flare' ?
PGP Public Key
Date: 2 Jan 2002 13:38:23
Message: <3C335309.80705@club-internet.fr>
Rick [Kitty5] wrote:
> spot the problem?
IMHO using a Leica Summicron-M asph. f/1.4 35mm would fix nearly anything!
François DISPOT  --  http://www.wozzeck.net
       __  __ __  __  _
|  | /  \  /  / |_  /  |/
\/\/ \__/ /_ /_ |__ \_ |\
Date: 3 Jan 2002 23:44:00
Message: <3c353310@news.povray.org>
news:3c306bd3$1@news.povray.org...
The "real lens flare" one...but the camera lens one would be nice in
addition to that ;-p
