POV-Ray : Newsgroups : povray.binaries.images : 3d-Mosaic Server Time
23 Oct 2026 01:58:43 EDT (-0400)
  3d-Mosaic (Message 1 to 19 of 19)
Subject: 3d-Mosaic
Date: 28 Dec 2001 08:20:49
Message: <3c2c71b1@news.povray.org>
I've made a picture with a 3dmosaic-macro i wrote and i think it looks
interesting.
The macro divides a box in space into unisized cubes and tests each cube if
it is in
a particular object. it can take several samples per cube if wished. then it
only creates
those cubes which are partially inside and partially outside the object.
It's a bit like
the marching-cubes algo but without triangulation. each vube which is
created is a
superellipsoid which size and shape is dependant on how many samples were in
the
object. The scene uses radiosity and an area-light. The object is an
isosurface.
Rendertime was 90 hours on my celeron 400. If i had known this before i
hadn't
rendered it at all : ]
I would appreciate comments and suggestions on this.
    Thies Heidecke
Download 'iso_mosaic.jpg' (158 KB)
Preview of image 'iso_mosaic.jpg'
Subject: Re: 3d-Mosaic
Date: 28 Dec 2001 08:22:54
Message: <3c2c722e@news.povray.org>
sorry for the too long rows : /
Date: 28 Dec 2001 08:28:57
Message: <3C2C71D8.3070704@videotron.ca>
Thies Heidecke wrote:
> Hi,
What are these blotches on the walls and floor?
Very nice pic, BTW.
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 28 Dec 2001 08:55:20
Message: <3c2c79c8$1@news.povray.org>
Hi Francois,
I've added some turbulence to the checker-pigment.
The pigment block is like this:
    checker color rgb 1 color rgb <0.4,0.2,0.01>
    turbulence 0.0015
> Very nice pic, BTW.
    Thies Heidecke
Date: 28 Dec 2001 10:13:16
Message: <3c2c8c0c$1@news.povray.org>
cube if
> it is in
then it
> only creates
object.
How?  Do you use the trace function?
Very nice indeed.  When you have a faster computer, make the cubes out
of glass, put a light inside it, and render with photons :)
Date: 28 Dec 2001 11:39:16
Message: <3c2ca034@news.povray.org>
Hi Andrew,
I use the inside-function to test if a point is inside the object.
If anyone is interested in the source i'll post it.
Thanks. Argh. Although I'll upgrade my computer soon (Duron 700 =) )
this would be pure overkill =] but If anyone of you has too much
idle-time...
I'd be interested in the result : ]
Greetings
    Thies Heidecke
Date: 28 Dec 2001 13:13:30
Message: <3c2cb64a@news.povray.org>
Yes, please. Been attracted by the beauty of such objects, I'm interested.
> idle-time...
I can't say that I have too much idle-time,
but it's possible to try. :)
wbr,
 gleb
Date: 28 Dec 2001 22:34:16
Message: <3c2d39b8@news.povray.org>
"Thies Heidecke" <h3i### [at] gmxnet> wrote in message
news:3c2c71b1@news.povray.org...
> Hi,
> interesting.
Wow!  This looks very cool.
I think it would look very interesting with that glass/photons idea, but
that'd be pushing it :-)
Maybe if someone has an extra system...hmm...
Actually, after I get my Mac (should arrive in a few days), I might be able
to render it on my P2-400 if you make the necessary changes in the scene
file.  Be prepared to wait a few years while it renders, though ;-)
#macro S(M)cylinder{E(M)<A,C,5>,<B,D,5>,.1,15}#end#macro E(P)#if(div(P,16)
)#declare B=-1;#declare D=-2;#end#if(div(P,32))#declare A=1;#declare C=0;#
end#if(div(P,64))#declare B=-1;#declare D=0;#end#if(div(P,128))#declare A=
1;#declare C=2;#end#end blob{S(192)S(96)S(48)pigment{rgb 8*z}} /** Ian **/
Date: 28 Dec 2001 23:34:22
Message: <3c2d47ce@news.povray.org>
I posted the scene-file (after major cleanup and some improvements) in
p.b.s-f
if u want the photon-overkill-scene =) turn photons and centerlight on with
the
declares at the beginning, change texture to texture{ glass }and uncomment
the interior statement.
Greetings
    Thies Heidecke
Date: 29 Dec 2001 05:19:01
Message: <3c2d9895@news.povray.org>
Uh, oh yeah!  I'd forgotten all about the inside function :-)  Guess I'd
better keep reading the helpfile...
Date: 29 Dec 2001 10:46:09
Message: <3c2de541@news.povray.org>
Hi Ian,
Thanks very much : )
able
I've posted the scenefile in p.b.s-f so if you like you can render it. I
would be
interested in the outcome.(2 months later...) =]
Greetings
    Thies Heidecke
Date: 29 Dec 2001 10:47:27
Message: <3c2de58f$1@news.povray.org>
Hi Gleb,
I've posted the .pov-file in p.b.s-f
Greetings
    Thies Heidecke
Date: 30 Dec 2001 22:07:32
Message: <3c2fd674@news.povray.org>
news:3c2de541@news.povray.org...
> able
> would be
Okay :-)
I'll have to give it a go after my new computer arrives (I can't wait I
can't wait).  Mind if I post the result here when (if) it gets done?  ;-)
Date: 2 Jan 2002 01:33:37
Message: <3C32AA97.7F0ABB1E@faricy.net>
Cool, reminds me of those things with a bunch of pins where you can
stick something behind it and make a relief.  It might be interesting to
rotate the cube lattice relative to the object you're sampling; as is
they're oriented the same way.
Date: 2 Jan 2002 16:23:19
Message: <3c337a47@news.povray.org>
Yes, an animation would be cool, but i think that rendering and of course
parsing-time will be awful ...
Hartmut
"David Fontaine" <dav### [at] faricynet> schrieb im Newsbeitrag
news:3C32AA97.7F0ABB1E@faricy.net...
Date: 2 Jan 2002 16:57:55
Message: <3c338263@news.povray.org>
Hi David,
Yeah, I had this idea, too : )
I've made a pic where the orientation of the mosaic is rotated while
the object is unchanged. I used a rotated version of the object for the
Mosaic and rotated it back after mosaic. Perhaps I'll do an animation
in the near future, but the parsetime is quite long, even with this few
cubes. (Parsetime was about 4 minutes).
Greetings
    Thies Heidecke
Here's the pic:
Download '3D_Mosaic_2.jpg' (72 KB)
Preview of image '3D_Mosaic_2.jpg'
Date: 2 Jan 2002 17:26:03
Message: <3c3388fb@news.povray.org>
An animation would be great, but will take a wile ...
Keep on rendering, this looks cool ...
Hartmut
"Thies Heidecke" <h3i### [at] gmxnet> schrieb im Newsbeitrag
news:3c338263@news.povray.org...
> Hi David,
> Greetings
>     Thies Heidecke
> Here's the pic:
Date: 3 Jan 2002 19:13:04
Message: <3c34f390@news.povray.org>
"Hartmut Wagener" <har### [at] t-onlinede>  wrote :
news:3c3388fb@news.povray.org...
> Hartmut
My computer finally finished the animation. It consists of
80 frames. Each took about 15 min to render. I hope you
like it : )
You can d/l the file in p.b.a
Thies Heidecke
Date: 5 Jan 2002 23:37:53
Message: <3C37D57A.E5FFDF47@faricy.net>
Cool, it looks springy or under torsion.  The corner at top left in the
pic looks like a scroll decoration too.
