POV-Ray : Newsgroups : povray.binaries.images : [WIP] Kitchen 45k Server Time
24 Nov 2026 01:25:32 EST (-0500)
  [WIP] Kitchen 45k (Message 1 to 23 of 23)
Subject: [WIP] Kitchen 45k
Date: 8 Dec 2001 18:13:56
Message: <3c129eb4@news.povray.org>
Hi
I've been working on this kitchen and ran into moire. Is there a way to get
rid of it or do I have to live with it?
Another question is the metal texture on the sink. Blurred reflection is too
slow and Rune's brushed metal looked weird. Does anyone have a nice fuzzy
metal texture in mind?
Ari-Matti
Download 'kitchen.jpg' (42 KB)
Preview of image 'kitchen.jpg'
Subject: Re: [WIP] Kitchen 45k
Date: 8 Dec 2001 18:21:15
Message: <MPG.167cbeadaff1ba6f9896c9@news.povray.org>
In article <3c129eb4@news.povray.org>, ari### [at] tutfi says...
antialiasing method 2 perhaps? (+am2 in the command Line)
Lutz-Peter
Date: 8 Dec 2001 18:27:58
Message: <3c12a1fe@news.povray.org>
"Lutz-Peter Hooge" <lpv### [at] gmxde> wrote in message
news:MPG.167cbeadaff1ba6f9896c9@news.povray.org...
+am2 +r5 +a0.1 wasn't enough.
Ari-Matti
Date: 8 Dec 2001 19:03:30
Message: <MPG.167cc88ab484911e9896cb@news.povray.org>
In article <3c12a1fe@news.povray.org>, ari### [at] tutfi says...
Ouch...
Date: 8 Dec 2001 19:20:35
Message: <Xns9171C4C4F9659CQ@204.213.191.226>
"Ari-Matti Leppanen" <ari### [at] tutfi> wrote in
news:3c129eb4@news.povray.org:
> get rid of it or do I have to live with it?
Well, you could try rendering at four times your desired resolution,
applying a 4x4 smoothing filter then downsampling using an image editor.
Slow, but in all likelyhood it will work.
Date: 8 Dec 2001 19:47:35
Message: <3c12b4a7@news.povray.org>
Give us some source. The camera, light, and a plane with that texture giving
you problems would do.
Date: 9 Dec 2001 02:46:06
Message: <5h561u4vosv8g16i0kdn1j26vhfnj2p7q7@4ax.com>
On Sun, 9 Dec 2001 01:14:57 +0200, "Ari-Matti Leppanen"
Massive antialiase jittering?
Peter Popov ICQ : 15002700
Date: 9 Dec 2001 04:48:19
Message: <3C13337D.5080301@ignorancia.org>
  Hmmmm... focal blur? I've not tested it, but I seem to remember Suzuky
saying he used focal blur to avoid moire patterns in one of his latest
posts.
  Search these newsgroups for the recent trick on blurred reflection
developed by Ron Parker and others. It's great!
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 9 Dec 2001 05:13:48
Message: <3c13395c@news.povray.org>
"Coridon Henshaw" <che### [at] sympaticoca> wrote in message
> editor. Slow, but in all likelyhood it will work.
Sounds painfull.. I think I'll save this for the last desperate trace when
all else has failed. But thanks anyway.
Ari-Matti
Date: 9 Dec 2001 05:19:11
Message: <3c133a9f$1@news.povray.org>
"Tony[B]" <ben### [at] catholicorg> wrote in message
news:3c12b4a7@news.povray.org...
> giving you problems would do.
Here it is.
Ari-Matti
  location  <-80.0, 180.0, 25.0>
  look_at   <-120.0, 120.0,  160.5>
light_source { <0, 0, 0>
  color 1
  area_light <2, 0, 0>, <0, 2, 0>, 20, 20
  adaptive 1
  jitter
  circular
  orient
  translate <0, 250, 100>
  photons{refraction on reflection on}
plane {
  y, 89.5
    pigment { rgb <0.39, 0.41, 0.43>  quick_color rgb 0.5 }
    finish {
      diffuse 0.8
      brilliance 5
      specular 0.80
      roughness 1/100
      metallic on
      reflection { 0.65 metallic }
    normal {
      quilted control0 0.5 control1 1
      rotate y*45
      scale <1,1,0.4>
Date: 9 Dec 2001 08:32:15
Message: <3c1367df@news.povray.org>
>     normal {
>       rotate y*45
>       scale <1,1,0.4>
Well, there's you're problem! This sort of pattern will quickly develop
moire! :) Use something like bumps. Or better yet, use Ron's blurred
reflection trick. I'll go whip up a version of this using his technique and
post it for you.
Date: 9 Dec 2001 09:25:26
Message: <3c137456@news.povray.org>
I hope this does what you want. I didn't make it super-smooth because I
figured you wanted a little graininess.
  color 1
  adaptive 1
  jitter
  circular
  orient
difference
 box {-1000,1000}
 box {-999,999}
 pigment {rgb 1}
#declare Metal =
texture
 pigment
  quick_color rgb 0.5
 finish
  diffuse 0.8 brilliance 5
  specular 0.80 roughness 0.01
  metallic on
  reflection {0.65 metallic}
#declare BlurredMetal =
texture
 average
 texture_map
  #declare I = 0;
  #declare S = seed(7);
  #while (I<50)
   [1
    Metal
    normal
     bumps scale 0.1 triangle_wave bump_size 0.125
     translate <rand(S),rand(S),rand(S)>*0.2
   #declare I = I + 1;
plane {y, 89.5 texture {BlurredMetal}}
sphere {y*109.5,20 pigment {red 1} translate <-120,0,160.5>}
Date: 9 Dec 2001 11:25:40
Message: <3c139084$1@news.povray.org>
news:3c1367df@news.povray.org...
> and post it for you.
Well, I kinda know that. I want to get rid of moire not the texture. :) That
kind of quadrangular bump pattern is on my kitchen counter.
I have already tried the blurred reflection trick on the sinks, but it's
sooo sloooow.
But thanks for your effort!
Ari-Matti
Date: 9 Dec 2001 14:43:17
Message: <3c13bed5@news.povray.org>
That
Well, if you want to be physically accurate I can't help you. I only
provided a solution that works so it looks right.
> sooo sloooow.
I often forget I'm running at 1.33GHz... :)
You're welcome.
Date: 10 Dec 2001 04:34:40
Message: <3c1481b0@news.povray.org>
news:3c13bed5@news.povray.org...
> > it's sooo sloooow.
Try replacing the plane in the scene you sent with this:
union {
    box {<-999, 89.5, -999><-150.1, 0, 999> }
    box {<-89.9, 89.5, -999><999, 0, 999> }
    box {<-150.1, 89.5, -999><-89.9, 0, 135.4> }
    box {<-150.1, 89.5, 185.6><-89.9, 0, 999> }
  difference {
    box {<-150.1, 89.5, 185.6><-89.9, 0, 135.4> }
    box {<-150, 89.6, 185.5><-90, 69.5, 135.5> }
and you'll see that some things are slow even with 1.33GHz. Tracing that is
at least ten times slower than it was with just a plane. I guess there's no
way to optimize that difference. :(
Ari-Matti
(PS. Hmm.. I wounder what happens, if I put some glass objects in my
kitchen, increase the max_trace_level to make them trace correctly AND use
the blurred reflection with I < 50. ;) )
Date: 10 Dec 2001 11:48:24
Message: <3c14e758@news.povray.org>
Do NOT use blurred reflection on transparent objects. It's TOO slow to
fathom.
Date: 14 Dec 2001 18:24:07
Message: <3c1a8a17@news.povray.org>
Hi
I got stuck playing with the lighting. Still haven't finished the faucet.
And I have to some plates, pots, glasses etc. It's a shame the multiple
instances are gone.
This version was done with that Dynamic Range Compression magic. A bit dark
I guess.. All lighting experts, the stage is yours.
Btw. the only way to get rid of the moire seems to be a four times bigger
picture scaled down and man it takes long. One test without reflections was
nearly a day. Thanks to all who gave suggestions to the earlier problems. :)
Ari-Matti
Download 'k.jpg' (45 KB)
Preview of image 'k.jpg'
Date: 14 Dec 2001 18:52:22
Message: <3C1A8EC7.A396E17A@scifi-fantasy.com>
Hmm...I think the sink's a little small for the cabinets/light/tiles...
Other than that, I like it.  Needs more clutter, tho, to add realism ;)
Tim Cook
Version: 3.12
Date: 15 Dec 2001 06:07:24
Message: <3C1B2F05.3E150CF6@engineer.com>
This definitely has that extra touch of realism that is missing
in plain vanilla renderings. The tube doesn't seem to be 36x1
in dimensions though, and my previous advice on the fade_distance
doesn't apply here unless you recalculated for the new geometry.
This a challenging scene for radiosity. Is the whole room modelled?
Just blank walls are enough for the out-of-frame parts and maybe
black patches for the window(s). The tonal balance looks ok for
sRGB image but more color variations would be nice. For the moire
I would try blurred version of the normal as normal map. If you
add glass to the scene the render time will explode unless it's
done is two steps.
The http news are broken at the moment so here's a NS link to
a thread where this glass and radiosity issue came up:
news://news.povray.org/3be39102%40news.povray.org
news://news.povray.org/3be532ca%40news.povray.org
First save the rad data from a "quick glass" render and reuse
it in the final render. The image is not important here so 1/2
resolution should be enough. Set glass or transparent objects like
this when saving rad data:
max_trace_level recursion_limit+1 (may need to be higher)
diffuse 0 ambient 0
no normal
no reflection
Then set them back to normal and:
load_file "rad.dat" always_sample off pretrace_start 1 pretrace_end 1
_____________
Kari Kivisalo
Date: 15 Dec 2001 13:49:52
Message: <3c1b9b50@news.povray.org>
> instances are gone.
> dark I guess.. All lighting experts, the stage is yours.
  Very good lighting! What is the scene scale, and what fade_distance you
used? (only curious)
Date: 15 Dec 2001 17:17:21
Message: <3c1bcbf1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:3c1b9b50@news.povray.org...
> you used? (only curious)
Thanks. Scale is 1 pov-unit = 1 centimeter. fade_distance is about 3 for
every light source and the lamp has four of them.
Ari-Matti
Date: 16 Dec 2001 03:29:59
Message: <3c1c5b87@news.povray.org>
"Kari Kivisalo" <ray### [at] engineercom> wrote in message
news:3C1B2F05.3E150CF6@engineer.com...
> The tube doesn't seem to be 36x1 in dimensions though, and my
> previous advice on the fade_distance doesn't apply here unless you
The "tube" you see is actually the plastic cover of the lamp. Inside it is a
35 units long cylinder with the same diameter so the fade_distance is
roughly 3.
> Is the whole room modelled? Just blank walls are enough for the
> out-of-frame parts and maybe black patches for the window(s).
Yep. White walls, no windows because I thought they wouldn't make a
difference.
> If you add glass to the scene the render time will explode unless it's
> done is two steps.
I've been using this with glass objects since it was discussed here. It's
been a really great help.
But how about reflective surfaces in general? A quick test shows that you
could trace any scene with this method. It's really fast because without
reflections you can use a lower max_trace_level and get the same result.
See the picture. The upper half was done in one trace with max_trace_level 7
(2m37s) and the lower was done in two traces, first save radiosity without
reflections with max_trace_level 4 (48s)and then load it with reflections
and max_trace_level 7 (19s). Difference in time is 1m30s and in quality
unnoticable.
Ari-Matti
Download 'Balls3.jpg' (36 KB)
Preview of image 'Balls3.jpg'
Date: 16 Dec 2001 05:43:33
Message: <3c1c7ad4@news.povray.org>
  Nice: we use the same scale! I'm also using lately very short values for
fade_distance and very high color intensities, always with fade_power 2.
It seems to work very well for realism.
