POV-Ray : Newsgroups : povray.binaries.images : Isosruf Again :o) Server Time
18 Oct 2026 05:45:22 EDT (-0400)
  Isosruf Again :o) (Message 1 to 10 of 10)
Subject: Isosruf Again :o)
Date: 25 Nov 2001 17:04:57
Message: <3c016b09@news.povray.org>
A closer look, with the "open" option.
36hours (SIGH!) on Pentium200, 96MB RAM
Download 'iso01.JPG' (55 KB)
Preview of image 'iso01.JPG'
Subject: Re: Isosruf Again :o)
Date: 25 Nov 2001 17:31:11
Message: <3c01712f@news.povray.org>
"Galy" <gal### [at] inwindit> wrote in message news:3c016b09@news.povray.org...
What kind of function is this anyway? Looks interesting...
    Frits van Bommel
Date: 25 Nov 2001 18:15:27
Message: <3c017b8e@news.povray.org>
Galy <gal### [at] inwindit> wrote:
: 36hours
  Could you post the source so that we could see if that render time could
be drastically reduced (with no change in the image, of course)?
Date: 26 Nov 2001 02:16:28
Message: <slrna03eol.st.steve@zero-pps.localdomain>
Now fill those cones with emitting media and you've got
some beautiful fireworks, but you'll need to make it night
time aswell:-)
Nice work.
  3:45am  up 48 days, 19:29,  1 user,  load average: 1.00, 1.00, 1.00
Date: 26 Nov 2001 13:28:11
Message: <3c0289bb@news.povray.org>
background { color rgb <0.5, 0.7, 1> }
  location  <0.0, 2.0, -20.0>
  look_at   <0.0, 0.0,  1.0>
          // create a regular point light source
light_source {
  0*x                  // light's position (translated below)
  color rgb <1,1,1>    // light's color
  translate <0, 10, -20>
// create a isosurface object - the equipotential surface
// of a 3D math function f(x, y, z)
#declare fn_X = function(x,y,z,tau) {
8*(x^2-tau^4*y^2)*(y^2-tau^4*z^2)*(z^2-tau^4*x^2)*(x^4+y^4+z^4-2*(x^2*y^2+y^
2*z^2+z^2*x^2))+(3+5*tau)*(x^2+y^2+z^2-1)^2*(x^2+y^2+z^2-(2-tau))^2 }
isosurface {
 function { fn_X(x, y, z,(1+sqrt(5))/2) }        // alternative declared
function
  contained_by { sphere { 0, 3 } }  // container shape
  accuracy 0.001                      // accuracy of calculation [0.001]
  max_gradient 3445031.481                      // maximum gradient the
function can have [1.1]
// evaluate 1, 1.2, 0.99             // evaluate the maximum gradient
 open
 material {
     pigment { color rgb <0.2, 0.7, 0.2> }
     finish {
       ambient 0.3          // ambient surface reflection color [0.1]
       diffuse 0.6          // amount [0.6]
       phong 0.5          // amount [0.0]
       phong_size 40      // (1.0..250+) (dull->highly polished) [40]
       reflection {
      //0.0                      // minimal reflection value (for variable
reflection)
      1.0                        // reflection amount (maximum for variable
reflection)
        fresnel on               // realistic variable reflection
        falloff 1.0              // falloff exponent for variable reflection
        exponent 1.0             // influence surface reflection
characteristic
        metallic 1.0             // tint reflection in surface color
  rotate y*30
  scale 3
Date: 26 Nov 2001 13:33:38
Message: <3c028b02@news.povray.org>
Here's the code.
If i fill the cones with emitting media (and i doubt i could do such a
thing), i will render 'til next year. :o)
Obviously i find the function on a manual. :o)
Download 'prova_suse6_4.pov.txt' (2 KB)
Date: 26 Nov 2001 15:00:19
Message: <3c029f53@news.povray.org>
Galy schrieb in Nachricht <3c0289bb@news.povray.org>...
OMG! Are you sure you need a that high max_gradient? Even if evaluate
reported this for you - did you try to cut it down by half or something?
Will save you lots of rendertime and most of the time will make no
difference. Only if you get holes in your Iso, you should be worried about
your max_gradient.
Marc-Hendrik
Date: 26 Nov 2001 17:07:55
Message: <slrna05f30.2ca.steve@zero-pps.localdomain>
On Mon, 26 Nov 2001 19:38:27 +0100, Galy wrote:
>Here's the code.
Thanks for posting the code, I'll have a look at it.
 10:03pm  up 49 days, 13:47,  1 user,  load average: 1.00, 1.00, 1.00
Date: 27 Nov 2001 03:37:58
Message: <3c0350e6@news.povray.org>
Ehm, in fact i used the max_gradient reported by "evaluate".
Maybe you're right, I'll do a test with a much smaller one.
Tnx
Date: 27 Nov 2001 23:42:45
Message: <3c046b45@news.povray.org>
Try the below code.  The rendering speed is about 5 times
faster than that of the original on my PC.
The gradient values near the origin is extremely smaller
than those near the container surface.
In such cases, it is better to calculate them separately.
The below code is not well optimized.  Combination with other
techniques might increase the speed further.
c.f. http://news.povray.org/3bc417a4@news.povray.org
     http://news.povray.org/3bd7f6e8$1@news.povray.org
R. Suzuki
#include "functions.inc"
light_source {
  0*x
  color rgb <1,1,1>
  *(x^4+y^4+z^4-2*(x^2*y^2+y^2*z^2+z^2*x^2))
#macro ISO1(R1, R2, max_g, Open_flg)
  isosurface {
    function {fn_X(x,y,z,(1+sqrt(5))/2) & -f_sphere(x,y,z,R1)*max_g}
    contained_by { sphere { 0, R2 } }
    accuracy 0.001
    max_gradient max_g
  //evaluate 100, 1.20, 0.99
  #if (Open_flg)
    open
object{
  union{
    difference{
      ISO1(2.49, 3.0, 3445031.481, on)
      sphere{ 0, 2.5 }
    ISO1(1.9, 2.5, 330000., on)
    ISO1(1.4, 1.9, 13000., off)
    ISO1(1.0, 1.4, 1500., off)
    ISO1(0.72, 1.0, 70., off)
    ISO1(0.6, 0.72, 5., off)
 material {
     finish {
       reflection {
      //0.0
      1.0
        fresnel on
        falloff 1.0
        exponent 1.0
        metallic 1.0
  rotate y*30
  scale 3
