Mucking about with date algorithms.
The following macros will generate a calendar as a string object union for a
specified month/year (yucky example attached):
#macro MakeTOU(MyStr, YTrans) // modify this according to taste
text {
ttf // font type (only TrueType format for now)
"crystal.ttf", // Microsoft Windows-format TrueType font file name
MyStr, // the string to create
1, // the extrusion depth
0 // inter-character spacing
translate y*YTrans
#macro MakeCal(Year, Month) // main date algo. macro
#local YTrans = 0;
#local YChange = 1.5;
#local TempStr = "";
#local Months = array[12]{
"January","Febuary","March","April",
"May","June","July","August",
"September","October","November","December"
#local Days = array[7]{"Su","Mo","Tu","We","Th","Fr","Sa"};
#local Day = 1;
#local RealYear = Year;
#if (Month < 3)
#local Month = Month + 12;
#local Year=Year-1;
#local JulDay = Day + int((153 * Month - 457) / 5) + 365 * Year + floor(Year /
4) -
floor(Year / 100) + floor(Year / 400) + 1721118.5;
MakeTOU(concat(Months[Month-1], " ",str(RealYear,0,0)), YTrans)
#local YTrans = YTrans - YChange;
#local Temp = 0;
#while(Temp<7)
#local TempStr=concat(TempStr,Days[Temp], " ")
#local Temp = Temp+1;
MakeTOU(TempStr, YTrans)
#local TempStr= "";
#local JulDay = JulDay - 1;
#local LastDay = -1;
#local CalDay = 0;
#local First = 1;
#while(LastDay < CalDay)
#local LastDay = CalDay;
#local JulDay = JulDay + 1;
#local ModDInt = floor(mod(JulDay + 2, 7));
#local Z = floor(JulDay - 1721118.5);
#local R = JulDay - 1721118.5 - Z;
#local G = Z - 0.25;
#local A = floor(G / 36524.25);
#local B = A - floor(A / 4);
#local CalYear = floor((B+G) / 365.25);
#local C = B + Z - floor(365.25 * CalYear);
#local CalMonth = int((5 * C + 456) / 153);
#local CalDay = C - int((153 * CalMonth - 457) / 5) + R;
#if (CalMonth > 12)
#local CalYear = CalYear + 1;
#local CalMonth = CalMonth - 12;
#if(First | CalDay > 1)
#local First = 0;
#if(CalDay = 1)
#local Temp = 0;
#while (Temp < ModDInt)
#local TempStr = concat(TempStr, " ")
#local Temp = Temp + 1;
#local TempStr = concat(TempStr, str(CalDay,2,0)," ")
#if(ModDInt = 6)
union{ // example
MakeCal(2001,6)
pigment{Red}
translate x*-7
translate y*4
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Download 'c1.jpg' (11 KB)
Preview of image 'c1.jpg'
The week starts with Monday!!!
I don't work at Sundays ... why does everybody do this wrong ?
SCNR ....
Jan Walzer <jan### [at] lzer net>
Moving :
to the line above:
#if (Month < 3)
prevents an error for the months jan and feb.
Ingo
Pov-Ray : http://members.home.nl/seed7/
Jan Walzer schrieb in Nachricht <3bfbe9a9@news.povray.org>...
OT: Do you have to earn your free day by the work of the week or do you get
it for free and therefore are able to work the next few days?
Marc-Hendrik
"ingo" <ing### [at] home nl> wrote in message
news:Xns### [at] povray org...
> Moving :
> to the line above:
> #if (Month < 3)
> Ingo
Already dealt with - RealYear is a copy of Year prior to the jan-mar thing -
However, your suggestion save needing RealYear in the first place... Ta.
I've got a bit of enhancement and optomising to do, and will post an update
later.
"Jan Walzer" <jan### [at] lzer net> wrote in message
news:3bfbe9a9@news.povray.org...
I'll parametise that in the next version (as well as height-offset and
suchlike).
"Tom Melly" <tom### [at] tomandlu co uk> wrote in message
news:3bfbe3ff@news.povray.org...
Do you have the getdate.bat system to make povray read the system clock
and generate today's calendar?
Okay, posted improved version with more params to b.scene-files...
"Bill DeWitt" <bde### [at] cfl rr com> wrote in message
news:3bfc0b26$1@news.povray.org...
clock
No, the scene uses pov lang to implement algorithms I found on a website (or
did you mean in general?)
intereting idea, now I have to make a nice background for mine.....
G.
Tom Melly <tom### [at] tomandlu co uk> wrote in message
a
> text {
> translate y*YTrans
> #end
> #local YTrans = 0;
> #local Day = 1;
> #if (Month < 3)
> #local Year=Year-1;
> #end
floor(Year /
> 4) -
> #local Temp = 0;
> #while(Temp<7)
> #end
> #local TempStr= "";
> #local CalDay = 0;
> #local First = 1;
> #if (CalMonth > 12)
> #end
> #local First = 0;
> #if(CalDay = 1)
> #local Temp = 0;
> #end
> #end
> #if(ModDInt = 6)
> #end
> #end
> #end
> #end
> union{ // example
> MakeCal(2001,6)
> pigment{Red}
> translate x*-7
> translate y*4
Jan Walzer scribis news:3bfbe9a9@news.povray.org:
hy should your work week decide how the calendar looks? Just why do you
think they are called "Weekends" Sunday is the start and Saturday is the
finish.
Gis poste, Arto.
> finish.
No! ... They both are called weekend, because they are at the END of the WEEK
Or don't you call sunday a weekend-day ? Is it a weekstart-day for you ?
news:3bfc39a8$1@news.povray.org...
> clock
(or
What I mean is do you have that system so that you can add it to your
macro to allow it to read the system clock and maybe highlight today's date
or automatically make the right month unless you tell it otherwise? If not I
can tell you how to do it.
> are at the END of the WEEK ... Or don't you call
Ends, plural. A line segment (in this case, the work
week) has two ends. Hence weekend, similar to bookend,
is at either locus.
Tim Cook
Version: 3.12
news:3bfc8c28$1@news.povray.org...
date
I
Ah! No, but it might be a nice option - I could implement it through a batch
file and pov i/o I suppose. I can't think of any cross-platform way apart
from using perl, but then that ties it to having perl installed. Would your
method be cross-platform?
"blessing" <ble### [at] icefog net> wrote in message
news:3bfc5e3c@news.povray.org...
I've posted a better version to bin.scene-files...
"Tom Melly" <tom### [at] tomandlu co uk> wrote :
> Would your
There are other platforms?
I imagine that other platforms have ways of calling small batch programs
that write text files which contain the date and time. You have the pov.ini
run them, then read them in the pov script i/o functions. Including cross
platform instructions in the comments would make it cross platform.
On Wed, 21 Nov 2001 18:52:58 +0100, "Jan Walzer" <jan### [at] lzer net>
Yup. Sunday is the 7th day. Even the bible has this correct.
nospam schrieb in Nachricht <3bfea719.14298978@localhost>...
Sorry, that's not correct. It's Saturday in the bible - as the Jews
celebrate it. Sunday as the day of the lord is caused by Easter and JC
resurrection.
Marc-Hendrik
> >On Wed, 21 Nov 2001 18:52:58 +0100, "Jan Walzer" <jan### [at] lzer net> wrote:
quoth PeterC:
(and a few Christians)
> resurrection.
Well, I doubt that the Bible ever mentions "Saturday" or "Sunday" by
those names. But it's clear, isn't it?, that the crucifixion (Good
Friday) was on the "day of preparation", i.e. the day before the "day of
rest" -- which is still called something like `sabbat' in some Romance
languages as well as Hebrew.
Anton Sherwood -- http://www.ogre.nu/ (online again, Nov.19)
Anton Sherwood schrieb in Nachricht <3C0091B0.E2CDEFDE@pobox.com>...
Of course, the bible does not mention those names, which are of
Latin-Germanic origin if I'm not mistaken (Thursday = Thor's day, Friday =
Freya's day etc.).
I may misunderstand you, but I was not talking about the crucifixion, but
the resurrection of J.C. which is celebrated each Sunday.
But to be honest: It is absolutely arbitrary which day one chooses to let
the week begin, isn't it?
Marc-Hendrik
Not if we want to keep on calling saturday/sunday the week-end. :-)
Anyway, there is a European Standard that specifies, that the week
starts on monday, so in Europe at least, it is official. Don't know
about the rest of the world.
/Ib
>> ... it's clear, isn't it?, that the crucifixion (Good Friday) was on
>> the "day of preparation", i.e. the day before the "day of rest" ...
> but the resurrection of J.C. which is celebrated each Sunday.
I'm no Bible expert; the crucifixion is the only link I know between the
ancient Jewish week and the modern week. If the crucifixion was the day
before "the day of rest", then the resurrection must be the day after.
Anton Sherwood schrieb in Nachricht <3C00D412.1F9AAB7A@pobox.com>...
So we agree and I got you partly wrong.
Marc-Hendrik
"On the third day he rose again", so could be the day after the day
after... depends on if you count the day he was buried as the first day or
not.
But standard calendars have the week ends in their proper places, at
both ends of the week. The week starts at one end on Sunday and goes through
the other end which is Saturday.
> or not.
Zero-based indexing is rare in the ancient world; that bit, at least, is
uncontroversial: the cross-raising was day 1 (Friday), the resurrection
day 3 (Sunday).
> at both ends of the week. The week starts at one end on Sunday and goes
> through the other end which is Saturday.
American standard, yes, but evidently not Eurostandard.
