POV-Ray : Newsgroups : povray.binaries.images : border lines are missing [82.7kb] Server Time
10 Apr 2026 09:47:08 EDT (-0400)
  border lines are missing [82.7kb] (Message 1 to 10 of 18)
Subject: border lines are missing [82.7kb]
Date: 24 Oct 2001 09:38:09
Message: <3bd6c430@news.povray.org>
a pic to my question in povray.newusers
Download 'disklines.jpg' (83 KB)
Preview of image 'disklines.jpg'
Subject: Re: border lines are missing [82.7kb]
Date: 24 Oct 2001 11:40:16
Message: <3bd6e0e0$1@news.povray.org>
"marabou" <not### [at] availableyet> wrote in message
news:3bd6c430@news.povray.org...
    I haven't read you newusers post, but it looks like a case of AA
erasure. The line is so small the effect of anti-Aliasing completely erases
it. At a different angle, it will probably show up again.
Date: 24 Oct 2001 11:55:57
Message: <3bd6e48c@news.povray.org>
> erases it. At a different angle, it will probably show up again.
would you explain what this mean:
erases it.
Date: 24 Oct 2001 11:57:39
Message: <3BD6E4BF.C9F748C7@aol.com>
Glad to see you back, old fart.
Date: 24 Oct 2001 11:58:11
Message: <3BD6E4DF.6A164469@aol.com>
Repeat your image at 800 x 600.
Date: 24 Oct 2001 12:08:08
Message: <3bd6e768$1@news.povray.org>
news:3bd6e48c@news.povray.org...
> erases it.
    If a line or a point is smaller than a pixel or so, the averaging of the
color values of the pixels surrounding it makes it fade into insignificance,
ie: Erasure.
Date: 24 Oct 2001 12:26:21
Message: <3BD6EBAB.3816042C@gmx.de>
> ie: Erasure.
But this is not solved by not using AA.  In fact (as someone mentioned in
.newusers), AA usually helps to make it better visible.
Date: 24 Oct 2001 13:24:46
Message: <3bd6f95e@news.povray.org>
later i used the option +a0.0 after trevor quayle inspired me to do.
now i see the lines but they look ugly.
Date: 24 Oct 2001 13:31:20
Message: <3bd6fae8@news.povray.org>
news:3BD6EBAB.3816042C@gmx.de...
the
insignificance,
> > ie: Erasure.
    I am not sure what you are saying, but sometimes lines disappear because
of AA. Here is an example (image below). The only way to fix this particular
example is to make the "edge" a little larger.
////////////// Camera //////////////////////
camera {                                  //
        right      < -1.333, 0.0, 0.0 >   //
        up         <  0.0, 1.0, 0.0 >     //
        direction  <  0.0, 0.0, 1.0 >     //
        location   <  2.0, 3.0, 5.0 >/2   //
        look_at    <  0.0, 1.0, 0.0 >     //
////////////// end Camera //////////////////
///////////////  Light  ////////////////
light_source { < -100.0, 100.0, 100.0 >
color rgb < 1.0, 1.0, 1.0 > }
light_source { <  -100.0, 100.0, -100.0 >
#declare edge = 0.0015;
box {
  <-1, -1, -1>  // one corner position <X1 Y1 Z1>
  < 1,  1,  1>  // other corner position <X2 Y2 Z2>
  pigment { rgb 0.75 }
  translate < 0.5, 0.0, 0.0 >
box {
Download 'AA Line Test.jpg' (16 KB)
Preview of image 'AA Line Test.jpg'
Date: 24 Oct 2001 13:32:42
Message: <3bd6fb3a$1@news.povray.org>
Yes, when you have very thin lines like that, even AA does not always
achieve what you would hope for as the program and the final output is
ultimately limited by the resolution of the image. Tthe best bet then is, as
someone else mentioned, is increase the resolution of your image.
-tgq
news:3bd6f95e@news.povray.org...
