POV-Ray : Newsgroups : povray.binaries.images : Path with sphere attached. . . Server Time
12 Nov 2026 05:26:16 EST (-0500)
  Path with sphere attached. . . (Message 1 to 16 of 16)
Subject: Path with sphere attached. . .
Date: 21 Oct 2001 09:58:42
Message: <3bd2d492@news.povray.org>
Okay, this note may get a little complicated so forgive me if I confuse you.
I have written a macro that makes stacks of rings of spheres as seen in the
attached image.  The macro adjusts the radius of the spheres in a ring
dependant on the radius of the ring because I wanted to make sure that all
spheres are tangential (touching each other at a tangent).
Now, what I would like to do is at the top of the "cylinder of spheres" is
start to make the rings, but so that every stack of it fits the profile i
have drawn in.  Figuring out what the radius of the ring should be and the y
value of the ring is very difficult for me--especially since the sphere's
radius changes as the ring's radius gets smaller.  I have attempted to
figure this out and in the second attached image you can see my initial
approach.
Initially I have thought to define a "path" for the profile by a polynomial
equation.  I would then input an x-coordinate value into the function with
the equation and I would get a y-coordinate as an output.  The problem is
that when you actually go and make this a macro, how can I determine the
change in the x value so it will give me the correct y value and STILL have
the sphere be tangential?   In other words how do I determine the
x-coordinate to input into the function that gives me the appropriate y
value?  Well I imagined that the change in x could be (as shown in the
diagram):
radius1*(sin theta1) + radius2(sin theta2)
I have figured out how to determine the radius for each sphere of any ring
size, but I simply can not figure out how to determine the "thetas" of which
to use for my equation.  Am I way off?  Is there an easier way to do this?
F. Audet has put up his Apple code which does something similar, and I have
looked at it, but I am trying to understand how I can figure the math so
that I can become more adept at making what I want.  Thanks for your time
and help I appreciate it a great deal since it has helped me realize the
images I see in my head :)
Arie
Download 'pathSpheres.jpg' (43 KB) Download 'cylinderSpheres.jpg' (63 KB)
Preview of image 'pathSpheres.jpg'
Preview of image 'cylinderSpheres.jpg'
Subject: Re: Path with sphere attached. . . [MORE PROGRESS]
Date: 21 Oct 2001 13:51:47
Message: <3bd30b33@news.povray.org>
While muddling around, I have come up with this.  You can start see the
effect I am after, but this is truly a linear inclination.  I am looking to
acheive a curved inclination all the while my spheres remain tangential.  I
just can't get enough of this stuff.
Arie
"Arie L. Stavchansky" <ari### [at] bellatlanticnet> wrote in message
news:3bd2d492@news.povray.org...
you.
the
y
> approach.
polynomial
have
> diagram):
which
have
> Arie
Download 'capTop.jpg' (81 KB) Download 'capPersp.jpg' (43 KB)
Preview of image 'capTop.jpg'
Preview of image 'capPersp.jpg'
Subject: Re: Path with spheres...
Date: 21 Oct 2001 18:45:21
Message: <3BD34F21.8F12DD0@sympatico.ca>
> Arie
Hello Arie !  Pretty nicely done job,  even if the goal you want to reach
is a curved profile.  I find it very cool the way each sphere is tangantial
to each others...  My macro don't work that perfectly.
(I posted another one. It is called dancer!)
Alex P
have a look at:  ( some sphere modeling techniques stuff...)
http://astronomy.swin.edu.au/pbourke/modelling/spheremodel/
http://astronomy.swin.edu.au/pbourke/curves/classical/
Download 'us-ascii' (2 KB)
Date: 21 Oct 2001 19:07:10
Message: <3bd3551e$1@news.povray.org>
Thanks you Alex!  This is an excellent resource.  I appreciate it :)
Arie
"F.Audet" <flo### [at] sympaticoca> wrote in message
news:3BD### [at] sympaticoca...
Arie
Alex P
Date: 21 Oct 2001 19:34:22
Message: <3BD35AA2.F96EE2B4@sympatico.ca>
> Arie
Oups,  I read the other post before !!
Alex
Date: 22 Oct 2001 01:26:57
Message: <5ogF3FAU0607EwQ5@econym.demon.co.uk>
>approach.
>diagram):
I think it gets rather messy, but here are a few pointers:-
Firstly, note that the green lines in your diagram are parallel, so
theta1 and theta2 are equal. So
1.      x = (r1 + r2)*sin theta
Now consider the ratio of r2 to r1. Because there are the same number of
spheres in each ring, the size of the spheres decreases by the same
ratio as the radius of the ring. Call the radius of the first ring "R",
then
2.      r2/r1 = (R-x)/R
The polynomial path that you are trying to follow provides the
relationship between y and x
3.      y = p(x)
And we can see that
4.      tan theta = x/y
The values of r1 and R are known, so we now have a system of four
simultaneous equations involving four unknowns (x, y, r2, theta).
Reducing these gives (if my algebra is correct)
5.      x = (r1 + (R - x)/(R * r1)) * sin(atan(x/p(x))
That's a horribly messy equation, but the only unknown in there is x, so
it should be soluble. The method of solution may well depend on the
nature of p(x). Good luck!
Once you've calculated x, obtain y from #3, r2 from #2, and theta (not
that you need it) from #4.
Mike Williams
Gentleman of Leisure
Date: 22 Oct 2001 10:54:03
Message: <3bd4330b@news.povray.org>
Thank you Mike.  I have been messing around and thinking about you tips.  I
think I'm almost there :)
Take a look
Arie
Download 'sphereBowl.jpg' (24 KB)
Preview of image 'sphereBowl.jpg'
Date: 22 Oct 2001 16:24:31
Message: <3bd4807f$1@news.povray.org>
Hi Mike,
I have been looking at your equations and am confused on equation number
How can you define x with x in the right side of the equation?
Thanks,
Arie
"Mike Williams" <mik### [at] nospamplease> wrote in message
news:5og### [at] econymdemoncouk...
you.
the
all
is
the y
> >approach.
polynomial
with
have
> >diagram):
ring
which
this?
have
> then
> 2.      r2/r1 = (R-x)/R
> 3.      y = p(x)
> And we can see that
> 4.      tan theta = x/y
> Mike Williams
Date: 22 Oct 2001 21:18:15
Message: <kp1SnAAHoL17EwLs@econym.demon.co.uk>
>Hi Mike,
That's the problem. That's what you get if you reduce the simultaneous
equations. I can't do any better it without knowing p(x).
Does it help if I rearrange it like this?
5a.      x - (r1 + (R - x)/(R * r1)) * sin(atan(x/p(x)) = 0
Even if someone tells me what p(x) is, it's still going to be horrible
to solve for x. I'd be inclined to use some sort of numerical method to
obtain an approximation.
Mike Williams
Date: 22 Oct 2001 21:23:39
Message: <3BD4C662.3ADE1FF1@hotmail.com>
"Arie L. Stavchansky" wrote:
> Hi Mike,
Like if you say:
2*x + 1 = x
Now if you rearrange then you'll get:
2*x - x + 1 = 0   =>   x + 1 = 0   =>   x = -1
So he probably meant that you should
solve this equation with respect to x:
(r1 + (R - x)/R/r1)*sin(atan(x/p(x))) - x = 0
Unfortunately; I suspect that it is rather non-
trivial to find analytical solutions for it
(especially with higher degrees of your polynome).
Tor Olav
Date: 22 Oct 2001 22:01:04
Message: <3BD4CF24.E431ECCB@hotmail.com>
I too thought there was a need to solve this
numerically, so I started working on some
macros that'll do the work.
See code below. The macros are not finished.
(E.g.: No detection of non-convergence yet.)
I have a suspicion that the RegulaFalsi
method is the best candidate for the job.
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 =
// Copyright 2001 by Tor Olav Kristensen
// mailto:tor### [at] hotmailcom
// http://www.crosswinds.net/~tok
#version 3.5;
// The macros
// Fn: The function to find a root for.
// Xa: x-value that are believed to be close to the root.
// Epsilon: Value that are "close enough" to zero for your use.
#macro NewtonRaphson(Fn, Xa, Epsilon)
  #local DerFn = function(x, H) { (Fn(x + H) - Fn(x - H))/2/H }
  #local IterFn = function(x, H) { x - Fn(x)/DerFn(x, H) }
  #local hh = Xa/100;
  #local x0 = Xa;
  #local f0 = Fn(x0);
  #while (abs(f0) > Epsilon)
    #local x0 = IterFn(x0, hh);
    #local f0 = Fn(x0);
    #debug ":"
  #end // while
  (x0)
#end // macro NewtonRaphson
// Xa: x-value that are believed to be on one side of the root.
// Xb: x-value that are believed to be on the other side of the root.
#macro RegulaFalsi(Fn, Xa, Xb, Epsilon)
  #local x1 = Xa;
  #local f1 = Fn(x1);
  #local x2 = Xb;
  #local f2 = Fn(x2);
  #local x3 = (x1*f2 - x2*f1)/(f2 - f1);
  #local f3 = Fn(x3);
  #if (f1*f2 > 0)
    #error "Macro RegulaFalsi: Endpoints does not bracket the root"
  #else
    #while (abs(f3) > Epsilon)
      #if (f1*f3 < 0)
        #local x2 = x3;
        #local f2 = f3;
      #else
        #if (f2*f3 < 0)
          #local x1 = x3;
          #local f1 = f3;
        #else
          #error "Macro RegulaFalsi: Maybe Epsilion is negative ?"
        #end // if
      #end // if
      #local f3 = Fn(x3);
      #debug ":"
    #end // while
  #end // if
  (x3)
#end // macro RegulaFalsi
#macro Bisection(Fn, Xa, Xb, Epsilon)
  #local x1 = Xa;
  #local f1 = Fn(x1);
  #local x2 = Xb;
  #local f2 = Fn(x2);
  #local x3 = (x1 + x2)/2;
  #local f3 = Fn(x3);
  #if (f1*f2 > 0)
    #error "Macro Bisection: Endpoints does not bracket the root"
  #else
      #if (f1*f3 < 0)
        #local x2 = x3;
        #local f2 = f3;
      #else
        #if (f2*f3 < 0)
          #local x1 = x3;
          #local f1 = f3;
        #else
          #error "Macro Bisection: Maybe Epsilion is negative ?"
        #end // if
      #end // if
      #local f3 = Fn(x3);
      #debug ":"
    #end // while
  #end // if
  (x3)
#end // macro Bisection
// Sample usage
#declare Fn = function(x) { 3*x^3 - 5*x^2 + x - 1 }
#declare CR = 0.000001; // Convergence criterion
#debug "\n"
#debug "\n"
#declare Root = NewtonRaphson(function(x) { Fn(x) }, -2, CR);
#debug str(Root, 0, -1)
#debug "\n"
#declare Root = RegulaFalsi(function(x) { Fn(x) }, -2, 3, CR);
#debug "\n"
#declare Root = Bisection(function(x) { Fn(x) }, -2, 3, CR);
#debug "\n"
#debug "\n"
Date: 24 Oct 2001 03:09:56
Message: <3bd66944$1@news.povray.org>
Oh yeah, that's what I was thinking :)
Seriously Tor, thanks for the efforts, but can you help a guy who was
educated in Design understand what RegulaFalsi is?  What does it mean to
solve something "numerically"?
Thanks,
Arie
Date: 25 Oct 2001 02:34:35
Message: <3BD7B3F7.EF09F96D@pobox.com>
> who was educated in Design understand what RegulaFalsi is?
> What does it mean to solve something "numerically"?
To abandon the search for a symbolic expression like "pi-ln(3)" and
settle for "well, it's between 2.0429 and 2.0430"; to try a rough
solution, see how far off it is, adjust proportionately and try again.
There are several versions of `adjust proportionately', applicable to
different kinds of problems.  In this case I'd use the secant method
(which is similar to regula falsi).
Start with
	x0 = the lowest reasonable value of x (zero?)
	x1 = the highest reasonable value of x (r1?)
Do this repeatedly:
	q0 = x0 - (r1 + (R - x0)/(R * r1)) * sin(atan(x0/p(x0))
	q1 = x1 - (r1 + (R - x1)/(R * r1)) * sin(atan(x1/p(x1))
	x2 = x1 - (x1-x0)*q1/(q1-q0)	//the fun bit
	x0 = x1; x1 = x2
until abs(q1) is small enough.
The line I've marked as "the fun bit" amounts to imagining that <x0,q0>
and <x1,q1> are plotted on a graph, drawing a line through them and
marking where it crosses the axis.  If q is well-behaved, the
crossing-point (x2) is a better guess than x0 or x1, so throw away the
oldest guess (x0).
Anton Sherwood
Date: 25 Oct 2001 03:03:21
Message: <3BD7BAB6.19FFFC0D@pobox.com>
> see the effect I am after, but this is truly a linear inclination.
> I am looking to acheive a curved inclination all the while my
> spheres remain tangential.  I just can't get enough of this stuff.
Hooked, eh?
If you want to keep the spheres one size (or roughly so),
you'll have to abandon the equal spacing of the green lines.
	r0 = radius of the spheres of the previous tier
	R0 = radius of the circle containing their centers
	n0 = how many are in that tier
	p(R) = your profile curve
	P(R) = its first derivative
In the next tier, as a first approximation,
	r1 = r0
	R1 = R0 - 2*r0 / sqrt(1+(P(R0))^2)	// i hope; i'm tired!
	n1 = round(n0*R1/R0)
This won't be an exact fit, but there are techniques for improving it
(which, unfortunately, are beyond my intelligence at this hour).
What is your desired profile curve, by the way?
For a different look, I might try adapting what others have called a
"Fibonacci spiral" (really the Fermat spiral with golden sector
sampling).
Anton Sherwood
Date: 25 Oct 2001 20:45:24
Message: <3BD8B1DF.82914778@hotmail.com>
Arie, I have thought about how to explain
what numerical methods are, but I find it
difficult to give a good explanation.
But here's my try at it anyway:
When one are solving a mathematical problem
analytically, one often manipulate SYMBOLS
that are describing the problem. The mani-
pulations are done according to a set of
rules that preserves the exact description
of the problem. (And by doing it this way,
any found solutions will be exact too.)
If the manipulations are done in an intelli-
gent way, each step of them will simplify the
problem, or parts of it, until simple
expressions containing the symbols are found.
But if one are solving a problem numerically,
one may start with a symbolic description of
the problem. And, sometimes, one thereafter
rewrites (and maybe simplifies) that
description a bit. Then one substitute
NUMBERS for some or all of the symbols in
the (modified) description and evaluate it.
(These numbers can be results of analysis,
guessing or measurements obtained from "the
real world".)
Often one can use the result of this
evaluation to determine how "far off" those
initial numbers are from a solution (i.e.
estimate the errors).
Some knowledge of similar problems can then
often be used to try to guess or estimate how
to alter those numbers in order to get closer
to a solution. If so, one may repeat the
process all over again and hope that a good-
enough solution appears (i.e. has an
acceptable error.)
If one find a solution to a problem, one
sometimes have enough information
to get closer to other solutions analytically.
If one succeeds doing this, one can then go
back and apply further numerical methods to
seek out other solutions (or more accurate
ones).
It is important to notice that with numerical
methods one does not get exact results if one
are using computers. This is because the
numbers involved are always either truncated
or rounded off. And also because some of the
calculations the computers perform are done
by numerical methods themselves or by
approximations of the mathematical operations.
I'll try to explain more about the mentioned
methods later.
Tor Olav
Btw:
Arie, did you read my reply to your question in
the "Not a sphere" thread (by Zebu 2. Oct.) ?
Here's a web page that you hopefully will
find interesting:
http://www.damtp.cam.ac.uk/user/fdl/people/sd/lectures/index.html
It contains links to some "Numerical Methods"
lecture notes by Stuart Dalziel.
There's a html version here:
http://www.damtp.cam.ac.uk/user/fdl/people/sd/lectures/nummeth98/index.htm
And if you look at this page;
http://www.damtp.cam.ac.uk/user/fdl/people/sd/lectures/nummeth98/roots.htm
- you'll find these sub-chapters(?):
"3.3 Linear interpolation (regula falsi)"
(Read the part "3.2 Bisection" first.)
"3.5 Secant (chord)"
(Read the part "3.4 Newton-Raphson" first.
- where he talks about the methods I and
Anton has mentioned.
It is often quite useful to study the graph-
images supplied within, while you are
figuring out what is _really_ going on.
Date: 31 Oct 2001 11:49:45
Message: <B80595D9.207E%arie@andrew.cmu.edu>
Hi Tor,
Thank you so much for your help and response.  I feel like this group
provides kinda of like an "underground" educational curriculum.  It's kinda
nice knowing that science and mathematics have something to do with the
visual arts.
I did read your answer to my question on "Not a sphere. . ." and understood
it.  Thank you for that response as well.  I have visited the sites you have
given me and will say that (for me) it will take a while to absorb the
material.  Thank you for answering my questions, it is greatly appreciated.
Arie
in article 3BD8B1DF.82914778@hotmail.com, Tor Olav Kristensen at
tor### [at] hotmailcom wrote on 10/25/01 7.44 PM:
> real world".)
> acceptable error.)
> ones).
> methods later.
> Tor Olav
> Btw:
> find interesting:
