POV-Ray : Newsgroups : povray.binaries.images : 3.5 Blurred Reflection Server Time
12 Nov 2026 05:26:16 EST (-0500)
  3.5 Blurred Reflection (Message 1 to 30 of 30)
Subject: 3.5 Blurred Reflection
Date: 16 Oct 2001 16:45:48
Message: <3bcc9c7c@news.povray.org>
Just experimenting with creating blurred reflections.  Comments?
-tgq
Download 'Blurred.jpg' (49 KB)
Preview of image 'Blurred.jpg'
Subject: Re: 3.5 Blurred Reflection
Date: 16 Oct 2001 16:53:26
Message: <3BCC9E52.F0D5360A@aol.com>
3.5 is NOT MegaPOV ; }
Date: 16 Oct 2001 16:53:34
Message: <3bcc9e4e@news.povray.org>
In this scene it looks pretty good, I must say. What are your aa settings
for that? Do you think this would work in every scene? Is the amount of
blurring *tunable* (sp?) ? The non-faked highlights look perfect.
Jonathan.
"Trevor Quayle" <Tin### [at] hotmailcom> ha scritto nel messaggio
news:3bcc9c7c@news.povray.org...
> -tgq
Date: 16 Oct 2001 16:55:55
Message: <3bcc9edb$1@news.povray.org>
...which is the interesting thing. Trevor did not use MegaPov, but simulated
blurred reflections with normals (I guess).
Jonathan.
"Dave Dunn" <poi### [at] aolcom> ha scritto nel messaggio
news:3BCC9E52.F0D5360A@aol.com...
Date: 16 Oct 2001 16:58:30
Message: <3BCC9F82.16E6EC98@aol.com>
Someone was just saying that the best jokes always fall flat...
Date: 16 Oct 2001 17:02:44
Message: <3bcca074@news.povray.org>
Uh? Sorry, I don't know why, but I didn't get it before... next time I will
check every ; } more than once before answering.
Jonathan.
news:3BCC9F82.16E6EC98@aol.com...
simulated
Date: 16 Oct 2001 17:03:10
Message: <3bcca08e@news.povray.org>
"Dave Dunn" <poi### [at] aolcom> wrote in message
simulated
    Jokes like that are no good unless someone doesn't get them.
Date: 16 Oct 2001 17:10:17
Message: <3BCCA245.D49E58B0@aol.com>
Seriously, it was a pretty amazing attempt to recreate one of my fave MegaPOV
features (which was the point since it didn't make its way into 3.5), and I
shouldn't have diminished the effort by horsing around. BTW, how was it done? I
am guessing a small amount of granite scaled verrrrry small...
Date: 16 Oct 2001 19:32:37
Message: <3bccc395@news.povray.org>
AA Setting were as follows:   Threshold 0.01, Method 2, Recursion 4
I have been trying to play with it but it is very hard to get rid of
artifacts even with really high AA settings.  This one used the bumps
normal, fresnel reflection and metallic reflection.  One of the problems
that can be slightly noticed is that at shallow angles, the blurred
reflection breaks down (i.e., becomes clearer, less blurred. I don't think
this reflects reality), I think this is beacause of the nature of normals.
I have been experimenting all around with super-realism, trying to use
reflection instead of specular highlighting and not using ambient lighting
(except as light sources) among other things.
Lots more work to do though.
-tgq
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3bcc9e4e@news.povray.org...
> Jonathan.
> > -tgq
Date: 17 Oct 2001 07:36:42
Message: <3bcd6d4a@news.povray.org>
verry nice, it looks like something with fine frost on it.
Gary
Trevor Quayle <Tin### [at] hotmailcom> wrote in message
> -tgq
Date: 17 Oct 2001 09:35:36
Message: <3BCD892B.2AAF86F8@engineer.com>
Can you do blurred transmission too?
_____________
Kari Kivisalo
Date: 17 Oct 2001 11:11:06
Message: <3bcd9f8a@news.povray.org>
Do you mean like this?
-tgq
"Kari Kivisalo" <ray### [at] engineercom> wrote in message
news:3BCD892B.2AAF86F8@engineer.com...
> _____________
> Kari Kivisalo
Download 'Sheet.jpg' (66 KB)
Preview of image 'Sheet.jpg'
Date: 17 Oct 2001 11:42:16
Message: <3BCDA6DB.2D767BA3@engineer.com>
Yes. Another key step towards realism :) I had plans to try
this with multiple averaged bumps at different base frequencies
but never got around calculating the required contributions
and scale factors.
_____________
Kari Kivisalo
Date: 17 Oct 2001 13:41:10
Message: <slrn9srglc.cb8.ron.parker@fwi.com>
>and scale factors.
Besides blurred transmission, there's another cool benefit to this method:
anisotropic blurring.
The first picture has no blurring.
The second picture has isotropic blurring.
The third picture has anisotropic blurring; the bumps are much taller than
they are wide.  In a way, the cylinder has lots of vertical microscratches.
Download 'blur-none.jpg' (51 KB) Download 'blur-isotropic.jpg' (33 KB) Download 'blur-anisotropic.jpg' (38 KB)
Preview of image 'blur-none.jpg'
Preview of image 'blur-isotropic.jpg'
Preview of image 'blur-anisotropic.jpg'
Date: 17 Oct 2001 14:30:21
Message: <3BCDCE3F.A794F6EB@engineer.com>
Didn't someone ask about brushed/machined metal textures?
Let's see some :)
_____________
Kari Kivisalo
Date: 17 Oct 2001 14:32:13
Message: <slrn9srjlf.ct6.ron.parker@fwi.com>
>Let's see some :)
Well, the downside of this is that it requires antialiasing for the whole
scene.  In my case, I rendered with +a0.0 +am2 +r5, which takes forever
even for that size image even on an Athlon 1.4GHz.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C)bicubic_patch{type 1u_steps 6
v_steps 6R(1)R(3)R(5)R(7)translate 9*z-2pigment{rgb z}}#end#macro _(Y)#local X=
asc(substr(C,Y,1))-65;<mod(X,4)div(X,4)>#end#local O=union{Q("ABEFUQWS")Q(// RON
"WSXTLOJN")}Q("JNKLCGCD")union{O}union{O translate 3*x}light_source{x 1}//PARKER
Date: 17 Oct 2001 14:34:52
Message: <3bcdcf4c@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> ha scritto nel messaggio
news:slr### [at] fwicom...
> >Let's see some :)
...which too bad does not make it likely to be used in *real* scenes :-(
Date: 17 Oct 2001 16:36:43
Message: <slrn9srqus.e3o.ron.parker@fwi.com>
>> >Let's see some :)
Here's another one, with slightly less blurring because I rendered it on
my P200 rather than my Athlon.  It's notable for the jaggy lines in the
checkerboard floor...
Rendered with a development build of 3.5, but with a custom patch.  Whether
that patch makes it into 3.5 or into the next MegaPOV is something I need to
discuss with some people.  Render time was 4:32, which isn't bad for a P200.
The cylinder was supersampled 25 times per ray (vs. 1089 for the images I
posted before.)
So what's so special about this patch compared to the old reflection blur?
Well, let's just say it's not limited to reflection, shall we?
Download 'jb.jpg' (20 KB)
Preview of image 'jb.jpg'
Date: 17 Oct 2001 16:44:00
Message: <3bcded90@news.povray.org>
> >> >Let's see some :)
whole
Whether
to
P200.
> posted before.)
*droooooooling*  :-|_
(something like stochastic raytracing?)
Jonathan.
Date: 17 Oct 2001 17:10:51
Message: <slrn9srsur.e53.ron.parker@fwi.com>
Sort of.  I've added a "supersample n,d" statement to the finish statement,
which causes POV to evaluate the texture n times while jittering the normal's
evaluation point within d of the actual evaluation point.  That means that,
if you have the CPU horsepower, you can do blurred isotropic reflection as
with the old patch, but also blurred anisotropic reflection, both kinds of
transmission, and maybe even real specular highlights, just by adding a
very small-scale normal to the surface.
I, of course, don't have that kind of horsepower.  But here's a sample of
blurred transmission that was within reach of my limited CPU.  The stats
are included for the curious:
Done Tracing
Statistics for blur.pov, Resolution 320 x 240
Pixels:           76800   Samples:           76800   Smpls/Pxl: 1.00
Rays:           1395150   Saved:                 0   Max Level: 3/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                            2726599         1054773     38.68
Cone/Cylinder                 10906396           22138      0.20
Plane                          5453198         2035619     37.33
Sphere                         2726599         2726599    100.00
Calls to Noise:            5679714   Calls to DNoise:        6998074
Shadow Ray Tests:         10651592   Succeeded:               794019
Refracted Rays:            1318350
Smallest Alloc:                 16 bytes   Largest:            12040
Peak memory used:            94390 bytes
Time For Trace:    0 hours  7 minutes  26.0 seconds (446 seconds)
    Total Time:    0 hours  7 minutes  26.0 seconds (446 seconds)
Download 'blur3.jpg' (21 KB)
Preview of image 'blur3.jpg'
Date: 17 Oct 2001 17:22:44
Message: <3bcdf6a4@news.povray.org>
Drroooool.... Ron, at least set things up to put it in the next MegaPOV...
pleeease... :)
Date: 17 Oct 2001 17:23:56
Message: <3bcdf6ec$1@news.povray.org>
blur?
statement,
normal's
that,
This surely has lots of applications... any chance to see it either in the
official release or in the next versions of MegaPov? (pleonastic
question...)
Jonathan.
Date: 17 Oct 2001 17:32:49
Message: <slrn9sru84.e6f.ron.parker@fwi.com>
>question...)
I'll make sure it at least gets in the next (3.5) version of MegaPOV.  No
guarantees about 3.5, because it's technically in feature lock.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 17 Oct 2001 17:37:05
Message: <3bcdfa01$1@news.povray.org>
the
> >question...)
Uh? From 0.7 to 3.5 will be a *giant* upgrade ;)
Jonathan.
Date: 17 Oct 2001 17:37:57
Message: <slrn9sruhn.e6p.ron.parker@fwi.com>
>the
>> >question...)
I meant, the next version based on the official 3.5.
Date: 18 Oct 2001 13:36:20
Message: <3BCF134A.7B700D8C@unforgettable.com>
Wouldn't it make sense to use something more geometric than a random
jitter? Or does that cause artifacts or something? (Of course, you would
then need at least, I dunno, four or five samples to get reasonable
results, but you'd need at least that many anyway...)
-Xplo
Date: 18 Oct 2001 21:58:37
Message: <slrn9sv1th.her.ron.parker@fwi.com>
Well, mathematically I don't see that there'd be much difference in the
two methods, since the underlying normal is itself likely to be somewhat
random.  Adaptive jitter might lead to a more ordered approach, though.
This morning I finished rendering a "real" test image, an anisotropic
blurred transmission test.  At 512x384, with 33 samples per intersection
(but two surfaces to the box, so really 1089 samples per pixel, it took
just under 12 hours to render on my P200 but the results were beautiful.
In other news, I thought of a way to get true blurred reflection without
a custom patch; it just requires one little bugfix in 3.5 and a seriously
layered texture.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 20 Oct 2001 10:33:43
Message: <3bd18b47@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote in message news:3bcdf6ec$1@news.povray.org...
> ... (pleonastic
> question...)
> Jonathan.
*grin*  Learn something new every day.
Michael
camera{location<8,20>look_at<6,0,4>}light_source{<8,8>rgb 1}difference{union{
#macro M(D,J)#local R=asc(substr(D,J,1))-32;<div(R,10)*2,mod(R,10)>#end#macro
E(D,B,R)prism{-D,4+D,R#local C=1;#while(C<R+1)M(B,C)#local C=C+1;#end}#end E(
0," (2:FPKAD80* U_dZU"18)sphere{2,2}#macro T(N)cylinder{<9,-N,3><9,4+N,3>3-N}
#end T(0)}T(2)E(1"45LNXUK4"8)pigment{rgb x+y/2}}//(c)2001 MDJohnson(Redbeard)
Date: 21 Oct 2001 13:20:35
Message: <3bd303e3@news.povray.org>
Uh?
"Redbeard (MDJohnson)" <red### [at] wvadelphianet> ha scritto nel messaggio
news:3bd18b47@news.povray.org...
> > ... (pleonastic
> > question...)
> > Jonathan.
> Michael
1}difference{union{
> #macro M(D,J)#local
E(
MDJohnson(Redbeard)
Date: 4 Nov 2001 00:11:35
Message: <3be4ce07@news.povray.org>
Never heard the word 'pleonastic' before.
"JRG" <jrg### [at] hotmailcom> wrote in message news:3bd303e3@news.povray.org...
> Uh?
> > > ... (pleonastic
> > > question...)
> > > Jonathan.
> > Michael
