POV-Ray : Newsgroups : povray.binaries.images : Eye macro Server Time
18 Oct 2026 10:35:13 EDT (-0400)
  Eye macro (Message 1 to 7 of 7)
Subject: Eye macro
Date: 12 Oct 2001 14:58:27
Message: <3bc73d53@news.povray.org>
I just made a little macro that lets you specify eye location, angle, lids
on/off, and lid angle. Any suggestions? I think the iris texture could
definitely use some improvement but am not exactly sure how to go about it.
Comments, questions and criticism are all welcome.
 camera{location<0,0.25,-2> look_at 0.5*y} #declare
T=texture{pigment{crackle scale 0.5 rotate 90 turbulence 0.75 color_map{[0
rgb 1][0.05 rgb 1][0.1 rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}}
finish{ambient 1}} #declare c=difference{torus{0.5,0.1
rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}  merge{object{c
translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}} #end
//Mahalis
Download 'eye.png' (16 KB)
Preview of image 'eye.png'
Subject: Re: Eye macro
Date: 12 Oct 2001 16:36:04
Message: <3bc75434@news.povray.org>
Try and animate this one!
Jonathan.
"Mahalis" <don### [at] fakeycom> ha scritto nel messaggio
news:3bc73d53@news.povray.org...
it.
> //Mahalis
Date: 12 Oct 2001 16:58:44
Message: <3BC75927.1A8EAD12@aol.com>
Mahalis wrote:
> Any suggestions?
Ultimately, such a macro has the greatest use if there is a point_at vector for
the macro.
Date: 13 Oct 2001 07:59:52
Message: <3bc82cb8$1@news.povray.org>
That's an excellent idea- how would I include that feature?
//Mahalis
"Greg M. Johnson" <"gregj56590[:-0]"@aol.com> wrote in message
news:3BC75927.1A8EAD12@aol.com...
> Mahalis wrote:
> > Any suggestions?
vector for
> the macro.
Date: 20 Oct 2001 19:28:16
Message: <3bd20890$1@news.povray.org>
"Mahalis" <don### [at] fakeycom> wrote in message
I've used radial for iris's before.  It works pretty well but is too regular.
I've tried adding turbulence, but it moves the center too much.  Maybe f_noise3d
would work better... hmmm
I agree with the look_at vector.  Probably one of the reorient macros would
work.  Hmmm... and have it react to brightness, too?  So the size of the pupil
is smaller for brighter light.  And IIRC, the pupil changes size with the
distance of whatever you're looking at.  I'm not sure how, though.  You could
use the distance to the look_at vector to calculate that.
Well... now I'm gonna have to go and do some research. :-)
Michael
#macro M(D)#local J=strlen(D);#local _=""#while(J>0)#local _=concat(_,substr(D
,J,1))#local J=J-1;#end _#end sphere{z*9,5pigment{rgb x}}#macro N(D,J)text{ttf
"timrom.ttf"M(D)1,0 translate-J}#end#macro O(E,K)#local _=N(E,K)light_source{-
z*9rgb 1projected_through{_}}#end O("leahciM"<1.6,-.3.9>)O("nosnhoJ"<1.6.9.9>)
Date: 20 Oct 2001 20:07:33
Message: <3bd211c5$1@news.povray.org>
I might put a pupil_size (from 0 [no pupil] to 1 [all the way open]). Maybe
a layered pigment would work for the iris...
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
"Redbeard (MDJohnson)" <red### [at] wvadelphianet> wrote in message
news:3bd20890$1@news.povray.org...
lids
it.
regular.
f_noise3d
would
pupil
could
> Michael
_=concat(_,substr(D
N(D,J)text{ttf
Subject: Re: Eye macro [image, ~61kbu]
Date: 20 Oct 2001 23:36:22
Message: <3bd242b6@news.povray.org>
news:3bd211c5$1@news.povray.org...
How's this for an iris?  The colors may not be right, but otherwise...  Oh...
sorry for the PNG, but JPG mussed the file up too much.
(POV-Ray 3.5b6 used,  MegaPov shouldn't take much modifications, though)
#declare Fnc_IrisBase =
function
    pattern
        radial triangle_wave
        scale 0.45 frequency 50
        rotate x * 90
#declare Fnc_Iris =
function
    mod(Fnc_IrisBase(x,y,z) + f_noise3d(x*100,y*100,z*100) * 0.5, 1)
#declare T_Iris =
texture
    pigment
        function { Fnc_Iris(x,y,z) }
        color_map
            [0.20 rgb <0.10, 0.30, 0.90>]
            [0.85 rgb <0.12, 0.95, 0.70>]
            [0.99 rgb <0.00, 0.05, 0.10>]
Download 'eyeball.png' (61 KB)
Preview of image 'eyeball.png'
