POV-Ray : Newsgroups : povray.binaries.images : Flood of Blood Server Time
12 Nov 2026 05:42:19 EST (-0500)
  Flood of Blood (Message 1 to 14 of 14)
Subject: Flood of Blood
Date: 10 Oct 2001 16:33:38
Message: <3bc4b0a2@news.povray.org>
...well, not really, just red paint.
This is a quick test with a particles system I'm writing these days. This
still doesn't look that good, but I'm going to post the animated version
ASAP (tough you can find my previous test in p.b-a).
Comments and suggestions are welcome.
Jonathan.
Download 'paint.jpg' (67 KB)
Preview of image 'paint.jpg'
Subject: Re: Flood of Blood
Date: 10 Oct 2001 16:45:47
Message: <3BC4B40F.221A70C1@iro.umontreal.ca>
> Jonathan.
hmmm...
....chunky....
More small particles? ... like a LOT more ?
Best,
    S.
Steven Pigeon                     Ph. D. candidate
University of Montreal.
pig### [at] iroumontrealca           Topic: data compression
         http://www.iro.umontreal.ca/~pigeon
Date: 10 Oct 2001 16:56:36
Message: <3bc4b604@news.povray.org>
To say the true the particles are really small. Look at the smallest
particles on the ground and consider that all the particles have same
size...
The problem here could be that I used only 100 iterations, with 40 particles
per iteration... just 2 minutes of parsing.
Jonathan
"Steven Pigeon" <pig### [at] iroumontrealca> ha scritto nel messaggio
news:3BC4B40F.221A70C1@iro.umontreal.ca...
This
> > Jonathan.
> >  [Image]
> hmmm...
> ....chunky....
> Best,
>     S.
Date: 10 Oct 2001 18:43:38
Message: <3bc4cf1a@news.povray.org>
Eeeew... Cool though. Source? :-)
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3bc4b0a2@news.povray.org...
> Jonathan.
Date: 10 Oct 2001 19:20:59
Message: <3bc4d7db$1@news.povray.org>
It reminds of the way liquid behaves in a zero G environment.  It holds a
globular shape as opposed to a flattened stream with gravity.  Paint in
Space?
Skip
JRG <jrg### [at] hotmailcom> wrote in message news:3bc4b0a2@news.povray.org...
> Jonathan.
Date: 10 Oct 2001 22:16:15
Message: <3BC50119.B3EFE157@unforgettable.com>
Make a version with blood! :D
-Xplo
Date: 11 Oct 2001 02:09:47
Message: <3bc537ab@news.povray.org>
Blood is more translucent though. Something like that glass of milk...
- Nekar
"JRG" <jrg### [at] hotmailcom> wrote in message news:3bc4b0a2@news.povray.org...
> Jonathan.
Version: 6.0.282 / Virus Database: 150 - Release Date: 2001/09/25
Date: 11 Oct 2001 16:33:17
Message: <3BC6029E.319BF1F5@iro.umontreal.ca>
> size...
I'm intrigued. How does your system work ?
I've done some thinking but all solution I came up
with are computational monsters. Especially with
Povray, the language isn't quite as powerful as one
could wish to do real computations and animations...
Best,
    S.
> Jonathan
> This
> > > Jonathan.
> > >  [Image]
> > hmmm...
> > ....chunky....
> > Best,
> >     S.
Date: 11 Oct 2001 16:50:46
Message: <3bc60626@news.povray.org>
Computational monsters? It's not the case.
I'm not a programmer neither a physicist, so I have no idea how particles
systems are usually done... ;)
Mine uses a simple 30-40 lines code to do all the calculations. It took me
just 30 minutes to write it down one or two weeks ago. No fancy features, no
inter-particle interaction. Yet it seems to work well in animations. And SDL
is required for trace(). I will post this scene animated tomorrow.
Jonathan.
news:3BC6029E.319BF1F5@iro.umontreal.ca...
> > size...
particles
> Best,
>     S.
> > Jonathan
> > This
version
> > > > Jonathan.
> > > >  [Image]
> > > hmmm...
> > > ....chunky....
> > > Best,
> > >     S.
Date: 11 Oct 2001 17:00:35
Message: <3BC60904.39272E10@iro.umontreal.ca>
Neither am I. But, I don't know... I would have particle glue together under
a certain treshold of energy difference, repulse each other when compressed...
Glue to objects, etc.
That type of physical constraints.
ok... I'm eager to see it
Best,
    S.
> Jonathan.
> > > size...
> particles
> > Best,
> >     S.
> > > Jonathan
> > > This
> version
> > > > > Jonathan.
> > > > >  [Image]
> > > > hmmm...
> > > > ....chunky....
> > > > Best,
> > > >     S.
Date: 11 Oct 2001 17:09:31
Message: <3bc60a8b@news.povray.org>
news:3BC60904.39272E10@iro.umontreal.ca...
particles
under
compressed...
That would be easy to implement but really slow in animation... (a loop
which checks the distances between every particle would do the trick).
This is *simulated* with little random amounts here.
Jonathan
Date: 11 Oct 2001 18:32:33
Message: <3bc61e01@news.povray.org>
"Mahalis" <don### [at] fakeycom> ha scritto nel messaggio
news:3bc4cf1a@news.povray.org...
When the work is finished I'll post the code. Now it really needs to be
cleaned up.
Jonathan.
Date: 11 Oct 2001 22:00:25
Message: <3BC64F91.36149A67@faricy.net>
Just wash the ax off when you're done.  Oh, and you forgot to lock the
door, so look out for Lizaveta.
Date: 14 Oct 2001 02:04:01
Message: <3BC92B81.E78AE64@qwest.net>
wow. very iconic image to me- and good title- who's to
say it *isn't* blood?
http://www.users.qwest.net/~dearmad
Why bother?  I'm not interesting.
But... maybe "Ballet pour ma fille" will be.
