POV-Ray : Newsgroups : povray.binaries.images : Problem with smooth heightfield Server Time
12 Nov 2026 05:42:21 EST (-0500)
  Problem with smooth heightfield (Message 1 to 22 of 22)
Subject: Problem with smooth heightfield
Date: 10 Oct 2001 10:21:32
Message: <3bc4596c@news.povray.org>
Hello,
The attached picture show heightfields created from an isosurface. The
bottom ones are "smooth" but don't exactly look like I would expect, or like
I remember triangles do when they are smoothed correctly.. I tried different
lights.. I tried TGA, PNG and GIF.. I tried POV 3.5, MegaPOV 0.7 and POV
3.1g and two computers.. It's all the same..What do you think?
#version 3.5;
camera { right -1.33*x up 1*y direction 1*z
 location <-3.5,3.2,6>*.6 look_at 0 angle 48 }
light_source { <-25,25,25> color rgb 1 }
height_field { png "heightfield.png"
 water_level .000001 translate -.5
 scale <3,.75,2.75> rotate 90*x
 pigment { rgb 1 }
 finish { ambient 0 diffuse .67 specular .1 }
 no_shadow }
Download 'Problem_Heightfield.JPG' (89 KB)
Preview of image 'Problem_Heightfield.JPG'
Subject: Re: Problem with smooth heightfield
Date: 10 Oct 2001 10:29:21
Message: <3BC45B3A.71BEFC86@gmx.de>
Hugo wrote:
> Hello,
That looks much like the heightfield having only 8 bit resolution.  Using
'hf_gray_16 on' in global_settings should help if you generate the
heightfield with Povray.  But be careful when using png output in Povray
3.5 with this since it does not work correctly right now.
Date: 10 Oct 2001 10:35:03
Message: <slrn9s8n4o.9oc.ron.parker@fwi.com>
On Wed, 10 Oct 2001 16:29:14 +0200, Christoph Hormann wrote:
>Hugo wrote:
>> Hello,
Actually, the PNG output is fine.  It's the PNG input that's broken.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 10 Oct 2001 11:09:37
Message: <3BC464A8.DFAEFBFC@gmx.de>
No, i have always (including last betas) used my 16 bit png's in Povray
heightfields without problems.
Date: 10 Oct 2001 11:21:56
Message: <slrn9s8psm.9q8.ron.parker@fwi.com>
16-bit greyscale PNGs?
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 10 Oct 2001 12:20:31
Message: <3BC4754F.51931A2D@gmx.de>
Yes! (should i post one?)
Date: 10 Oct 2001 13:42:05
Message: <slrn9s923f.9sh.ron.parker@fwi.com>
By all means.  I'd like to see what the difference is, since I haven't
seen any problems with the PNGs POV outputs.
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 10 Oct 2001 15:11:10
Message: <3BC49D3F.5D87E8EB@gmx.de>
Here are three 128x128 16 bit png's:
hf_pov35_16.png      generated with POV 3.5 beta 6
hf_pov31_16.png      generated with POV 3.1
hf_xxx_16.png        generated with other program
Download 'hf_pov35_16.png' (25 KB) Download 'hf_pov31_16.png' (25 KB) Download 'hf_xxx_16.png' (29 KB)
Preview of image 'hf_pov35_16.png'
Preview of image 'hf_pov31_16.png'
Preview of image 'hf_xxx_16.png'
Date: 10 Oct 2001 16:20:17
Message: <3bc4ad81@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> ha scritto nel messaggio
news:3BC49D3F.5D87E8EB@gmx.de...
Uh? Something like Ategeros? ;)
Remember that there are people who are waiting for that.
Jonathan.
Date: 10 Oct 2001 16:44:01
Message: <3bc4b311@news.povray.org>
Thanks for the suggestion. I figured out myself that the 8 bit resolution
was the problem. However, wouldn't it be possible to make an "interpolate"
feature that make them appear as smooth as 16 bit?  For the user, it would
be easier to stick with 8 bit bitmaps because many paintprograms don't
support 16 bit greys.. I don't have one, that do.
I could also try another approch to store heightfields. To use the "trace"
command and make a grid of triangles myself.. I could get away with much
fewer triangles, if I am lucky to implement a triangle decimation algoritm.
This has proved hard in the past.
I tried to output a PNG 16 bit, and put "hf_gray_16" in global settings.. I
used POV 3.5 beta 5 and the result looks cool, as you can see.. I tried to
render the heightfield both in MegaPOV and POV 3.5 beta5, with same result.
Hugo
Download 'Problem_Heightfield2.JPG' (53 KB)
Preview of image 'Problem_Heightfield2.JPG'
Date: 10 Oct 2001 16:56:14
Message: <3BC4B5EE.2E13A371@gmx.de>
I know, but it's quite problematic, things have grown over the years and
the structure of the program quite difficult to handle (in fact
*structure* is seriously missing :-).
I'm considering starting new from scratch, before i would like to release
an experimental version of the current state, but there are serious
problems with things becoming very slow after some time of use.  If i for
example apply a filter 100 times it's getting slower and slower and i
can't find the reason...
Date: 10 Oct 2001 17:00:55
Message: <3bc4b707@news.povray.org>
Hugo <hua### [at] post3teledk> schrieb in im Newsbeitrag:
3bc4b311@news.povray.org...
> Hi,
You could use your image as a image_map in a function then you could
use interpolate.
Date: 10 Oct 2001 17:13:43
Message: <3bc4ba07$1@news.povray.org>
news:3BC4B5EE.2E13A371@gmx.de...
I lost you here... I know NOTHING about programming and similia so forgive
me if I say something silly: I always thought to h-f  utilities as image
processors which, through a series of fractal (or not) algorithms, alter (or
create from scratch) a bitmap in order to get a grayscale image usable in
POV. Once you apply a filter, you've got a new bitmap ready for other
filtering processes. No matter how many times you apply one or more filters,
every time the h-f utility treats the bitmap as if *it were the first time
it saw it*. Please tell me if I'm wrong.
Jonathan
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 10 Oct 2001 17:24:25
Message: <3bc4bc89@news.povray.org>
"Simon" <sim### [at] 12movede> wrote in message
news:3bc4b707@news.povray.org...
resolution
"interpolate"
would
> use interpolate.
A 'smooth' keyword exists and from what I read no one mentioned that.  Only
good on 256 color image files though from what I know.
Bob H.
Date: 10 Oct 2001 17:32:05
Message: <3bc4be55@news.povray.org>
Yeah gee, that's what I was talking about before, chaotic.  Odd thing is
that a Targa file will look much the same way, except for not being
grayscale, and yet can render as a HF fine.  What I saw in the PNG-made HF
was partially okay and mostly not.  Chaotic mosaics mostly.
Bob H.
> Christoph
Date: 10 Oct 2001 17:32:38
Message: <3BC4BE76.ACE1E01E@gmx.de>
'smooth' in heightfield only interpolates the normal vectors.  Geometry is
not influenced.
Date: 10 Oct 2001 17:32:57
Message: <3BC4BE89.81EE0305@gmx.de>
That's the theory, but since it is an interactive program, there are
things done after the steps (like displaying the changed bitmap) and
somewhere there must be the problem...
Date: 10 Oct 2001 17:40:51
Message: <3BC4C05B.EACE2539@gmx.de>
Yes, it's the same pattern, but it's not chaotic, it's simply the less
significant byte, like the green channel in the tga file.
Date: 10 Oct 2001 17:41:32
Message: <3bc4c08c@news.povray.org>
So, theorically, if you apply a filter with Ategeros, save the output, then
reload it and apply a new filter the problem shouldn't sussist. I don't
think this is a *so serious* bug for a (first) beta release... :-)
BTW who would want to apply 100 filters alltogether?
Jonathan
news:3BC4BE89.81EE0305@gmx.de...
forgive
(or
in
filters,
time
> Christoph
Date: 10 Oct 2001 17:46:24
Message: <3BC4C1AC.6759C511@gmx.de>
If you restart the application in between too. ;-)
When doing an animation...
And a lot of erosion filters need to be applied a lot of times to get good
results.
Date: 10 Oct 2001 17:52:07
Message: <slrn9s9goa.a1t.ron.parker@fwi.com>
On Wed, 10 Oct 2001 21:10:55 +0200, Christoph Hormann wrote:
>This is a multi-part message in MIME format.
>--------------53C58C8C78D6DC69CDEC24AB
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
Only one of those works correctly with pngtopnm.  The others all have the
words in the wrong order.  I suppose this could be a flaw in pngtopnm, but
I prefer to believe that it's a flaw in everything else.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 10 Oct 2001 18:08:18
Message: <3BC4C6CF.25AB0957@gmx.de>
Including all image viewers and paint programs that display the files with
8 bit?
Not to mention all past Povray versions and gforge etc.
