Cheap Grass.
Pros:
- Practically no memory consumption.
- Can cover infinitely large areas, literally.
- Parsing: ~3 seconds.
- Rendering: Fast.
Cons:
- Not that realistic.
- No good for close-ups.
- No good for animations.
Rune
Rune's World: http://rsj.mobilixnet.dk (updated June 26)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
Download 'cheapgrass.jpg' (67 KB)
Preview of image 'cheapgrass.jpg'
I think the white and brownish lines are what give it away. That, and the
fact that there is no fuzziness on the horizon. Nice though. :)
Is it an image map?
BTW why is it cheap? Shouldn't it be free? ;o)
- Nekar
"Rune" <run### [at] mobilixnet dk> wrote in message
news:3babe982@news.povray.org...
> Cheap Grass.
> Pros:
> - Rendering: Fast.
> Cons:
> Rune
> 3D images and anims, include files, tutorials and more:
On Sat, 22 Sep 2001 03:25:54 +0200, Rune wrote:
>Cheap Grass.
>Pros:
>- Rendering: Fast.
>Cons:
It does look good. Hope you're going to source us.
It looks like gras that's been recently cut and has
dried out but stayed green.
Steve email mailto:ste### [at] zeropps uklinux net
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
9:40am up 11 days, 11:54, 1 user, load average: 1.16, 1.09, 1.03
> That, and the fact that there is no fuzziness on the horizon.
Perhaps the attached version is slightly better?
> Nice though. :)
Thanks! :)
Can anyone guess the trick I used?
Rune
Download 'cheapgrass2.jpg' (60 KB)
Preview of image 'cheapgrass2.jpg'
"Nekar Xenos" wrote:
> Is it an image map?
No image map, material map or similar used.
Careful now, or it won't even be cheap anymore...! ;)
Rune
"Steve" wrote:
> It does look good.
Thanks!
In a little while.
I tried to make a fresher version which you can see in my reply to Tony[B].
Rune
news:3bacbd42@news.povray.org...
> > Nice though. :)
> Thanks! :)
3.5 function pigment? Couldn't begin to guess the specific formula.
It occurs to me that maybe you could replace the darker colors with
transparency and use two copies of the ground stacked one above the
other for a little extra realism. What do you think?
Batronyx ^"^
bat### [at] cadronhsa com
http://www.batronyx.com
On Sat, 22 Sep 2001 17:47:43 +0200, "Rune"
I like these, but I think they look more like the texture of some
types of fur, carpet, or perhaps "Astro-turf", than actual grass. Have
you tried simulating any of these other materials, using this
technique yet?
Later,
Glen
If it's that fast it must just be a texture (either that or your
machine's a lot faster than mine). I'd guess something like this:
pigment {leopard
scale <0.01,1,0.1>
turbulence <4,1,1> octaves 2 omega 1
colour_map{[0 rgb 0][0.1 rgb <0,0.5,0>][0.5 rgb <0.9,1,0.9>]}
warp {turbulence <0.2,0.1,0.1>}
Mike Williams
Gentleman of Leisure
Interesting effect. With the "road" it seems to gain more depth. :) I'm
guessing f_noise3d displaced along some sort of sine wave and turbulated.
"Rune" <run### [at] mobilixnet dk> schrieb im Newsbeitrag
> > Nice though. :)
> Thanks! :)
I think, if it isn't a material/pigment-map,than maybe either an Isosurf or
Media, but both of them would be slow ... I don't see any artefacts of fast
mediasettings, but it seems to have some volume (as you can see at the edges
of the path)
at least it inspired me to the following 15mins hack (most time was waiting)
could you tell, if it's the right direction ?
// place some camera and lights here ...
plane { // ground and lower limit of the container
y, 0
pigment { color rgb <0.7,0.5,0.3> }
difference { // this should be the container of the grass
plane {y, 0.1}
torus {3,0.3 scale y*20 translate x+1} // cut the path out of this ...
hollow // of course, we are playing with media
pigment { color rgbt <0,0,0,1> } // we ONLY play with media !
finish { ambient 0 diffuse 0} // --------"-------------
interior {
media { // here we go ...
absorption 35 // we have small features ...
samples 128,128 // and so we need much samples
density {
bozo // I think every pattern playes well
color_map { // one part of the secret is the colormap
[0, color rgb 0] // 85% nothing happens
[0.85, color rgb 0] //
[0.85, color rgb <0.9,0.25,0.9>] // but here we
[1, color rgb <0.9,0.7,0.9>] // create blades
frequency 1.5 // to make it a bit denser ...
scale <0.01,5,0.01> // thats the other part of the trick
warp { turbulence <0.3,0,0.3> } // and of course ...
this renders without AA at 1180PPS here ... what is quite fast, i think ...
Jan Walzer <jan### [at] lzer net>
"Microsoft: because choices are confusing..."
interesting. the forground looks painted, which i like a lot.
Looks much better with the road, helps to add a sense of scale :)
(i have no idea how you did it!)
PGP Public Key
Well, actually it's supposed to be a small path, just half a meter wide, but
I don't think I succeeded in making it look that way. That's not so
important though.
Rune
Well, yes, but that doesn't say so much does it? ;)
I'll post it in a little while.
> darker colors with transparency and use two copies
> of the ground stacked one above the other for a
I've already done that. That's why the horizon is slightly fuzzy. :)
Rune
Yep.
> scale <0.01,1,0.1>
That wouldn't work because of perspective, but you've guessed the basic
principle, only it's a bit more complicated.
Rune
> texture of some types of fur, carpet, or perhaps
> "Astro-turf", than actual grass. Have you tried
> this technique yet?
Nah, I'd prefer it to look like grass... :(
Rune
"Jan Walzer" wrote:
> I think, if it isn't a material/pigment-map, than maybe
> either an Isosurf or Media, but both of them would be slow
It's a texture... :)
> ... I don't see any artefacts of fast mediasettings, but
> of the path)
I'm using several copies of the object one on top of the other...
Rune
Thanks!
Rune
news:3badcaff@news.povray.org...
No it doesn't. :) Just emphasizing your use of the new
functions over more traditional texture techniques.
Great! I'll check it out. Enjoyed playing with some
of your crackle variants recently. :)
I see that now. Hmmm. . . Perhaps some extra surface displacement on the top
layer to make the fuzzy/jagged effect more pronounced? It looks fresh
mowed on the edges but not in the middle. It might increase the realism
somewhat.
Impressive any way. :)
> Rune
