POV-Ray : Newsgroups : povray.binaries.images : --- Server Time
18 Oct 2026 14:29:06 EDT (-0400)
  --- (Message 1 to 14 of 14)
Subject: ---
Date: 28 Aug 2001 18:53:13
Message: <3b8c20d9@news.povray.org>
I've been experimenting with glass and have come across some problems.
Here is part of a scene that I created using Moray and sPatch.  The
texture used for both the sphere and shot glass is Glass1 from the glass
material library that comes with Moray.  Whereas the sphere is normal
looking, the shot glass has all those black inconsistencies.  There are
walls covering all sides of the objects, so the black is not anything
reflected or refracted.  When I take away the refraction of the shot
glass, the inconsistencies disappear.  How do I get rid of those
inconsistencies?
(By the way, the shot glass was created from a lathe in sPatch then
exported to Moray)
Download 'iso-8859-1' (2 KB)
Subject: Re:
Date: 28 Aug 2001 18:57:11
Message: <MPG.15f640478f0ef62b989685@news.povray.org>
In article <3b8c20d9@news.povray.org>, use### [at] hostcom says...
> refraction of the shot glass, the inconsistencies disappear.
> How do I get rid of those inconsistencies?
Most certainly this is caused by a insufficient max_trace_level in
global_settings.
Lutz
Subject: Re:
Date: 28 Aug 2001 19:17:41
Message: <3b8c2695@news.povray.org>
"Paragon" <use### [at] hostcom> wrote in message news:3b8c20d9@news.povray.org...
> across some problems...
>                                          ...the shot glass has all those
> black inconsistencies.  There are walls covering all sides
> of the objects, so the black is not anything reflected or
> refracted.
    First off, HTML posts are frowned upon by most people round here (yes,
even in the binaries groups)...
    Now to answer your question - Whilst you are right the black bits aren't
reflections of anything in your scene, they are caused by reflection... try
removing the reflection from the glass material and the black bits should
disappear...
    You see, what's happening is the combination of reflection and
refraction is causing 'total internal reflection' - where the rays POV is
calculating bounce around and around inside the glass without leaving - of
course POV won't do this forever - it only calculates upto a finite amount
of reflections and if it hasn't calculated a colour within that number it
just colors the pixel black.
    Fortunately you can specify how many reflections POV calculates - I
don't know how you do it in Moray, but you can add the following to top of
your .pov file :
global_setting { max_trace_level <level> }
    where <level> is the number of reflections you wish it to calculate -
now the only problem is you may find that you never get rid of the black
bits completely and the higher the value for max_trace_level you pick the
longer POV will spend rendering these parts of the scene...
Scott Hill.
Software Engineer.
E-Mail        : sco### [at] innocentcom
Pandora's Box : http://www.pandora-software.com
*Everything in this message/post is purely IMHO and no-one-else's*
Subject: Re:
Date: 28 Aug 2001 21:25:44
Message: <3b8c4498@news.povray.org>
Thank you for the reply but it seems to have not done the trick.  I tried
taking away the reflection from the glass material as well as increasing the
max_trace_level but I still get the black distortions (even with very high
max_trace_levels).  I have attached the files for the scene if anybody
wishes to try their hand at it.
-Paragon
"Scott Hill" <nos### [at] nospamthanks> wrote in message
news:3b8c2695@news.povray.org...
> > refracted.
aren't
try
> disappear...
> your .pov file :
> Scott Hill.
> Software Engineer.
Download 'whiskey.zip' (6 KB)
Subject: Re:
Date: 28 Aug 2001 21:25:48
Message: <3b8c449c@news.povray.org>
-Paragon
> > refracted.
aren't
try
> disappear...
> your .pov file :
> Scott Hill.
> Software Engineer.
Subject: Re:
Date: 29 Aug 2001 00:11:01
Message: <3B8C6AD0.E3C920B0@usb.ve>
Set the adc_bailout to 0.1 . If this is to big, try with a little bit smaller value.
Alberto.
> -Paragon
Subject: Re:
Date: 29 Aug 2001 01:21:26
Message: <3b8c7bd6@news.povray.org>
Thanks, but I still get that darn black distortion.  I found that setting
the diffuse level higher helps, but changes the look I want for the glass.
I guess I'll have to settle for that for now...
Paragon
"Alberto" <jac### [at] usbve> wrote in message news:3B8C6AD0.E3C920B0@usb.ve...
smaller value.
> Alberto.
tried
the
high
> > -Paragon
Subject: Re:
Date: 29 Aug 2001 04:06:56
Message: <3B8CA29C.DB03CAD8@ignorancia.org>
  These are not "black distortions", only realistic reflections of the
empty space on the scene (thus black space). Surround all the scene with
walls and ceil and it will disappear...
Jaime Vives Piqueres
http://www.ignorancia.org/
Subject: Re: glass problem
Date: 29 Aug 2001 07:46:12
Message: <3b8cd604@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:3B8CA29C.DB03CAD8@ignorancia.org...
tried
the
high
No, it is already.  Said so somewhere else but this dual thread thing has
confused me as to where exactly.
But that is what it looks a lot like anyway, if not any lack of
max_trace_level.
If I could find that scene file to see if maybe the CSG has two textures, a
combined refractive one and non-refractive perhaps, then maybe it could be
figured out.  Just guessing though.
Bob H.
Subject: Re:
Date: 29 Aug 2001 08:31:53
Message: <3b8ce0b9@news.povray.org>
After playing with the scene for a bit I think I may have found somewhat of
an answer.
Some of the black came from the black background (you do have walls but not
on all sides, try  "background {color <1,1,1>}".  Some of the black are
artifacts from not having max_trace_level high enough (I used 100 *ulp* to
make sure there weren't any left but you can get away with lower).  After
changing these any black that's left appear to come from the glass texture
itself.  You have filter set to 0.7 so eventually, after moving through the
glass enough, the light fades to black. Try setting the filter value in your
glass texture higher (plus the other fixes mentioned) and the black should
eventually disappear (at least I was able to get it to). Unless you want
your glass to appear like that. As a side note, you may also want to try use
light fading in your glass to achieve the look you want for your glass. Good
luck
-tgq
Image 1 - no changes
Image 2 - change "background {color <1,1,1>}"
Image 3 - change "max_trace_level 100"
Image 4 - change "color rgbf <1.0, 1.0, 1.0, 0.9>" in Glass2
Bonus:
Image 5 - add   "fade_distance 3  fade_power 1" to interior of Glass2
"Paragon" <use### [at] hostcom> wrote in message news:3b8c449c@news.povray.org...
the
> -Paragon
those
> > > refracted.
(yes,
> aren't
> try
should
> > disappear...
is
of
amount
it
of
> > your .pov file :
calculate -
the
> > Scott Hill.
> > Software Engineer.
Download 'whiskey1.jpg' (7 KB) Download 'whiskey2.jpg' (6 KB) Download 'whiskey3.jpg' (6 KB) Download 'whiskey4.jpg' (7 KB) Download 'whiskey5.jpg' (6 KB)
Preview of image 'whiskey1.jpg'
Preview of image 'whiskey2.jpg'
Preview of image 'whiskey3.jpg'
Preview of image 'whiskey4.jpg'
Preview of image 'whiskey5.jpg'
Subject: Re:
Date: 29 Aug 2001 08:48:20
Message: <3b8ce494@news.povray.org>
Your scene revisited using some of the features of the MegaPOV patch (plus
caustics from the regular POV).
Now I've just got to start fiddling with photons :)
-tgq
Download 'whiskey.jpg' (86 KB)
Preview of image 'whiskey.jpg'
Subject: Re:
Date: 29 Aug 2001 14:28:50
Message: <3b8d3462@news.povray.org>
Thanks for the tips Trevor, it has greatly helped.  The scene I attached did
not have walls on all sides but I did try and render the scene with walls on
all sides and was still getting the black pixels.  But I have done what you
said and am now getting the results I want.
Thanks!
-Paragon
"Trevor Quayle" <tqu### [at] pwddcom> wrote in message
news:3b8ce494@news.povray.org...
> -tgq
Subject: Re:
Date: 29 Aug 2001 14:50:34
Message: <3b8d397a@news.povray.org>
Actually, I have had some success with the tips you gave me, but how you
achieved the glass in whiskey4.jpg is eluding me...is it possible for you to
post the scene files for that render (or the updated MegaPOV files if that's
the case)?
Thanks
-Paragon
news:3b8ce0b9@news.povray.org...
of
> an answer.
not
the
your
use
Good
> luck
> -tgq
> Bonus:
tried
> the
high
> > -Paragon
> those
> > > > refracted.
> (yes,
> > aren't
reflection...
> > try
> should
> > > disappear...
> is
leaving -
> of
> amount
> it
I
top
> of
> > > your .pov file :
> calculate -
black
> the
> > > Scott Hill.
> > > Software Engineer.
Subject: Re:
Date: 30 Aug 2001 07:46:39
Message: <3b8e279f@news.povray.org>
For whiskey 4.jpg I made the following exact changes to the files you
posted:
Turned off radiosity
Scale the glass larger by 3
Raised the camera location to location  < 2.424,-5.483, 5.253>
Change background colour to white "background{color<1,1,1>}"
Change max_trace_level to 100 (probably way higher than it needs to be but I
wanted to be sure to eliminate that problem)
And finally in the Glass2 texture in whiskey.inc, change the pigment to
If you want the light to appear darker use attenuation rather than changing
the filter component (It also makes the shadow look better)
Actually I have been playing with glass textures quite a bit this past week
and I find I prefer some of the MegaPOV options.  I rendered this one for
you last night (1h55min, photons, no radiosity (sorry to all ye radiosity
lovers, I haven't had much luck with it yet :( ))
Reply if you want some info on the MegaPOV settings I've been using
-tgq
"Paragon" <use### [at] hostcom> wrote in message news:3b8d397a@news.povray.org...
to
that's
> the case)?
> Thanks
> -Paragon
Download 'whiskey6.jpg' (143 KB)
Preview of image 'whiskey6.jpg'
