POV-Ray : Newsgroups : povray.binaries.images : Duet Server Time
23 Oct 2026 11:59:19 EDT (-0400)
  Duet (Message 1 to 19 of 19)
Subject: Duet
Date: 28 Aug 2001 17:41:16
Message: <3b8c0ffc@news.povray.org>
A sunny musical duet.
Comments?
Jonathan
Download 'duet.jpg' (109 KB)
Preview of image 'duet.jpg'
Subject: Re: Duet
Date: 28 Aug 2001 18:12:15
Message: <3b8c173f@news.povray.org>
That's one big flute :) I remember the holes in my flute to be bigger, but
it might be some other kind of flute. If it's one of these flutes you can
take apart, it's a bit hard to see the intersection between the "body" with
holes and the "head".
There are two dark spots in the bottom of the image, where do they come
from?
Peter
http://hertel.no/peter
Subject: Re: Duet
Date: 28 Aug 2001 18:16:46
Message: <MPG.15f62957f1c93a059899d2@news.povray.org>
On Tue, 28 Aug 2001 23:30:10 +0200, JRG wrote...
> Comments?
Either that's a very large recorder, or it's a very small piano...
Oh, and maybe you should have cropped off the two rogue radiosity
artifacts :)
Bye for now,
    Jamie
Subject: Re: Duet
Date: 28 Aug 2001 18:21:41
Message: <MPG.15f637e8f8e0bf48989684@news.povray.org>
In article <3b8c0ffc@news.povray.org>, jrg### [at] hotmailcom says...
> Comments?
I think the proportions are slightly incorrect, but I may be wrong ;-)
The textures are very good, except that wooden thingy on the piano that
is for covering the keys if its unused (don't know how that thing is
correctly called). That looks like is has a strange normal.
Lutz
Subject: Re: Duet
Date: 28 Aug 2001 18:29:06
Message: <3b8c1b32@news.povray.org>
Comments, aside from the scale?  :)  Well, maybe a piano bench and light,
but otherwise, nice.  The recorder I have is plastic and breaks up into
three pieces like that one, but the joints on mine stick out a little more.
That is a recorder, right?  I don't remember if they have eight or nine
holes (incl. the one in the back)...
Hmm, I just noticed something.  Don't pianos usually have three pedals?
Me
Subject: Re: Duet
Date: 28 Aug 2001 21:06:26
Message: <3b8c4012@news.povray.org>
Nice. Increase the max_trace_level to get rid of those funny polka-dots...
Subject: Re: Duet
Date: 28 Aug 2001 23:43:59
Message: <3b8c64ff$1@news.povray.org>
"Peter Hertel" <NOS### [at] hertelno> wrote in message
news:3b8c173f@news.povray.org...
with
> from?
That is not a flute, I belive it is a recorder.
> Peter
Subject: Re: Duet
Date: 29 Aug 2001 00:05:56
Message: <3b8c6a24@news.povray.org>
"Daniel Lin" <dli### [at] yahoocom> wrote in message
news:3b8c1b32@news.povray.org...
I thought so before too, but "usually" is the key word there.  Apparently
there are two pedal piano's too.
Bob H.
Subject: Re: Duet
Date: 29 Aug 2001 00:26:56
Message: <3b8c6f10@news.povray.org>
Just one small suggestion - the piano suffers a lot from aliasing - try
rendering it with anti-aliasing method 2 (+am2 +r3 on the command line
usually works pretty well...)
-Dave
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3b8c0ffc@news.povray.org...
> Comments?
> Jonathan
Subject: Re: Duet
Date: 29 Aug 2001 06:43:55
Message: <3b8cc76b@news.povray.org>
I rather think it has something to do with lathe... without sturm it looked
even worse... :(
Jonathan
"Tony[B]" <ben### [at] catholicorg> ha scritto nel messaggio
news:3b8c4012@news.povray.org...
Subject: Re: Duet
Date: 29 Aug 2001 06:47:40
Message: <3b8cc84c$1@news.povray.org>
Radiosity artifacts, probably caused by the hole of the "body".
Jonathan
"Peter Hertel" <NOS### [at] hertelno> ha scritto nel messaggio
with
> from?
> Peter
Subject: Re: Duet
Date: 29 Aug 2001 06:50:46
Message: <3b8cc906@news.povray.org>
"Daniel Lin" <dli### [at] yahoocom> ha scritto nel messaggio
more.
Ehm...perhaps it's me but I don't see the point...
Jonathan
Subject: Re: Duet
Date: 29 Aug 2001 06:52:20
Message: <3b8cc964@news.povray.org>
I just didn't want to wait too much....;)
Anyway this one took only 1h and 47 minutes...
Jonathan
"Dave Blandston" <gra### [at] earthlinknet> ha scritto nel messaggio
news:3b8c6f10@news.povray.org...
> -Dave
> > Comments?
> > Jonathan
Subject: Re: Duet
Date: 29 Aug 2001 08:11:05
Message: <3b8cdbd9@news.povray.org>
"Lutz-Peter Hooge" <lpv### [at] gmxde> ha scritto nel messaggio
news:MPG.15f637e8f8e0bf48989684@news.povray.org...
> > Comments?
do you?!
You are. These are two souvenirs taken by a friend of mine, a certain
Gulliver, during his travels... ;)
> correctly called).
"Cover"?
No strange normals used. The texture is the same for every part of the
piano.
Jonathan
Subject: Re: Duet
Date: 29 Aug 2001 09:22:29
Message: <3b8cec95@news.povray.org>
Believe me. I've seen those spots before. They happen when you mix "objects
on a plane lit with a dome" radiosity and reflective objects. Increase
max_trace_level enough and they'll go away.
Subject: Re: Duet
Date: 29 Aug 2001 15:06:58
Message: <3b8d3d52@news.povray.org>
Sorry, I thought you were referring to those little dots at the end of the
flute...
I'll give it a try. :)
Jonathan
news:3b8cec95@news.povray.org...
"objects
Subject: Re: Duet
Date: 29 Aug 2001 18:10:26
Message: <3b8d6852@news.povray.org>
but
can
> with
> > from?
What's a "recorder" anyway? Some other kind of flute? If it is, what's the
difference?
Peter
Subject: Re: Duet
Date: 29 Aug 2001 19:54:14
Message: <3b8d80a6@news.povray.org>
news:3b8d3d52@news.povray.org...
> flute...
That's where the camera aligns with the lathe, only fix I know of is to
offset them enough to where the camera isn't on a plane intersecting the
extra-radial realm of the lathe.
Bob H.
Subject: Re: Duet
Date: 29 Aug 2001 22:47:10
Message: <3b8da92e@news.povray.org>
> difference?
I really know nothing about musical instruments so don't take my word for
gospel;-) A recorder is a completely different woodwind instrument, at least
from the modern flute. Most modern flutes are metal.
