POV-Ray : Newsgroups : povray.binaries.images : Simple is beautiful Server Time
12 Nov 2026 06:28:23 EST (-0500)
  Simple is beautiful (Message 1 to 22 of 22)
Subject: Simple is beautiful
Date: 19 Aug 2001 09:49:13
Message: <3b7fc3d8@news.povray.org>
Just playing and testing... And got this. It's very simple, but somehow
I like it. It has the beauty of raytracing.
  Uses just 3.1 code, no fancy features.
Download 'GlowTest.jpg' (36 KB)
Preview of image 'GlowTest.jpg'
Subject: Re: Simple is beautiful
Date: 19 Aug 2001 10:51:46
Message: <3b7fd282$1@news.povray.org>
 - Warp -
Indeed.  Can you describe the lighting ?
I'm wondering what the source of the *green* on the
plane under the left sphere is . . .
Nice use of focal blur . . . just the right amount.
Y
Date: 19 Aug 2001 11:08:25
Message: <3b7fd669@news.povray.org>
news:3b7fc3d8@news.povray.org...
somehow
Was puzzling over Greens "reflection" until I realized it wasn't
opaque. Brain was expecting 3 metallic balls :-/  I wish I could
figure how to remove the saturation with these, always spoils it for
me. Looks pretty tho'.
Alf
Date: 19 Aug 2001 11:27:58
Message: <3b7fdafe$1@news.povray.org>
> Alf
  Ah ha !!!  Same thing faked me out ;)
Y
Date: 19 Aug 2001 11:35:05
Message: <3b7fdca8@news.povray.org>
Y <Hos### [at] nettaxinet> wrote:
: Indeed.  Can you describe the lighting ?
: I'm wondering what the source of the *green* on the
: plane under the left sphere is . . .
  The green glass sphere just has pov3.1's caustics.
Date: 19 Aug 2001 12:21:58
Message: <3B7FE7A1.BD84A6CD@ignorancia.org>
  I think it is lighting. When lighting is good, all the rest seems to
be less important, bcos you feel the space. Anyhow, I notice the
reflection of the balls isn't blurred... is that normal with focal blur?
(I really never used it).
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 19 Aug 2001 12:27:19
Message: <3B7FEAE0.ED90859D@qwest.net>
Agreed.  Excellent composition and a fine render.
http://www.users.qwest.net/~dearmad
Why bother?  I'm not interesting.
But... maybe "Ballet pour ma fille" will be.
Date: 19 Aug 2001 12:55:20
Message: <3b7fef78@news.povray.org>
Warp that is stunning - very,very beautiful.
Mick
Date: 19 Aug 2001 13:51:46
Message: <3b7ffcb2@news.povray.org>
: Anyhow, I notice the
: reflection of the balls isn't blurred... is that normal with focal blur?
: (I really never used it).
  Yes, that's the physically correct behaviour (and which you will not get
with post-processed focal-blur).
  The balls are (approximately) at the same distance from the camera in
the reflection as viewed directly (with this camera location they are a bit
farther away in the reflection, but not so much that they get blurred visibly).
  This is what you get with real-life cameras as well.
Date: 19 Aug 2001 16:23:47
Message: <3f70ots4fk7bi637d5oogg2i7sefuces1s@4ax.com>
Somehow soothes me, so I have is as my KDE background. One needs
soothing while coding ;)
Peter Popov ICQ : 15002700
Date: 19 Aug 2001 18:02:34
Message: <3b80377a@news.povray.org>
"Warp" <war### [at] tagpovrayorg> in news:3b7fc3d8@news.povray.org...
nice .... extremely nice ...
two things make me wonder ...
1) the two spots on the black background(the brown and the white one): Are
they only 2 simple spheres with emitting media, or is there a better Idea
behind them ?
Or are they two 'normal' spheres very near the camera, so they got blurred
dramatically(But this would be very slow)?
2) the shadows below the brown and the blueish sphere are looking odd to
me...
I don't know how many lights you have used(I counted 2, but I think there are
at least 3), but it looks a bit dark to me... to dark... maybe there should
be some fill-light  to show, there is no hole below these spheres ...
but as a hole: nice pic ... can we expect a higher resolution ???
Jan Walzer <jan### [at] lzernet>
Date: 19 Aug 2001 22:44:50
Message: <3B807B54.1AC7624E@usfamily.net>
My god, that's crisp!  I always thought that when focal blur is used, it takes
over for AA.  But if that's the case, shouldn't we be seeing just a bit of bad
/ non AA-ing, at least somewhere?  This image holds none.  Its just the most
crisp image I think I've ever seen.  Beautiful...
-Law
Date: 20 Aug 2001 04:53:07
Message: <3B80D07B.E01B3A0F@gmx.de>
Really nice, but maybe it would look even better with some blurred &
variable reflection, photons, ... :-)
Date: 20 Aug 2001 08:06:08
Message: <3b80fd2f@news.povray.org>
Peter Popov <pet### [at] vipbg> wrote:
: Somehow soothes me, so I have is as my KDE background. One needs
: soothing while coding ;)
  I can render it with the resolution of your screen, if you want... :)
Date: 20 Aug 2001 08:14:16
Message: <3b80ff18@news.povray.org>
Flux <kid### [at] usfamilynet> wrote:
: My god, that's crisp!  I always thought that when focal blur is used, it takes
: over for AA.  But if that's the case, shouldn't we be seeing just a bit of bad
: / non AA-ing, at least somewhere?  This image holds none.  Its just the most
: crisp image I think I've ever seen.  Beautiful...
  I would also believe that the lack of antialiasing would cause aliasing
artifacts in the sharpest zone. However, it doesn't seem to be so. It may
be that even the smallest difference in sample ray directions is enough
to produce a smooth result.
  Of course proper focal blur settings are needed to get a smooth result.
These settings don't even make it slow: Rendering this image at 640x480
took less than 3 minutes in my 1.2GHz Athlon.
  (I don't remember the settings I used, and I don't have the scene file
here at work, as it is in my home computer...)
  By the way, the 640x480 version can be found at my images page:
http://iki.fi/warp/pics/
Date: 20 Aug 2001 08:22:04
Message: <3b8100eb@news.povray.org>
Jan Walzer <jan### [at] lzernet> wrote:
: 1) the two spots on the black background(the brown and the white one): Are
: they only 2 simple spheres with emitting media, or is there a better Idea
: behind them ?
: Or are they two 'normal' spheres very near the camera, so they got blurred
: dramatically(But this would be very slow)?
  I used a nice trick to get the light sources to "glow". The idea is not
mine, but unfortunately I can't credit the original author of the idea. I
just read about it somewhere (I really don't remember where). The idea is
simple but very ingenious.
  The camera is not looking at the scene, but in the exact opposite direction.
There's a plane in front of the camera with 100% mirror finish. The plane
has also specular highlighting (with a very small roughness). This simple
trick makes the light sources to "glow".
  Of course it has some side-effects: If you look closely at what the spheres
are reflecting, you'll see that they are reflecting themselves through this
mirror.
: 2) the shadows below the brown and the blueish sphere are looking odd to
: me...
: I don't know how many lights you have used(I counted 2, but I think there are
: at least 3), but it looks a bit dark to me... to dark... maybe there should
: be some fill-light  to show, there is no hole below these spheres ...
  There are just two light sources, those which are glowing.
  The shadows might look a bit odd because the light sources are so close
to the spheres.
: but as a hole: nice pic ... can we expect a higher resolution ???
  There's a 640x480 version at http://iki.fi/warp/pics/
  I can also render a bigger one (eg. 1024x768) if you want.
Date: 20 Aug 2001 09:47:40
Message: <3b8114fc$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:3b8100eb@news.povray.org...
Are
> : behind them ?
blurred
[snip]
direction.
Oh yes ... I expirienced this effect myself some time ago when I placed some
candles next the window.
It was a nice effect, especially when you calculated the focal blur for the
reflected objects, but still have the original objects visible in the
viewport (and you use some HQ fb-params)
spheres
> mirror.
I asked myself what they are reflecting there, but I decided it must be some
artifacts ..
> : me...
are
should
> to the spheres.
But now, knowing of the mirror, the shadows in their relation to the
lightsources are making sense
1152x864 ?
But if you open the sources I would render it myself in 2400x1800 and
V(ery)HQ fb-params ;)
Date: 20 Aug 2001 10:18:12
Message: <nt62ot45jr5pufhr7dd1h13tm6s8gq4jm9@4ax.com>
That'll be great, thanks. The res is 1024x768.
Date: 20 Aug 2001 13:02:54
Message: <slrn9o24rt.5gq.steve@zero-pps.localdomain>
I think it hits the spot.
  2:40pm  up 37 days, 16:44,  2 users,  load average: 1.04, 1.04, 1.00
Subject: 1024x768 version and source (Was: Simple is beautiful)
Date: 20 Aug 2001 14:26:55
Message: <3b81566d@news.povray.org>
Took 7 minutes to render. (Who says focal blur is slow?-) )
Download 'GlowTest.jpg' (74 KB)
Subject: Re: 1024x768 version and source (Was: Simple is beautiful)
Date: 20 Aug 2001 16:59:03
Message: <3b817a17@news.povray.org>
   - Warp -
Thanks ... now I can see it ...
Y
Date: 23 Aug 2001 01:29:15
Message: <3B84925A.7274BA06@faricy.net>
Hehe, very nice.
