POV-Ray : Newsgroups : povray.binaries.images : placing books Server Time
23 Oct 2026 12:44:10 EDT (-0400)
  placing books (Message 1 to 18 of 18)
Subject: placing books
Date: 9 Aug 2001 06:05:23
Message: <3b726063@news.povray.org>
I've just written a little macro to place books on a library (I needed it
for my irtc entry). The first queue uses a little amount of randomness, the
second one uses no randomness. Well, not much to say, I just liked the
effect and wanted to share it with POV community :).
(Oh, well, in my irtc entry I'm using books instead of 60ies coloured
superellipsoids...)
Jonathan.
Download 'libri.jpg' (93 KB)
Preview of image 'libri.jpg'
Subject: Re: placing books
Date: 9 Aug 2001 06:32:30
Message: <3b7266be@news.povray.org>
As I had my first look at it, it looked perfect. But as I had my second look
at it there were some books with strange or impossible positions. Please
have a look at the attached image. Maybe other values for seed will fix
this.
So long,
Bonsai
Download 'errors.gif' (37 KB)
Preview of image 'errors.gif'
Date: 9 Aug 2001 09:43:33
Message: <3B72937D.8CFC52BA@slpschools.org>
I really like the second queue.  I used to work at a library, and its almost a
perfect representation of how books slide down the shelf when there's nothing
to hold them together.  Very nice.
Also, I'm impressed with the beauty of radiosity and would love to see your
settings for this image.  Thanks in advance!
-Law
> superellipsoids...)
> Jonathan.
Date: 9 Aug 2001 13:30:57
Message: <3b72c8d1@news.povray.org>
Off course the macro is not physically correct, only geometrically...
Anyway you can always set a lower maximum angle to avoid these situations
(or play with the random seed, as you suggested).
Cheers,
Jonathan.
"Bonsai" <bon### [at] b0n541net> ha scritto nel messaggio
news:3b7266be@news.povray.org...
look
> this.
> So long,
> Bonsai
Date: 9 Aug 2001 13:36:53
Message: <3b72ca35@news.povray.org>
Thans Lawrence. Here are the settings (nothing extraordinary, pretty low
settings).
global_settings {
        ambient_light 0
        radiosity {
                pretrace_start 1
                pretrace_end 1
                recursion_limit 2
    count 80
    error_bound 0.2
       ini_option "+qr"}
A white a plane and a white skysphere (something really abused... ;) )
Probably the scene would look the same even with lower settings (7 hours of
rendering with 1 ghz machine :(...).
Jonathan.
Date: 9 Aug 2001 14:12:44
Message: <3B72D294.A0E43AC8@ignorancia.org>
  Hmmm.... "trace()" must help to do it more physically correct... still
don't know how, but I must try it (because my entry also must have
shelves with books...;)
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 9 Aug 2001 14:42:51
Message: <3b72d9ab@news.povray.org>
Well, this macro worked for me, and it looks quite physically realistic.
Download 'library.jpg' (35 KB)
Preview of image 'library.jpg'
Date: 9 Aug 2001 21:14:45
Message: <3b733585@news.povray.org>
as long as you ignore the bottom 3 rows..
PGP Public Key
Date: 10 Aug 2001 04:06:33
Message: <3B739625.B3BE1F88@aicoss.de>
Or the top 3 rows, for that matter. All "wrong" ;-)
Markus
Date: 10 Aug 2001 13:08:26
Message: <3b74150a@news.povray.org>
the
> superellipsoids...)
I've always wondered how you do things like that :-)
Is it something like
bookrotation = lastbookrotation*(some strange formula) ?
Peter
http://hertel.no/peter
Date: 11 Aug 2001 05:07:26
Message: <3B74F5B0.BE41BBAC@inapg.inra.fr>
You could try having a look at mine, to see how they compare.
http://www.oyonale.com/ressources/english/sources07.htm
G.
Graphic experiments
Pov-ray gallery
Date: 11 Aug 2001 08:45:57
Message: <3b752905@news.povray.org>
No strange formula. Just a bit of trig. The right formulae much depend on
your approach to the problem. My macro begins from a rotation value which
depens on the book position in the shelf (the books on the right are more
tilted) and on a random amount. Then it finds the distance of the book from
the previous one. Which is of course based on the rotation of the last book,
but also on the sizes of the two books (which could be different). So you
have to split your macro in several cases, because the formulae can be very
different.
For istance, suppose that the new rotation value is greater than the
previous one (a very common situation) and that the two books have such a
size that the second one leans against the previous one (and not viceversa).
If you indicate dist=(x coordinate of the point of contact between the
previous book and the *floor*) then you have to translate the second book to
dist+x_size_of_last_book/sin(radians(last_book_rotation))+y_size_of_new_book
*sin(radians(last_book_rotation-new_book_rotation))/sin(radians(last_book_ro
tation)) along the X axis. Just make a sketch on a sheet and you'll see
that.
Jonathan.
"Peter Hertel" <NOS### [at] hertelno> ha scritto nel messaggio
news:3b74150a@news.povray.org...
it
> the
> > superellipsoids...)
> Peter
Date: 11 Aug 2001 08:46:00
Message: <3b752908@news.povray.org>
Oh, well, yours is far more complete! My 20 lines macro can't compete.
Surely the math involved is the same (I can't understand why people are
frightened by the simplest trig formulae). Here trace() cannot be handy,
because there's no problem about overlapping. BTW, if the angle of a book is
forced to be greater than the previous one, then you get a boring but
physically correct result (just like the queue with no randomness in my
image).
Jonathan.
"Gilles Tran" <tra### [at] inapginrafr> ha scritto nel messaggio
news:3B74F5B0.BE41BBAC@inapg.inra.fr...
> G.
> Graphic experiments
> Pov-ray gallery
Date: 11 Aug 2001 09:53:07
Message: <3B7538A6.539900A6@inapg.inra.fr>
Must be the same, since both show the same problem, i.e. books standing more or
less upright when they should be sliding. I guess that a complete book macro
would have to take into account factors like mass or friction, and I agree that
trace() doesn't give a solution. But overall, it looks nice enough to be useful.
G.
Graphic experiments
Pov-ray gallery
Date: 11 Aug 2001 19:11:40
Message: <3b75bbac@news.povray.org>
Hmm.. figured it out to be something like that. I'll taka a look at it
someday. I guess it uses a reqursive macro, which I honestlty don't
understand, but I'll take a look at that someday, aswell :-)
Thanks a lot for enligtening me!
Great picture btw! I like the pretty colors.. oooh :)
-Peter
from
book,
very
> different.
viceversa).
to
> that.
Date: 11 Aug 2001 23:05:29
Message: <3B75F032.30266CDE@faricy.net>
JRG wrote:
> I can't understand why people are frightened by the simplest trig formulae
Could it have to do with their having been exposed to trig through the
wonderous public education system?
Date: 12 Aug 2001 04:33:11
Message: <3B763F40.F0EACEFF@ignorancia.org>
  Mostly... I wonder how I hated maths at school. Now I understand that
what I hated was the system, no the things I was learning.
  I also think that now maths can be learned in a less "abstract" way: I
myself know some teachers who use pov to graphically show maths to kids,
and they said it works pretty well to have them interested.
Date: 12 Aug 2001 04:55:10
Message: <Xns90FB6F14C7F7Bseed7@povray.org>
>   way: I
> kids, and they said it works pretty well to have them interested.
http://www.inetarena.com/~pdx4d/ocn/numeracy0.html
uses POV-Ray and Python to teach math.
Ingo
