POV-Ray : Newsgroups : povray.binaries.images : cdrom case again Server Time
18 Aug 2024 04:20:14 EDT (-0400)
  cdrom case again (Message 1 to 5 of 5)
Subject: cdrom case again
Date: 7 Jul 2001 10:03:17
Message: <3b4716a5$1@news.povray.org>
sorry about the last one being split into 2 parts, one of the check boxes in
OE settings had reset itself - i have cancelled both parts.
hmm, need better rad settings - see the spotchys
  radiosity {
    brightness       1.5
    count            500
    distance_maximum 0.0
    error_bound      0.05
    gray_threshold   0.0
    low_error_factor 0.05
    minimum_reuse    0.015
    nearest_count    4
    recursion_limit  1
PGP Public Key
Subject: Re: cdrom case again
Date: 7 Jul 2001 10:05:10
Message: <3b471716@news.povray.org>
and after all that I forget the blummin image.. arrrgghhh
PGP Public Key
Download 'radlighting-test.jpg' (57 KB)
Preview of image 'radlighting-test.jpg'
Date: 8 Jul 2001 11:12:10
Message: <MPG.15b296e39a54ce659897fa@NEWS.POVRAY.ORG>
In article <3b471716@news.povray.org>, Rick [Kitty5] says...
> Rick
Very convincing though the green is a little off to my taste :~)
Regards,  Sander
Date: 10 Jul 2001 09:20:20
Message: <3B4B018E.CA27E9D1@gmx.de>
Pure rad lighting on reflective and refractive objects - interesting, but
the same with light and photons would look nice too.
The CD-case itself looks somewhat wrong, the upper part should have some
striped structure on both sides so you can't look through it (or do your
cases differ from those here?)
Date: 10 Jul 2001 11:41:54
Message: <3b4b2242@news.povray.org>
I have 2 versions of that cd case - the one with the striped sides takes
hell of a lot longer to render (days longer), so i genrally use the LQ
version for test renders
PGP Public Key
