POV-Ray : Newsgroups : povray.binaries.images : Added trace() to Clutter macro Server Time
12 Nov 2026 06:56:35 EST (-0500)
  Added trace() to Clutter macro (Message 1 to 18 of 18)
Subject: Added trace() to Clutter macro
Date: 6 Jul 2001 14:41:41
Message: <3b460665@news.povray.org>
I followed Norbert's suggestion and added the possibility to place the
objects on a landscape (just one line of code).
My next effort is something concerning the textures of the placed objects
(i.e. they could be influenced by another map, or by their position, or by
the relative position of the objects around...) but I haven't got any good
and clear idea yet.
In this example 500 spheres and 500 boxes are placed on a landscape
following a simple checker pattern.
Feedback is appreciated.
Jonathan.
Download 'clutter4.jpg' (110 KB)
Preview of image 'clutter4.jpg'
Subject: Re: Added trace() to Clutter macro
Date: 6 Jul 2001 15:24:20
Message: <3b461064@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3b460665@news.povray.org...
> and clear idea yet.
Could you include re-orientation of the objects to the normal of the
landscape as an option?
Looks great!
All the best,
Andy
Date: 6 Jul 2001 15:56:06
Message: <3b4617d6$1@news.povray.org>
<snip>
That's coming along nicely! In fact this does exactly what I was trying to
do with a grass macro that never went anywhere. Could you post the one line
of code? I never got the hang of the trace function.
Date: 7 Jul 2001 08:33:04
Message: <3b470180$1@news.povray.org>
If you want to know the y coordinate of a point (i.e. its height):
#local _alt=vdot(y,trace( land, temp_pos+10000*y,-y));  // check the
altitude
or, even easier:
#local _alt=(trace( land, temp_pos+10000*y,-y)).y;  // check the altitude
(I didn't check if the last notation works, but it should).
Where land is the landscape object,
temp_pos is the coordinate (of XZ plane) you want to check (you are supposed
to not use landscapes higher than 10000 units...).
For normal calculation things are slightly more complicate (even if it's
just another line of trig formulae).
Jrg.
Date: 7 Jul 2001 08:33:36
Message: <3b4701a0@news.povray.org>
Done.
Thank you for the suggestion!
jrg.
Download 'clutter5.jpg' (69 KB)
Preview of image 'clutter5.jpg'
Date: 7 Jul 2001 10:37:54
Message: <3b471ec2@news.povray.org>
You gotta animate that!
Date: 7 Jul 2001 11:12:05
Message: <3b4726c5@news.povray.org>
Yeah, I was thinking so too.
I'll try.
Jonathan
"Bill DeWitt" <bde### [at] cflrrcom> ha scritto nel messaggio
news:3b471ec2@news.povray.org...
Date: 7 Jul 2001 13:08:16
Message: <3b474200@news.povray.org>
...and here's how it looks with a heightfield.
2700 spikes and no probability map this time.
jrg.
Download 'clutter6.jpg' (134 KB)
Preview of image 'clutter6.jpg'
Date: 7 Jul 2001 13:16:51
Message: <3B474469.9A81C50@qwest.net>
Oh good lord.  It *is* now a VERY COOL macro...  how
about object orientation parameters, possible to add in
or not?
-peter
http://www.users.qwest.net/~dearmad
Why bother?  I'm not interesting.
But... maybe "Ballet pour ma fille" will be.
Date: 7 Jul 2001 13:18:12
Message: <3B4744BA.E5152433@qwest.net>
this is starting to look a little like fur or... I
dunno something sort of wicked... :o)
-peter
Date: 7 Jul 2001 13:21:05
Message: <3b474501$1@news.povray.org>
news:3b474200@news.povray.org...
    Ok, this is cool and all, but it looks like your normal orientation is
reading one point only. In a situation like this, it might be nice if it
were able to average the normals in the local area. that way they would all
seem to stick out of the ground at what we perceive as the general tilt of
the ground in that area.
    Just an idea...
Date: 7 Jul 2001 15:51:30
Message: <3b476842@news.povray.org>
you're probably right. In fact objects have to be a lot smaller than the
landscape itself in order to get good results.
This macro is going beyond my own aspectatives (I just wanted to randomly
place objects on a plane), but now I feel I have to go further.
How many normals vectors you think I should average?
Jonathan.
news:3b474501$1@news.povray.org...
all
>     Just an idea...
Date: 7 Jul 2001 17:15:13
Message: <3b477be1@news.povray.org>
    The radius of the object plus 10% or one ring of triangles around the
object?
Date: 7 Jul 2001 18:36:53
Message: <3B478D35.701F00F4@faricy.net>
> object?
A central point and a ring of six you mean?  They should probably be
weighted less the farther away.  For overkill you could do another ring
of twelve around that...
Date: 7 Jul 2001 18:58:12
Message: <3b479404@news.povray.org>
    Well, thinking about it (and admitting that I have no skill at such
things) it would seem that the radius of the object would normally be
enough. If the object is unusually shaped it might be a problem, but for the
most part, if you place an object on an irregular surface, the points where
it touches are what determine the orientation, not the point under the
center.
Date: 7 Jul 2001 21:13:16
Message: <slrn9kfcr5.aqc.ron.parker@fwi.com>
>altitude
>or, even easier:
You shouldn't need another line of trig.  You should be able to do:
#local _norm = <0,0,0>;
#local _alt=trace(land, temp_pos+10000*y,-y,_norm).y;
and find the normal at the intersection in the _norm vector (or <0,0,0> if
no intersection was found.)
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 8 Jul 2001 07:57:47
Message: <3b484abb$1@news.povray.org>
Oh well, I did it. The trig formula is used when rotating the object. But
I've not got any problem with it.
jrg.
"Ron Parker" <ron### [at] povrayorg> ha scritto nel messaggio
news:slr### [at] fwicom...
> >altitude
> >or, even easier:
supposed
L(R.x)L(R.y)0,0
else's
Date: 8 Jul 2001 22:56:56
Message: <3B491BAA.D960DBD0@faricy.net>
> center.
Hmm, actually then, rather than averaging normals, it would probably be
better to actually use the plane that goes through or best fits the
points around the edge.  With three points it's simple vcross
calculations, with six you could probably just use two interlaced sets
of three and average them.
