POV-Ray : Newsgroups : povray.binaries.images : Impossible triangle Server Time
13 Jun 2026 10:49:08 EDT (-0400)
  Impossible triangle (Message 21 to 26 of 26)
Subject: Re: Answer (Was: Impossible triangle)
Date: 7 Jul 2001 18:33:27
Message: <3B478C67.2212732D@faricy.net>
Warp wrote:
>   The other trick is, however, more difficult to see, and it's the apparent
> perspective of the image.
>   The camera is orthographic, so the perspective is fake.
I was right!  :)
Subject: Re: Impossible triangle
Date: 7 Jul 2001 22:28:43
Message: <3b47c55a@news.povray.org>
David Fontaine <dav### [at] faricynet> wrote:
: The triangle is orthographic and the rest is not?
  Everything in the image is orthographic.
  I can't imagine any way of creating an orthographic and a perspective image
at the same time with one render and no external files... :)
  The background looks like it has perspective, but that's the fake. Things
are only rotated so that they look like that, and the pattern in the floor
is the radial pattern.
Date: 8 Jul 2001 11:03:54
Message: <MPG.15b2950129801e2b9897f8@NEWS.POVRAY.ORG>
In article <3B478BDD.C5C48896@faricy.net>, David Fontaine says...
> Warp wrote:
> >   The impossible triangle with cubes was first invented by the
> > Swedish artist Oscar Reutersvard back in 1934.
> >   This image has two tricks. The first one is obvious (the triangle). But
> > there's another trick which may not be obvious. Can you guess what it is?
I was right first: beat you with about 10h 54m 32 s :))
Regards,  Sander
Date: 8 Jul 2001 11:06:35
Message: <MPG.15b295a4e234c2d49897f9@NEWS.POVRAY.ORG>
In article <3b471b43@news.povray.org>, Warp says...
>   The most obvious trick in the image is, of course, the triangle itself
> (one of the cubes is clipped by a plane so that the cube right behind it
> shows up; also some of the cubes have a no_shadow applied to them in order
> to avoid annoying and even revealing shadows).
>   The pattern on the floor is not a gradient pattern, as it may seem, but
> actually a radial pattern. The other cubes in the image are rotated so that
> the look like they were "distorted" by the perspective althought they aren't.
> The cube on the right is actually the intersection of two superellipsoids.
I was looking for a sign on one of the shadowless cubes where there
would be a break: stupid not to have thought of clipping...
Cleverly done, though :)
Regards,  Sander
Date: 8 Jul 2001 22:53:16
Message: <3B491ACE.A5D1098A@faricy.net>
Well, obviously you can't have both perspectives in the same render...
I thought perhaps you did perspective and faked the orthographic part so
they'd line up, but your way sounds easier.
Date: 9 Jul 2001 00:47:35
Message: <3B493766.BFB886C5@bigfoot.com>
Fantastic Image!
I've read the explanations, looked again and again at the picture
and still don't understand all that was done.
I would love to see the .pov code that did this, but understand
completely if you were a bit "possessives" of this. Would you at least
consider a rendering from a different camera angle so those as
dense as I could begin to understand how you are managing such
a deceptive image?
