POV-Ray : Newsgroups : povray.binaries.images : Stacking? Server Time
12 Nov 2026 06:56:35 EST (-0500)
  Stacking? (Message 1 to 4 of 4)
Subject: Stacking?
Date: 2 Jul 2001 01:26:58
Message: <3b400622@news.povray.org>
This may be a little off topic but I was wondering how it might be possible
to implement a stack in povray? Over the past few days I've been thinking of
developing a maze algorithm for pov. I've done some searching on the net and
from what I can see "depth first search" is a promising algorithm to use.
Unfortunately I have almost no programming ability so it's going to be a
little tricky to implement this. I was thinking of using 2 arrays to create
the maze, one would keep track of the visited cells in the maze and the
other would keep track of the walls. I might then be able to use a depth
first search like method to step through the cells randomly, knocking down
walls as I went. When it was finished I could then build the maze using the
wall array. This would require a stack I believe though. Does this sound
like a promising approach? I really don't know how I'm going to go about
this though, I guess I've got to just jump in and see what happens.
I've got this idea for a maze scene where all the walls of the maze are
lined with outdoor vendor stalls. There would be stalls selling fruit,
trinkets, and anything I could come up with, something reminiscence of the
streets of morocco, I think.
Subject: Re: Stacking?
Date: 2 Jul 2001 08:05:25
Message: <slrn9k07if.1pn.steve@zero-pps.localdomain>
[snip]
For p.b.i yes, pobably well suited to povray.general as it is
a POV related subject.  This group is for binary posts.
  8:08am  up  6:01,  2 users,  load average: 1.02, 1.02, 1.00
Date: 2 Jul 2001 23:31:56
Message: <3b413cac$1@news.povray.org>
"Thomas Lake" <tla### [at] homecom> wrote in message
news:3b400622@news.povray.org...
possible
of
and
create
the
Probably shouldn't have posted this in a binary images group, actually.  ;-)
Anyway, if you're looking for a method for creating mazes, look here:
http://www.donovansweb.com/~chaffe/
rc
Date: 17 Jul 2001 20:10:27
Message: <3b54d3f3@news.povray.org>
possible
of
and
    If you want to do what I think you want to do, you're on the right lines
with a depth first algorithm, but, you don't need to implement the stack in
the POV scene description language. I take it you want a stack so that you
can implement a recursive algorithm ?
    Well, the POV scene description language supports recursion ! You just
need to do something like this :
#macro recursive(count)
 #debug "."
 #if(count>0)
  recursive(count-1)
 #debug "\n"
recursive(10)
    This is untested, but if you stick it into a .pov file and run it you
should see 11 periods appear in the debug window/on screen...
BTW, I implemented a similar algorithm when I was at Uni, only my program
had to solve a maze rather than build one, but the principle is basically
the same...
Scott Hill.
Software Engineer.
E-Mail        : sco### [at] innocentcom
Pandora's Box : http://www.pandora-software.com
*Everything in this message/post is purely IMHO and no-one-else's*
