POV-Ray : Newsgroups : povray.binaries.images : Request for help with media Server Time
23 Oct 2026 15:26:32 EDT (-0400)
  Request for help with media (Message 1 to 16 of 16)
Subject: Request for help with media
Date: 21 Jun 2001 22:18:39
Message: <3b32aaff@news.povray.org>
Attached is a volumetric rendering using media.  What is the best way (i.e.
best quality for shortest rendering time) to get rid of the graininess and
get nice, smooth colors?
Any help would be appreciated.
Jim
Download 'rohf_density_001.jpg' (65 KB)
Preview of image 'rohf_density_001.jpg'
Subject: Re: Request for help with media
Date: 21 Jun 2001 23:05:22
Message: <3B32B5A2.357531CC@pacbell.net>
Code example and version of Pov you are using would be very helpful,
Jim. MegaPov's multi-method media feature can really help smooth out
the graininess and reduce rendering times when used properly but
there are speed vs. quality trade-offs no matter what you do :(
Date: 21 Jun 2001 23:38:47
Message: <3b32bdc7@news.povray.org>
Thanks Ken.
I've attached a copy of the pov and include files.  I haven't included the
df3 file since it's rather large.
Jim
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3B32B5A2.357531CC@pacbell.net...
(i.e.
and
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Download 'rohf_density_001.pov.txt' (6 KB) Download 'rohf_density_Density_001_001_media_Pos.inc.txt' (12 KB)
Date: 21 Jun 2001 23:39:49
Message: <3b32be05$1@news.povray.org>
Also, I am using version 3.1g.
Thanks again.
Jim
(i.e.
and
Date: 22 Jun 2001 00:31:30
Message: <3b32ca22$1@news.povray.org>
"Jim Kress" <kre### [at] kressworkscom> wrote in message
news:3b32be05$1@news.povray.org...
You might want to consider looking into MegaPOV.  The "method 3" of media
seems to work pretty well (quickly, too):
http://nathan.kopp.com/
-Ian
Date: 22 Jun 2001 00:36:49
Message: <3b32cb61$1@news.povray.org>
To improve the quality, btw, imcrease the number of samples up.  I'd say
samples 3,5 should work for what you're using.  Just stick that into all the
media blocks you're using, and the effect should look real nice when you're
done.
Prepare to leave your computer on overnight, though :-/
-Ian
Date: 22 Jun 2001 00:41:17
Message: <3b32cc6d@news.povray.org>
Thanks Ian.  I'll give it a try.
Jim
"Ian Burgmyer" <the### [at] hotmailcom> wrote in message
news:3b32cb61$1@news.povray.org...
the
you're
> done.
> -Ian
Date: 22 Jun 2001 00:49:50
Message: <3b32ce6e@news.povray.org>
Ian,
OK. Tried your suggestion with megapov 0.7  The results are attached.
Media looks better except the top and both sides have been chopped off (or
left off).  Any ideas what's going wrong or how to fix?
Thanks.
Jim
Download 'rohf_density_001_mpov7.jpg' (29 KB)
Preview of image 'rohf_density_001_mpov7.jpg'
Date: 22 Jun 2001 00:56:03
Message: <3b32cfe3$1@news.povray.org>
This was using
   method 3
   intervals 1
   samples 3,5
   confidence 0.999
   variance 1/1000
Jim
news:3b32ce6e@news.povray.org...
> Ian,
> Thanks.
> Jim
Date: 22 Jun 2001 00:59:38
Message: <3b32d0ba@news.povray.org>
Here's another result using:
   method 3
   intervals 20
   samples 3,5
   confidence 0.999
   variance 1/1000
What's going on with this?  Looks like the sampling algorithm is not
behaving properly.
Jim
the
you're
> done.
> -Ian
Download 'rohf_density_001_mpov7_2.jpg' (29 KB)
Preview of image 'rohf_density_001_mpov7_2.jpg'
Date: 22 Jun 2001 03:13:24
Message: <3b32f014@news.povray.org>
news:3b32d0ba@news.povray.org...
>    method 3
>    intervals 20
>    samples 3,5
>    confidence 0.999
>    variance 1/1000
> behaving properly.
I hadn't seen the number of layers your df3 might be made up of but that
intervals change suggests to me there are a few.   Nathan Kopp has made the
method 3 somehow figure the intervals out on it's own (I'm guessing) and
maybe what you really need to do is increase the samples.  I often use equal
numbers.  Perhaps a samples 10,10 is okay for you?  If not there's always
method 2 and samples 5,5 could possibly do well.
Bob H.
Date: 22 Jun 2001 11:28:33
Message: <3b336421@news.povray.org>
Thanks.  I'll give it a try.
Jim
"Bob H." <omn### [at] msncom> wrote in message
news:3b32f014@news.povray.org...
> >    method 3
> >    intervals 20
> >    samples 3,5
> >    confidence 0.999
> >    variance 1/1000
> > behaving properly.
the
equal
> Bob H.
Date: 22 Jun 2001 13:24:11
Message: <3b337f3b@news.povray.org>
OK.  It turns out that, although media is supposed to be contained within a
unit cube, it really isn't.
If you lok at my inc file, you'll see I used a unit cube box to contain the
media so it could be rendered.  Well, if I change the box specification from
 box{ <0,1>
to
 box{ <0,0,-2>, <2,2,2>
the problem goes away, as one can see in the attached image.  Hopefully this
does not indicate there is a bug in megapov.
Thanks for your suggestions!
Jim
Download 'rohf_density_001_5,5_samples_intervals_10_bounding_box_fixed.jpg' (27 KB)
Preview of image 'rohf_density_001_5,5_samples_intervals_10_bounding_box_fixed.jpg'
Date: 22 Jun 2001 17:12:51
Message: <3b33b4d3@news.povray.org>
news:3b337f3b@news.povray.org...
a
the
from
>  box{ <0,1>
> to
this
I can't see that happening here, using spiral.df3 in place of your df3, the
media is contained within the 1 unit cube as described in the doc.
I thought perhaps it could be wave type but default is ramp_wave and looked
okay to me anyway. Most likely thing could be you are getting some sort of
perspective trouble.  Make your box transmit 0.5 instead of 1 and you can
see where the sides are.
Bob H.
Date: 24 Jun 2001 16:06:43
Message: <3B3648D1.D868817C@pobox.com>
> (i.e. best quality for shortest rendering time) to get rid of the
> graininess and get nice, smooth colors?
I think it's quite pretty as is.
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 24 Jun 2001 17:23:22
Message: <3b365a4a$1@news.povray.org>
Thanks.
Jim
"Anton Sherwood" <bro### [at] poboxcom> wrote in message
news:3B3648D1.D868817C@pobox.com...
