Attached is a volumetric rendering using media. What is the best way (i.e.
best quality for shortest rendering time) to get rid of the graininess and
get nice, smooth colors?
Any help would be appreciated.
Jim
Download 'rohf_density_001.jpg' (65 KB)
Preview of image 'rohf_density_001.jpg'
Code example and version of Pov you are using would be very helpful,
Jim. MegaPov's multi-method media feature can really help smooth out
the graininess and reduce rendering times when used properly but
there are speed vs. quality trade-offs no matter what you do :(
Thanks Ken.
I've attached a copy of the pov and include files. I haven't included the
df3 file since it's rather large.
Jim
"Ken" <tyl### [at] pacbell net> wrote in message
news:3B32B5A2.357531CC@pacbell.net...
(i.e.
and
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Download 'rohf_density_001.pov.txt' (6 KB)
Download 'rohf_density_Density_001_001_media_Pos.inc.txt' (12 KB)
Also, I am using version 3.1g.
Thanks again.
Jim
(i.e.
and
"Jim Kress" <kre### [at] kressworks com> wrote in message
news:3b32be05$1@news.povray.org...
You might want to consider looking into MegaPOV. The "method 3" of media
seems to work pretty well (quickly, too):
http://nathan.kopp.com/
-Ian
To improve the quality, btw, imcrease the number of samples up. I'd say
samples 3,5 should work for what you're using. Just stick that into all the
media blocks you're using, and the effect should look real nice when you're
done.
Prepare to leave your computer on overnight, though :-/
-Ian
Thanks Ian. I'll give it a try.
Jim
"Ian Burgmyer" <the### [at] hotmail com> wrote in message
news:3b32cb61$1@news.povray.org...
the
you're
> done.
> -Ian
Ian,
OK. Tried your suggestion with megapov 0.7 The results are attached.
Media looks better except the top and both sides have been chopped off (or
left off). Any ideas what's going wrong or how to fix?
Thanks.
Jim
Download 'rohf_density_001_mpov7.jpg' (29 KB)
Preview of image 'rohf_density_001_mpov7.jpg'
This was using
method 3
intervals 1
samples 3,5
confidence 0.999
variance 1/1000
Jim
news:3b32ce6e@news.povray.org...
> Ian,
> Thanks.
> Jim
Here's another result using:
method 3
intervals 20
samples 3,5
confidence 0.999
variance 1/1000
What's going on with this? Looks like the sampling algorithm is not
behaving properly.
Jim
the
you're
> done.
> -Ian
Download 'rohf_density_001_mpov7_2.jpg' (29 KB)
Preview of image 'rohf_density_001_mpov7_2.jpg'
news:3b32d0ba@news.povray.org...
> method 3
> intervals 20
> samples 3,5
> confidence 0.999
> variance 1/1000
> behaving properly.
I hadn't seen the number of layers your df3 might be made up of but that
intervals change suggests to me there are a few. Nathan Kopp has made the
method 3 somehow figure the intervals out on it's own (I'm guessing) and
maybe what you really need to do is increase the samples. I often use equal
numbers. Perhaps a samples 10,10 is okay for you? If not there's always
method 2 and samples 5,5 could possibly do well.
Bob H.
Thanks. I'll give it a try.
Jim
"Bob H." <omn### [at] msn com> wrote in message
news:3b32f014@news.povray.org...
> > method 3
> > intervals 20
> > samples 3,5
> > confidence 0.999
> > variance 1/1000
> > behaving properly.
the
equal
> Bob H.
OK. It turns out that, although media is supposed to be contained within a
unit cube, it really isn't.
If you lok at my inc file, you'll see I used a unit cube box to contain the
media so it could be rendered. Well, if I change the box specification from
box{ <0,1>
to
box{ <0,0,-2>, <2,2,2>
the problem goes away, as one can see in the attached image. Hopefully this
does not indicate there is a bug in megapov.
Thanks for your suggestions!
Jim
Download 'rohf_density_001_5,5_samples_intervals_10_bounding_box_fixed.jpg' (27 KB)
Preview of image 'rohf_density_001_5,5_samples_intervals_10_bounding_box_fixed.jpg'
news:3b337f3b@news.povray.org...
a
the
from
> box{ <0,1>
> to
this
I can't see that happening here, using spiral.df3 in place of your df3, the
media is contained within the 1 unit cube as described in the doc.
I thought perhaps it could be wave type but default is ramp_wave and looked
okay to me anyway. Most likely thing could be you are getting some sort of
perspective trouble. Make your box transmit 0.5 instead of 1 and you can
see where the sides are.
Bob H.
> (i.e. best quality for shortest rendering time) to get rid of the
> graininess and get nice, smooth colors?
I think it's quite pretty as is.
Anton Sherwood -- br0### [at] p0b0x com -- http://ogre.nu/
Thanks.
Jim
"Anton Sherwood" <bro### [at] pobox com> wrote in message
news:3B3648D1.D868817C@pobox.com...
