I've changed the ocean function, toned down the area light and added a
couple
of clouds. Render time ~20 hours
I thought about adding some birds or plants, but I kinda like the desolate
look.
Comments? Suggestions?
Gail
* gsh### [at] monotix co za * Step into the abyss, *
* http://www.rucus.ru.ac.za/~gail/ * and let go. Babylon 5 *
* The difficult we do immediately, the impossible takes a little longer *
Download 'OceanGate.jpg' (39 KB)
Preview of image 'OceanGate.jpg'
In article <3b1fc615@news.povray.org>, Gail Shaw says...
> couple
> look.
> Gail
The atmosphere and colour are very nice: I should not add much, or even
anything. Only IMO the 2 clouds look a bit too much like they were
painted on afterwards :)
Regards, Sander
I like this image alot. Something about the artifice of that structure and
the elemental quality of the ocean. The water texture is coming up real
good. I suspect that a chop like that would be compounded on a smaller scale,
an effect that many seem to be getting by doing just that... adding a scaled
down replica of the same rmf into the first. The uniformity of the wood
texture is striking me too. What if the rocks were a volcanic black?
> couple
> look.
> Gail
> [Image]
> couple
> look.
> Comments?
Very good, however...
The water seems to be a tad too reflective. It does look more like snow
than water. There should also be, as J. Charter pointed out, smaller
wavelets and ripples on the big waves.
Since most of the illumination comes from the setting sun, the back side
of the rocks and the structure should be almost black. The structure
doesn't appear to have any shadow.
How come the Sun is a bright yellow, yet the highlight it produces on
the water is almost white?
> Suggestions?
- Moss/algae on the rocks.
- The rocks should be wet around the water level. At least as high as
the waves hit.
- Foam near the rock edges (although I think this would prove rather
hard to do!)
You probably want to kill me by now, so I'll shut up.
Francois Labreque | Now, at this point, I am not even going to tell you
flabreque | to twiddle your knob, because as we all know, you
@ | have had plently of practice in that skill by now...
videotron.ca | - StvCD7
> look.
Mee too.
I love the overall tone and feel of this image but the clouds on the left
look kinda cheesy. You could lose them and not hurt the image at all.
j charter <jrc### [at] aol com> wrote in message
news:3B204F43.6BEC9093@aol.com...
scale,
scaled
Will do. There is already a smaller version, I think it's a little too
small.
I'll roughen it up a bit
I'll give that a try.
Gail
There's always a 'but' <grin>
> than water.
I'll tone it down a bit
The sun is the only light in the scene. I'll try dropping the ambient a bit.
I think the shadows are getting lost on the dark rock and the reflection.
Um, because the sun is yellow, but the lightsource is white. Will fix.
> > Suggestions?
Will try
> the waves hit.
Shouldn't be too hard
> hard to do!)
<shudder>
Thanks
Gail
Sander <san### [at] stols com> wrote in message
news:MPG### [at] NEWS POVRAY ORG...
It seems I need better clouds.
Gail
Ken <tyl### [at] pacbell net> wrote in message
news:3B205B25.35AAC631@pacbell.net...
I want some clouds there, think I need to experiment a lot more with media
clouds. (Those were just scaled spheres with spherical density scattering
and
absorbtion media)
Gail
"Gail Shaw" <gsh### [at] monotix co za> wrote in message
news:3b206bce@news.povray.org...
> Gail
Opinions are just that, opinions. I personally like the look of it. Fits
with the oriental picture theme.
Bob H.
> couple
> look.
The water texture looks really good now, I am just not sure about the
scale of the waves. The clouds in front of the sun should be darker.
Christoph Hormann <chr### [at] gmx de>
Christoph Hormann <chr### [at] gmx de> wrote in message
news:3B208651.678B7996@gmx.de...
> scale of the waves.
I'm going to reduce the vertical scale and add a second smaller.
If the waves aren't so big, I should be able to get away without
having to add foam on the waves
I'm thinking about redoing the clouds completely, keeping the
idea of a few scattered near the horizon.
Gail
For the foam, how about using warps in the areas of the rocks? I've never used
warps before, so I'm not really sure if it would work.
I've got an idea on how to do the foam, here's the pseudo-code:
difference
{waves with slightly exagerated verticle scale // red line on pic -
foam
pigment{foam}
{Waves - as in the scene} // black
line - water
The exagerated wave should only show over the top of the wave.
Hope this helps - if you want to do the foam.
- Nekar
Download 'Graphic1.jpg' (10 KB)
Preview of image 'Graphic1.jpg'
Another approach might be to use a gradient y for two different textures -
one for the normal water, one for the foam. Give them different normals and
blend them a little bit. That does not help for your problem if you just
want to add foam around the rocks. But you could "raise" the water around
the rocks a bit (with some formulas which multiplies those areas with
something like 1.2 f.e) - it might work.
Marc-Hendrik
>couple
>look.
I don't knwo how you're doing the water but it looks like concrete
with all those hard straight edges. Apart from that it looks great.
Steve email mailto:ste### [at] zeropps uklinux net
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
3:33pm up 126 days, 16:23, 2 users, load average: 1.00, 1.00, 1.00
Very nice pic. Good lighting and composition.
Minor improvements I would suggest, maybe make the clouds more
transparent, and more color change in the sky. How are the clouds
done? If they're no media, try media.
David Fontaine <dav### [at] faricy net> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
David Fontaine <dav### [at] faricy net> wrote in message
news:3B22FF33.5F83AB9B@faricy.net...
Fade to blue faster? or something else
> How are the clouds
spheres filled with scattering media.
Gail
Nah, changed my mind.
> > How are the clouds
Hmm. They don't look very 3D though. Don't know what you should do.
