POV-Ray : Newsgroups : povray.binaries.images : Le Divan D'Ivan (~104kau) Server Time
12 Nov 2026 07:20:43 EST (-0500)
  Le Divan D'Ivan (~104kau) (Message 1 to 13 of 13)
Subject: Le Divan D'Ivan (~104kau)
Date: 31 May 2001 09:06:23
Message: <3b1641cf@news.povray.org>
Thanks to Fabien Mosen for the title. I hope you like this version better.
No time to comment... sorry. Ciao...
Download 'le_divan_d'ivan.jpg' (74 KB)
Preview of image 'le_divan_d'ivan.jpg'
Subject: Re: Le Divan D'Ivan (~104kau)
Date: 31 May 2001 15:49:52
Message: <3b16a060@news.povray.org>
I do! Especially the floor. It's a bit dark though.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated May 10)
Date: 1 Jun 2001 00:18:27
Message: <3B1716F7.86D836A7@pacbell.net>
Looks nifty. My only comment would be with that much light outside, and
the windows open, it shouldn't be that dark inside.
Ken Tyler
Date: 1 Jun 2001 00:52:37
Message: <3b171f95@news.povray.org>
:( First, it was too bright, and without contrast... now it's too dark...
you can't have both... Grrr! I'll see what I can do...
Date: 1 Jun 2001 00:53:34
Message: <3b171fce@news.povray.org>
> Looks nifty.
Keen, Ken. :)
I know, but see my reply to Rune...
Date: 1 Jun 2001 01:11:21
Message: <3B17242D.DB3BFF1D@gmx.de>
The lighting looks much better now, but it seems to be floating in the
air,  there needs to be something outside the window, doesn't it?
Date: 1 Jun 2001 05:37:41
Message: <3b176265@news.povray.org>
Used radiosity? Try a recursion level of two to make the scene brighter (and
maybe a higher brigtness value in the radiosity definition..something like
1.2)
Paul
Tony[B] <ben### [at] catholicorg> schrieb in im Newsbeitrag:
3b1641cf@news.povray.org...
Date: 1 Jun 2001 11:34:58
Message: <3b17b622@news.povray.org>
Well, I'm glad someone likes the lighting... :) And, yes, you're right...
what do you suggest I add outside? I was thinking maybe some grass or
something.
Date: 1 Jun 2001 11:36:13
Message: <3b17b66d@news.povray.org>
(and
> 1.2)
Yes, I did. I won't use a recursion of 2 because that ruins the radiosity
which I use, and I'm already using a brightness >2. I've made the
fill-lights an eensy bit brighter.
Date: 1 Jun 2001 12:18:56
Message: <3B17C0A7.86104DED@gmx.de>
> something.
Grass sounds good, or maybe water... :-)
Date: 2 Jun 2001 03:09:11
Message: <0f3hht0o5epufjlnvn34nb3re9otjhuh2p@4ax.com>
On Thu, 31 May 2001 23:49:39 -0600, "Tony[B]" <ben### [at] catholicorg>
On a sunny day the irradiance of sunlit and shadowed areas can be off
by a factor of 10^5 and even more. Of course, our eyes react
non-linearly but still, trying to represent this on a screen is a
heavy task. Kari seems to know the most about this stuff, maybe if
you're a good boy... ;)
Peter Popov ICQ : 15002700
Date: 2 Jun 2001 03:09:12
Message: <0k3hhto1u902ghkoukt70ktao72ef0k50q@4ax.com>
On Fri, 1 Jun 2001 10:33:13 -0600, "Tony[B]" <ben### [at] catholicorg>
 >2?! Keep brightness low (0.75 - 1) and use a recursion of 2. Lower
diffuse and maybe increase brilliance a bit, that should give you more
contrast. Ditch the fill lights altogether except if you really need
them, but use light groups to only illuminate the parts you want.
And then show us the result :)
Date: 4 Jun 2001 03:04:32
Message: <3b1b3300@news.povray.org>
Tony[B] <ben### [at] catholicorg> wrote in message
news:3b17b622@news.povray.org...
> something.
Top of a tree, distant hills.
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.        Babylon 5   *
* The difficult we do immediately, the impossible takes a little longer *
