POV-Ray : Newsgroups : povray.binaries.images : Re: Problem with photons. Server Time
18 Aug 2024 14:22:02 EDT (-0400)
  Re: Problem with photons. (Message 1 to 3 of 3)
Subject: Re: Problem with photons.
Date: 28 Apr 2001 12:19:44
Message: <slrn9elqim.nm4.steve@zero-pps.localdomain>
On Sat, 28 Apr 2001 13:00:32 +0200, JRG wrote:
>These two images refer to the same scene, but the big one has completely
>white photons.
>Why did this happen? I can also see some reflection errors in the plane
>(maybe because I reduced the accuracy of the isosurface to 10^-2).
>Thanks in advance.
>Jonathan.
Is the Isosurface Object Library still going, and if so is this in it
yet?
  3:41pm  up 85 days, 16:27,  2 users,  load average: 1.03, 1.13, 1.10
Date: 28 Apr 2001 20:50:37
Message: <3aeb655d@news.povray.org>
> yet?
we are planning to put an object (inc iso surfaces) library into
povray.co.uk, but there is quite a lot of other things i have to do before i
get into that - will put it on the list of things todo after then next big
update
PGP Public Key
Date: 29 Apr 2001 03:42:59
Message: <3AEBC61C.4568D27@gmx.de>
> white photons.
> Thanks in advance.
> Jonathan.
If you use media for the glass interior, there is a media switch for
photons you can try.
