POV-Ray : Newsgroups : povray.binaries.images : looking for settings for transparent plastic with radiosity (WIP) Server Time
18 Oct 2026 23:10:19 EDT (-0400)
  looking for settings for transparent plastic with radiosity (WIP) (Message 1 to 6 of 6)
Subject: looking for settings for transparent plastic with radiosity (WIP)
Date: 23 Apr 2001 12:16:43
Message: <3ae4556b@news.povray.org>
here are settings (MegaPOV) for below image
has anybody idea how to improve speed and look of it ?
the object is box for plantation of sprout (I hope it is proper word)
it is made of transparent plastic - I think that it could get settings from
transparent LEGO bricks but I can't find any - I think current version is rather
ghost instead of plastic :-(
the setting are inspired by sample files and some posts
global_setting{
  radiosity{recursion_limit 5 brightness 1.2 normal on}
  max_intersections 255
  max_trace_level 255
  photons{count 20000 gather 20,100 autostop 0}
object{
  Platform() // returns CSG
  texture{
    pigment{color rgb 1 transmit .95 }
    finish{
      ambient -0.3
      diffuse 0.8
      specular 0.1
      roughness 0.1
      metallic
      brilliance 1
      reflection_type 1
      reflection_min 0.0
      reflection_max 1.0
      conserve_energy
  photons {target 1.0 reflection on }
rendered on PIII 1 GHz
Pixels:          307850   Samples:          322574   Smpls/Pxl: 1.05
Rays:           4624440   Saved:           2230393   Max Level: 68/255
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder                785799942         2279424      0.29
CSG Intersection              17207298           35157      0.20
CSG Merge                      5735766         3374355     58.83
CSG Union                     11471532         1864102     16.25
Lathe                          5735766         3133726     54.63
Lathe Bound                    5735766         3980932     69.41
Plane                          5735766         1685140     29.38
Sphere                      1032437880        41578154      4.03
Torus                         17207298           63636      0.37
Torus Bound                   17207298           65522      0.38
Roots tested:             26443985   eliminated:               26901
Calls to Noise:                  0   Calls to DNoise:        5256862
Shadow Ray Tests:          6683438   Succeeded:              1702918
Reflected Rays:            1667290
Transmitted Rays:          1654309
Number of photons shot:          21382
Radiosity samples calculated:     141071 (7.91 percent)
Radiosity samples reused:        1643387
Smallest Alloc:                 26 bytes   Largest:           122928
Peak memory used:         23457867 bytes
Time For Photon:   0 hours  0 minutes   6.0 seconds (6 seconds)
Time For Trace:    6 hours 47 minutes  44.0 seconds (24464 seconds)
    Total Time:    6 hours 47 minutes  50.0 seconds (24470 seconds)
Total cache size: 39180
ABX
Download 'platform.jpg' (40 KB)
Preview of image 'platform.jpg'
Subject: Re: looking for settings for transparent plastic with radiosity (WIP)
Date: 23 Apr 2001 12:49:06
Message: <3AE45D0A.76EA69BD@gmx.de>
Wlodzimierz ABX Skiba wrote:
> global_setting{
recursion_limit 5 is probably quite unnecessarily high.
>   max_trace_level 255
I don't see the photons, and where is the light source?
> object{
>   texture{
>     finish{
>       ambient -0.3
>       diffuse 0.8
>       specular 0.1
>       roughness 0.1
>       metallic
>       brilliance 1
>       reflection_type 1
>       reflection_min 0.0
>       reflection_max 1.0
>       conserve_energy
Negative ambient? never used something like that, maybe try less transmit,
some light fading, less diffuse, more specular.
It really looks quite promising, but i would probably rather start with a
standard glass finish and try to modify it step by step.
Date: 23 Apr 2001 13:19:20
Message: <3ae46418@news.povray.org>
Christoph Hormann wrote in message <3AE45D0A.76EA69BD@gmx.de>...
> > global_setting{
thanks
> >   max_trace_level 255
that's my problem
sorry for cutting
sky_sphere{pigment{gradient y color_map{[0 color blue .6][1 color rgb 1]}}}
light_source{<-30,30,-30>color rgb 1}
radiosity setting are inspired by gilles
// Message-ID: <398EE231.F90E52DC@inapg.inra.fr>
// Date: Mon, 07 Aug 2000 18:22:09 +0200
// From: Gilles Tran <tra### [at] inapginrafr>
// Newsgroups: povray.text.scene-files
// Subject: Radiosity test file #2
thanks
thanks again, good idea
ABX
Date: 23 Apr 2001 13:21:25
Message: <3ae46495$1@news.povray.org>
Hi Wlodzimierz!
word)
settings from
version is rather
You may use 'material {ior 1.5}' (or somewhat) to make it less
ghost-looking.
And I like that wood texture!
Sorry but I can't help you with radiosity - never used it.
cukk
Date: 23 Apr 2001 13:27:03
Message: <3AE465EF.16CABA17@gmx.de>
> that's my problem
> sorry for cutting
I think you need to have a photons{} block in the light source to activate
them, something like:
photons { reflection on refraction on }
Date: 23 Apr 2001 13:45:32
Message: <3ae46a3c@news.povray.org>
> ghost-looking.
Ahem - interior {ior 1.5} - sorry!
cukk
