POV-Ray : Newsgroups : povray.binaries.images : Oilve Oil Bottle - Photons - (and oil) Server Time
23 Oct 2026 20:42:05 EDT (-0400)
  Oilve Oil Bottle - Photons - (and oil) (Message 1 to 26 of 26)
Subject: Oilve Oil Bottle - Photons - (and oil)
Date: 3 Apr 2001 08:37:24
Message: <3ac9c404@news.povray.org>
render time just over 8 hours inc parse, modelled in rhino, scene laid out
in moray, mangled by hand.....
mega pov defiantly does not like shorthand translations and rotations!
eg
rotate -27.0*z
as outputted by moray works fine in mega pov until you put the version line
in, and it chokes. (error is expected } but found * instead)
after manually altering all the rotations and translations, I discover that
the camera is now not pointing in the exact same direction as before, gave
up and moved the bottle a bit closer, so the final render is not exactly the
view I was aiming for, but don't the photons look pretty (grr)
I am not a pov coder, that's the reason I use moray. I only wish either
moray
would not use shorthand, or megapov would not choke on it (only in mega pov
mode I might add)
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Download 'olive-oil-bottle.jpg' (73 KB)
Preview of image 'olive-oil-bottle.jpg'
Subject: Re: Oilve Oil Bottle - Photons - (and oil)
Date: 3 Apr 2001 09:13:29
Message: <3ac9cc79@news.povray.org>
oh yeah, forgot to mention - the reason it has the povray.co.uk bg again, is
that i am going to put this and the mug in the object library when i
eventually get those parts written :)
that and i wanted to have a 2 tone repeting floor that was not a checkered
plane.
PGP Public Key
Date: 3 Apr 2001 09:13:49
Message: <3ACA04BA.41E71748@chesapeake.net>
Very well done.
Date: 3 Apr 2001 09:24:36
Message: <3ac9cf14@news.povray.org>
Nice work.
I like the meniscus on the oil, though maybe the curvature shouldn't stop so
suddenly it should gradually become flat.  how about a Povray label on the
bottle?
Nekar
news:3ac9c404@news.povray.org...
> eg
> rotate -27.0*z
line
that
the
> moray
pov
> mode I might add)
> Rick
> Kitty5 WebDesign - http://Kitty5.com
> TEL : +44 (01625) 266358 - FAX : +44 (01625) 611913 - ICQ : 15776037
> POV-Ray News & Resources - http://Povray.co.uk
> PGP Public Key
Date: 3 Apr 2001 09:31:25
Message: <3AC9D0AC.A4D66682@gmx.de>
Nice, i'm only missing reflection photons.
Maybe a version without the thread and a with cork would look more
adequate for oilve oil, right now it looks a bit like a bottle of medicine
BTW, how long does it take to model such a thing in rhino?
> eg
> rotate -27.0*z
I'm regularly using such shortcuts but never had problems in megapov.
Date: 3 Apr 2001 11:49:57
Message: <3ac9f125$1@news.povray.org>
> eg
> rotate -27.0*z
is rotate z*-27.0 okay? (I've never had a problem with shorthand*)
*well, I did have a problem, but it was my problem, not povs
Date: 3 Apr 2001 12:36:53
Message: <chrishuff-EB897C.11365403042001@news.povray.org>
In article <3ac9c404@news.povray.org>, "Rick [Kitty5]"
I've never had any problem with them, and use them fairly often, but I
usually reverse things from what you showed:
rotate -z*27
My first thought is that it must be something to do with promoting the
float value of 27 to a vector before multiplying by z, but the error
message seems to indicate it messes up before then...and as far as I
know, that section of the code hasn't been messed with, except for
adding a ^ operator, and it works in other cases...
Christopher James Huff
Date: 3 Apr 2001 12:38:53
Message: <chrishuff-1317A1.11385403042001@news.povray.org>
BTW, what is the ior of oil? And it might be nice to have the light
coming from the other direction, so the caustics aren't hidden by the
bottle as much.
Date: 3 Apr 2001 13:17:34
Message: <3aca05ae@news.povray.org>
yes that works fine as far as I know, however
rotate -27.0*z
as outputted by moray is a no no
PGP Public Key
Date: 3 Apr 2001 13:17:36
Message: <3aca05b0@news.povray.org>
couple of hours, and that's considering I don't know what I am doing :)
PGP Public Key
Date: 3 Apr 2001 13:17:39
Message: <3aca05b3@news.povray.org>
so
> bottle?
it should curve more, but I was banking on the bottles refraction to hide it
label, thought about it, but didn't want to hide the refractions
PGP Public Key
Date: 3 Apr 2001 13:17:42
Message: <3aca05b6@news.povray.org>
its exactly the same as the 3 year old bottle we have here - don't use it
much, but it was a nice shape to try next after the mug
PGP Public Key
Date: 3 Apr 2001 13:17:45
Message: <3aca05b9@news.povray.org>
> bottle as much.
I have no idea, used 1.33 (water) as it looked nice.
the best caustics are in the bottles shadow, which i think helped to
highligt them, i did quickly try a couple of other lighting arangements, but
liked this best.
PGP Public Key
Date: 3 Apr 2001 13:58:10
Message: <3ACA0F32.617ABAEF@gmx.de>
> rotate -27.0*z
I tried exactly the same in megapov 0.7 and had no problems, same in 0.6a.
Date: 3 Apr 2001 14:09:43
Message: <3aca11e7@news.povray.org>
>> rotate -27.0*z
Hmm, could this be a platform/download thing?  Have you tried redownloading
and installing it?  It could simply be something broke in the transfer.
Geoff
Date: 3 Apr 2001 15:03:27
Message: <MPG.15342eefcf3bde6b9898a8@news.povray.org>
> > bottle as much.
Well, I don't know if this is any help or not, but 1,2,3 Propan-triol
(also known as Glycerol) has the same IOR at 20 degrees C as borosilicate
glass.  Unfortunately I don't know any numbers off the top of my head.
OK, scratch that, apparently olive oil has an IOR of 1.47, as according
to :
http://oldsci.eiu.edu/physics/DDavis/3050/Ch16R&R/Intrnl.html
You know, sometimes I really like Google...
Bye for now,
     Jamie.
Date: 3 Apr 2001 16:51:21
Message: <MPG.1534483974e0acf59898aa@news.povray.org>
Whoops, that should really have been Propan-1,2,3-triol...
Never mind.
Bye for now,
     Jamie.
Date: 3 Apr 2001 17:19:37
Message: <3aca3e69@news.povray.org>
> eg
> rotate -27.0*z
line
Yet you can use -z*27.0 fine (yes, with #version megapov) - I know, it's
what I use
Date: 3 Apr 2001 19:39:35
Message: <3ACA5E1C.6727DD09@videotron.ca>
> >> rotate -27.0*z
Same here.  Most of my transforms are shorthand and I have yet to see a
problem.  MP 0.5, 0.6, 0.6a and 0.7.
> Geoff
Probably not.  as the CRC of the zip file (or .tgz) would have caught
it.
I suspect drunk driving.  Rick should post a more complete example of
what is not working.
Francois Labreque |   //\\    Wear an ASCII ribbon!
    flabreque     |  ||  ||
        @         |   \\//    Support the campaign
   videotron.ca        \\     against HTML e-mail
                      //\\    and news!
Date: 3 Apr 2001 21:08:33
Message: <3aca7411$1@news.povray.org>
will do in the unoff.patches :)
PGP Public Key
Date: 3 Apr 2001 21:08:35
Message: <3aca7413@news.povray.org>
> what I use
i know i can, however its what is outputted by moray that i am working with,
and works perfectly till i add the version info, then it all falls down, i
dont want to have to start manually editing my scenes, especially as some
can get extremly complex with many layers of csg involving hundreds of
objects! (which is the reason i use a modeller!)
PGP Public Key
Date: 3 Apr 2001 22:05:20
Message: <3aca8160@news.povray.org>
> > what I use
with,
Search & replace? changing the -27.0*z to -z*27.0
Then again, time consuming
Date: 3 Apr 2001 22:33:23
Message: <3aca87f3@news.povray.org>
would have to search and replace every value one by one, would be simpler to
edit the code line by line by line.
PGP Public Key
Date: 4 Apr 2001 07:24:07
Message: <3acb0457@news.povray.org>
>> what I use
There really is something weird with your installation, since I do this kind
of thing all the time, and have never had a problem.  Perhaps something else
weird in your code, that just causes the break there?
Geoff
Date: 5 Apr 2001 04:56:44
Message: <3ACC33DA.DCB3AAB5@reading.ac.uk>
_Exactly_ what version info do you put in, and where do you put it? I
use the shorthand rotates/translates using (float)*(axis) all the time
in Win versions of MegaPov, PoVMan etc. I've never used Moray, but I
can't see this particular shorthand causing a problem with any
unofficial version.
Bye for now,
	Mike Andrews.
Date: 5 Apr 2001 12:37:58
Message: <3acc9f66@news.povray.org>
to
Realised that after :(
