POV-Ray : Newsgroups : povray.binaries.images : Radiosity2-Now with "ambient Normals" Server Time
24 Nov 2026 06:28:41 EST (-0500)
  Radiosity2-Now with "ambient Normals" (Message 1 to 19 of 19)
Subject: Radiosity2-Now with "ambient Normals"
Date: 20 Mar 2001 13:02:07
Message: <3ab79b1f@news.povray.org>
OK ...
I tried "normals on" and its so beatiful now ...
It took 'bout 2 hours with a crash between ...
So maybe the lower half is not correct with radio....
I can't see any artifacts, but I can't give my word ..
background{rgb 1}camera{location<1,5,-2>look_at 0}#macro
m(a,b,i)#local d=(b-a)
/8;#local
e=vcross(d,y);#if(i)m(a-e,a+e+2*d,i-1)m(a+e,a+2*d-e,i-1)m(a+3*d-e,a+e
+3*d,i-1)m(a+3*d-e,a+5*d-e,i-1)m(a+6*d-e,a+e+6*d,i-1)m(a+8*d-e,a+e+8*d
,i-1)#else
cylinder{a,b,vlength(d)/3 pigment{rgb 0}}#end#end m(-4*x,2*x,4) // Jan
Walzer
Download 'radiosity_test.png' (121 KB)
Preview of image 'radiosity_test.png'
Subject: Re: Radiosity2-Now with "ambient Normals"
Date: 20 Mar 2001 13:24:43
Message: <3ab7a06b@news.povray.org>
Here's my version, with my rad settings, a sky_sphere and a corrected sphere
texture.
Download 'janzrad.jpg' (18 KB)
Preview of image 'janzrad.jpg'
Date: 20 Mar 2001 13:45:48
Message: <3ab7a49c@news.povray.org>
> texture.
Why is it so yellow on the bottom?  I don't see anything that'd give it that
color.
Geoff
Date: 20 Mar 2001 14:21:06
Message: <3ab7ada2@news.povray.org>
Your settings are ?
... did you change the finish of the texture, or only the Rad-Settings
seems quite dark for me ... but so far .. thanx ..
/8;#local
,i-1)#else
Walzer
Date: 20 Mar 2001 14:26:40
Message: <3ab7aef0@news.povray.org>
Hehe ... I asked this myself ...
The Heaven is blue ...
so the most ambient is blue ...
The sun is yellow ...
so where the sun hits the sphere, there is the ambient and the sun
(blue + yellow) that gives white ...
The shadow of the sphere, that is not lit by the sun is blue, because
of the ambient ...
below the sphere there is no ambient, but the sun brightens some parts
so it gets yellow ...
You understand ?
/8;#local
,i-1)#else
Walzer
Date: 20 Mar 2001 14:57:14
Message: <3AB7B618.4249554A@gmx.de>
> of the ambient ...
> You understand ?
Because the sphere and floor themselves are white,  the yellow light
leades to yellow color where the sky's effect is not that strong.
Date: 20 Mar 2001 20:52:17
Message: <3ab80951@news.povray.org>
> Your settings are ?
global_settings
 assumed_gamma 1
 ini_option "+QR"
 radiosity
  pretrace_start 0.32 pretrace_end 0.08
  count 300 nearest_count 4
  error_bound 0.01 recursion_limit 1
  low_error_factor 0.5 gray_threshold 0
  minimum_reuse 0 brightness 1
  max_sample 1 adc_bailout 0.01/2 normal on
> texture, or only the Rad-Settings ?
I only changed the rad-settings and the pigment of the sphere.
That can be fixed by using a higher brightness or gray_threshold. I didn't
mean to imitate your settings, just show you that I had fixed "reflection"
the problem.
Date: 20 Mar 2001 23:38:27
Message: <3AB830C6.FFA7FEBC@pacbell.net>
> of the ambient ...
> You understand ?
No, I don't. I have never seen any situation in real life that this
would represent. I think radiosity does a poor job of realistic
ligthing representations and is over rated. I further think those who
use it just imagine that it gives a good lighting model when in reality
it fails the reality test. Further more...
Well that's what I think anyway :)
Ken Tyler
Date: 21 Mar 2001 05:33:31
Message: <3AB88380.89C707E7@kivisalo.net>
> would represent.
How can you compare then?
I have seen several photometric images of physical setups and
corresponding rad simulations in IEEE and other publications
which clearly show the validity of radiosity. There are differences
in implementations, like noise in the ray based radiosity, but the
basic concept is solid.
The problem with all radiosity implementations is that there are too
many cryptic parameters to tweak so users in general use non optimal
setup which ruins the simulation. There is an EU project ARCADE which
tries to automate the parameter tweak phase among other things so that
you don't have to be "Certified Radiosity Technician" to produce good
results. http://www-imagis.imag.fr/ARCADE/
This particular scene is a poor choice for meaasuring how realistic
the simulation is for two reasons. The "sky" emits the same amount of
"energy" as the "sun". Nobody has ever seen this situation so it's a
bit difficult to compare. The scene is also uniform in all directions.
There is something funny going on with background{} and radiosity.
I rendered the same scene enclosed in a sphere and the anomaly at
the bottom of the sphere disappeared.
http://hammer.prohosting.com/~kkivisal/sphere.jpg
______________________________________________________________________
Kari Kivisalo                                  http://www.kivisalo.net
Date: 21 Mar 2001 05:57:36
Message: <3AB889A4.D0C40829@pacbell.net>
Kari Kivisalo wrote:
> > would represent.
Simple. In front of me I place a solid red ball on a white piece of paper
with a fairly bright light shining on it. I see a fairly dark shadow but
absolutely zero evedence of red color bleed. I now repeat the experiment
with other colored objects. Again no color bleed.
Are we trying to mimic real life or photometric experiments ?
I remain unconvinced.
Ken Tyler
Date: 21 Mar 2001 06:09:45
Message: <3AB88BF9.D2323D7A@gmx.de>
I just tried the same with a few colored pencils and a red peace of cloth
and saw quite a lot of bleeding.  Sadly i have no digital camera here to
show it :-) It's cloudy today and the pencils have a fairly shiny surface,
but i really think it is quite realistic.
Date: 21 Mar 2001 06:12:06
Message: <Xns906B7C605547Cseed7@povray.org>
>paper with a fairly bright light shining on it.
Dim the light, or better just use the daylight. On the side where the
light comes from the paper has a red tint.
I could make some foto's if you want to be convinced.
Ingo
Date: 21 Mar 2001 06:30:46
Message: <3AB890EB.5B9EB478@kivisalo.net>
Is Ken trolling us?
Date: 21 Mar 2001 07:03:26
Message: <3ab8988e@news.povray.org>
I don't think the problem was due to the background{} ...
If you turn off the normals in radiosity, you will get a similar (or
the same) result ...
the "ambient-normals" of the sphere just scramble the reflections, so
you can't recognize them ...
/8;#local
,i-1)#else
Walzer
"Kari Kivisalo" <kar### [at] kivisalonet> schrieb im Newsbeitrag
news:3AB88380.89C707E7@kivisalo.net...
this
> > would represent.
which
that
good
of
directions.
> Kari Kivisalo
Date: 21 Mar 2001 07:47:22
Message: <3AB8A2E1.7A7FDB6@kivisalo.net>
This was rendered with normal on.
Date: 21 Mar 2001 08:19:09
Message: <Xns906B91EAF763Fseed7@povray.org>
in <3AB890EB.5B9EB478@kivisalo.net> Kari Kivisalo wrote:
>Is Ken trolling us?
Or his evil brother ...
    (_)
    (")  W
    _M_
Ingo
Date: 21 Mar 2001 20:19:42
Message: <3AB95406.C02CF54F@unforgettable.com>
> >Is Ken trolling us?
>     (_)
>     (")  W
>     _M_
Nice pic. I especially like the effect of radiosity here. But can you
post the scene file?
(heh heh heh)
-Xplo
Date: 22 Mar 2001 10:38:27
Message: <3aba1c73@news.povray.org>
It's because the sky is simulated. The light that illuminates sky comes from
the sun. So the blue intensity in the sky should never be higher than the
blue intensity of the sun e.g. sun: rgb ( 1.0, 0.9, 0.5 )  might have a sky
of rgb ( 0.1, 0.3, 0.5 ) and not rgb ( 0.1, 0.3, 1.0 ).  (I don't know what
the settings are in the pic)
I think absorbing media and scattering media might make a more 'real' sky.
BTW, has anyone tried making sky with media before?
Nekar
"Jan Walzer" <jan### [at] lzernet> wrote in message
news:3ab7aef0@news.povray.org...
> of the ambient ...
> You understand ?
> /8;#local
> ,i-1)#else
> Walzer
Date: 24 Mar 2001 11:10:02
Message: <chrishuff-D8933E.11034024032001@news.povray.org>
In article <3aba1c73@news.povray.org>, "Nekar Xenos"
It has been done by several people. I've had fairly good results
producing a sunset by using scattering media in several "shells" and a
large sphere for the land. However, MegaPOV's sampling method 2 or 3 is
almost absolutely necessary for this.
Christopher James Huff
